Question about Mitsubishi WT-46809 46" Rear Projection Television
Mitsubishi part signal pcb nla 930b881001
I was told i need the above part for my projection tv hd 1080 its blury and has horizonal lines, i was told they no longer make the part, can you help me find the part. thanks
  • Mitsubishi Master
  • 8,617 Answers
That part is no longer available however you can go to this link and they will rebuild your board and provide full warranty. Heres the link You just need to list what your part number is. I am one of the techs that rebuild the boards. They are completely reconditioned and guaranteed. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Mar 31, 2008
I have a Mitsubishi 55" 1080 HD TV with a blurry
info16939,
You need to go to my tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 15, 2010 | Mitsubishi WS-65313 65" Rear Projection...
It say 480 stretch on the screen how do I turn it to 1080 for my Hd tv
Make it sure that you have a 1080 signal from your source(eg. HD receiver, bluray player etc.). Try pressing format button on the remote until you get full picture . Or try changing the format or aspect ration in your satellite or cable box.
Dec 29, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi WS-65907 rear projection TV HD goes blue.
I would look at the source for the Hd signal as being the problem--if you are using some kind of cable or sat box it will deliver the signal to the DTV input on the back of the set--this is the HD input for this set.
It is possible to have a problem like you describe be one in the set--but very unlikely----have you looked on that green signal board for any signs of Glycol?
Anything that will produce a 1080 signal to the DTV input should tell you if the problem is the set or the source of the HD signal that is causing the problem.
If you have questions or need advice let me know--I am here to help people.
if this information has helped you rate this solution as i do this here for free.
SD TECH
Dec 05, 2009 | Mitsubishi WS-65907 65" Rear Projection...
How do I reset big screen tv to 1080 on remote
You don't.
It should automatically switch to 1080 when and only when there is a HD signal present. Otherwise it will be in 480 and you will need to use the format button on the remote to change the picture size. If it does not switch to 1080 and you know for sure you have a true HD signal present, there is a problem with the unit.
Hope this helps,
Skyassoc
Jun 28, 2009 | Mitsubishi WD-62531 Projection Television
Big screen on bad red lineand blury
Good DAy, mitas;
It sounds that the TV is having a Convergence Circuit problem or you may CRT Coolant (fluid) on the PCB's. Good Luck, big IRISH........ PS Call for help, by calling a Factory Service Center....get an estimate!!
Aug 31, 2008 | Mitsubishi WS-55809 55" Rear Projection...
TV is Mitsubishi 65" Model #WS65813, Serial #NWPROJ4K-5 (Diamond Series).
That particular board is NLA - - - the only way to have it repaired besides a local shop is to send it in to PTS Electronics for rebuild but I'd call them first and make sure they support it.. That's from a V23 chassis and that particular board was used in many PTVs in the Mits line-up.
PTS is 800-844-7871
Good Luck!
Bill
Dec 17, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Vertical Lines / Color Differences at edge of Analog vs HD Picture
EXACTLY-YOU HAVE THE USUAL "AGING" CRT PICTURE.THIS WILL ALWAYS HAPPEN WHEN YOU WATCH THE TV W/BLACK BARS ON THE SIDE,THERE IS NOTHING SHORT OF ALL 3 CRTS' REPLACEMENT TO FIX IT. JOE TV
Oct 31, 2007 | Mitsubishi WS-55819 55" Rear Projection...
HD setup, 480 to 1080 not working.
I had this same problem, got my HD installed yesterday w/ Direct TV, have had this TV since '02. The fact that is wasn't working, and Google, led me to your post in search of answers. I even went to a local retailer that sells the Mitsubishi TV's and they were as helpful as if I had gone to a drug store seeking the answer. So, between browsing other posts, and then going to the manual (who'd of thunk) I got my, and your, answer. You need to do the following, nothing magic: 1)Connect the component video output of the Direct TV HD Receiver to the DTV inputs on your TV. The COMP 1/2 inputs are NOT 1080 compatible, only the DTV input. As another poster said, you must use component video cables, not the old red/yellow/white cables. you can lose too much signal quality w/ the old R/Y/W cables and your TV still won't recognize the 1080. 2)Set your receiver to a HD Channel, which are in the 70's. 3)Use the format selection on your remote and select until you get the 1080i Standard (or whatever your preference is) format. 4)Enjoy Bottom line is the COMP inputs are not HD. Page 64 of the manual (at least the one i downloaded from mitsubishi-tv.com) is what gave me the final piece of the picture. Good Luck!
Sep 20, 2007 | Mitsubishi WS-65869 65" Rear Projection...
What do I need to do to get 1080dpi
Do you have HD cable or satellite? You need to make sure that they are connected to either a DVI, HDMI or Component (Y,Pr,Pb) connection. Depends on the age of the set you made need to get the Mitsubishi adaptor for HD. And to be correct the resolutions are listed as 48i,480p,720p or 1080i. DPI is used for printing or scanning as it refers to Dots Per Inch. In television we refer to lines.
May 07, 2007 | Mitsubishi WS-55515 55" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
350 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
