the lights on the controls are not working. The bulbs enclosed behind the conrols are still working.
Comments:
Mar 31, 2008
- I meant controls. Also, The ice maker does not produce the amount of ice I need.
Mar 31, 2008
- Model# PDS22MFBBB
Serial# DLO47501
Apr 01, 2008
- My problem was not answered. I have a GE fridge, model#PDS22MFBBB : serial# DLO47501 I have an ice maker, not an on the door dispenser.
My problem, the contols for keeping the freezer and refridgerator at the correct temperatures will not light. This means I do not know what the temperature of either part of the fridge. Also, the ice maker does not dispense the correct amount of ice.
The model I have is one that has the freezer compartment on the bottom. Would this problem be happening because I need to replace the water filter? I have looked at the troubleshooting pages in the manuel many times. I cannot find an answer.
Thank You, Catherine Dooley fairhaven74@comcast.net
Can you please provide the model number of your appliance?
Comments:
Mar 31, 2008
- Here is a link with more info on what could be wrong with your appliance. Here is more info on how to take it apart to check for loose wires. User guide. Check the troubleshooting section on page # 35 for more info.
Apr 01, 2008
- If the display does not work is not because of the water filter needs to be change.
There are 2 possibilities to pin point the problem:
1. The main controller board might be defective and not providing the right voltage to the display board assembly.
2. If the main controller board is providing the right voltage then you have defective display board.
I will try to find a service manual for you.
Apr 01, 2008
- Contact this site and ask them for the parts you need to fix your appliance. Provide the exact model number to them to get the right part.
They should be able to help you.
Rating Locked! (?) fairhaven74 has rated this solution as Very Helpful
what is a GE GSS25KGMBCC SIDE BY SIDE fridge (working) worth?? and what year was it made?? thanks...
(More)
what is a GE GSS25KGMBCC SIDE BY SIDE fridge (working) worth?? and what year was it made?? thanks so much!
we moved the refrigerator to paint and when we retured the waterline to the icemaker is partially...
(More)
we moved the refrigerator to paint and when we retured the waterline to the icemaker is partially blocked
Frigidaire frt21h8csbo, sounds like compressor makes a buzzing noise off and on freezer wont stay...
(More)
Frigidaire frt21h8csbo, sounds like compressor makes a buzzing noise off and on freezer wont stay cold. I checked fan everything else looks ok, had this problem a couple months ago started working again now its down.
