Question about HP Compaq nc6220 Notebook
Up dated Bios
I updated my Bios as advised by HP now it will not boot up, no screen nothing
dave
Ireland
  • 1 more comment
  • daphil Mar 31, 2008
    help
    It was the correct Bios as advised by HP. Is there any way to roll back the upgrade or even go back to factory settings ?
    Thanks
    Dave
  • daphil Apr 01, 2008
    Went back to shop today and the guy in the shop produced an e-mail from HP extending the warranty on my type of laptops. The e-mail was intended fot the USA, but appearantly it is valid world wide. Makes one think of dodgy batches. Anyway the shop took back my lap top and have sent it to be repaired. I guess HP will just replace mother board. So if anybody ther has a problem out of warranty, it might be worth cheching your serial number.
    Once again thanks for your help and advice and so long for a while from Ireland.
    Dave
    Scholar:
  • 132 Answers
First make sure you have the correct file, then you need to make sure you know how to do that. A botched "flash" will ruin your entire system. also take out the battery and only use the power cord.
Posted on Mar 31, 2008
  • Sandy Chamberlain
    Sandy Chamberlain Apr 01, 2008
    no, not like your thinking. You must re-flash (upgrade the BIOS) to correct it. The only other way is to replace the chip on the system board and that needs solder. there is a DOS version -flash on the HP site. Try that one, you boot right off the floppy with that (I hope you have a floppy drive). See if you can boot off the cd drive with maybe your restore cd, if you don't. IT won't fix the BIOS but will get you started, (you have nothing when you boot now, except for power? Is that correct?
Hp bricked after bios updates hp pavillion dv9700 need help please
hello,
this indicete that you did not do properly the update,my advice is to restore the old bios if you backed up if not try to do again the update
Jun 12, 2012 | HP Computers & Internet
HP Boot problem
a1540n PC Desktop fails to boot unstated OS....
a very obsolete PC, in fact HP retired, support.
no problem really but makes getting books on it harder... facts...
  1. so did you make sure all fans work? and stay on,
  2. does the DVD drive eject button work
  3. does the keyboard caps/num/scroll locks LED toggle, when pressed
  4. does BIOS work with 1 DDR2 RAM stick (1 by 1) not 2 at once
  5. do the fans all work , up to 3?
  6. Does the F1 key work, hit fast at power on button, in 1-3seconds? immediatay after power on.
  7. did the screen show Hit F1 to enter HP setup? if yes did you?
  8. any PCI expanisin cars in the PCI slots, remove them?
  9. remove DVD and HDD cables, see if BIOS works.
  10. CPU fan Heat sink fins not packed in lent, as all are, clean it with Can-o-air?
  11. test the PSU? (ask)
The goal is BIOS screens, first. first things are first.
carbon dating retired PCs (hp zero support now)
is not easy. and is key to learning what BIOS is there (a pain)
the date you bought this PC is not important , the date it was made maters only....
standing here, i cant do that, id need to do hands on inspection
old AMD Athlon 64 X2
says ,,,,DDR2 SDRAM 2x1g it says, remove one?
NVIDIA GeForce 6150 LE TurboCache supporting 256MB
integrated, VGA.... no card. if it has a card for VGA remove it to test system using integrated VGA jack on MOBO
best i can tell, 99% off all review on pc have TIME STAMP(DATE)
but one review said it had norton 2006
so we know that one is 2006 and is over 10years old.
maybe 12 years old.. the dvd drive has date code, there in clear english, dates, if it says 2005 , there it is. other HP codes
in the PC also date the PC.
i looked up your ASUS mobo and they says its
The current bios is 3.07 phoenix-award bios.
Even ASUS dont have data on A8m2n mobos. now.
huge list of keys on PHoenix bios.
my guess is F1 or F10 is the BIOS hot key
remember HP ordered Phoenix bios under contract and HP
can in fact dictate hot keys... so HP wins here.
find the answer to this is hard. (no HP books)
hint 1: the coin cell battery can be dead, replace it on the mobo
life spans 3 -5years possible most makers top life is 7.
the goal is here, if this works we test the HDD next.
see?
its just 2 goals, BIOS, below
then getting the HDD working and last the unstated OS working.
Jul 15, 2017 | HP Pavilion a1540n PC Desktop
Hi, I did this with Proliant ML350 G5: 1. shut it down normally 2. installed some more memory 3. started it up with BIOS update CD in the CD-Drive 4. updated BIOS successfuly (according the flas...
step one after checking DC supply voltage to spec
is does the BIOS key works
BIOS must work or the system is dead.
or video out port dead.
is this your first PC failure? experience
see if this dead screen page helps.
your post is not clear at all
start at the power switch and then go into BIOS
can you do that, if not find out why, bad screen>?
bad VGA port? lost DC power, try 2nd known screen
we can see you work and what all you see or saw.
lacking more clear results, and tests.
http://jeepdied.com/look/puters/dead-screen.html
Mar 26, 2017 | HP Compaq ProLiant ML350 G5 Server
Dv6000 will not startup ,Black screen , hd isnit being accessed
When you first turn the laptop on is there a HP splash screen? Can you enter the BIOS (normally by tapping F2 or Del key). If so then it would seem the BIOS updated OK. If when you turn it on there is nothing the BIOS flash probably went wrong and the machine will need a new BIOS flash chip installed.
If you can access BIOS then it may be a simple problem that the new BIOS reverted to default values. The most common issue would be the boot mode of the HDD. Look through the BIOS menus and there should be an option for boot which will say AHCI/IDE/Compatibility. Try changing it to another option, save and exit BIOS and see if that helps. Try this for each option.
Alternatively tap F8 continuously when you turn the laptop on and see if the advanced boot menu appears, if it does try selecting Safe mode with networking.
Finally to test if the HDD is actually working, try downloading Hiren's BootCD and boot to it. Then run some HDD diagnostics to see if the HDD is operating correctly.
Hope this helps,
www.PuterCare.com
Jul 07, 2010 | HP Pavilion dv6000z Notebook
I have a HP Media center pc and I tried to up date BIOS which did not work turn off my pc and then came back on with a black screen get the message need system disc put the windows xp but nothing happens
make it clear what is the exact problem weather the sys. is not turning on or it turns on but you are not able to boot if your are not able to boot what is the error and when do you get the error message.and why did you update the bios??
Oct 29, 2009 | Microsoft Windows XP Home Edition
Asus live update,cannot update..wont let me.
You are welcome... you can rate my solution if you like... thanks
Mar 17, 2009 | Shuttle XPC SD32G2 Barebone
HP Pavillion DV9000 ''Checkered Screen''
Yes it is a hardware problem not a software one perhaps replacing the monitor Im afraid nothing else will suffice...
Nov 11, 2008 | HP Pavilion dv9000z Notebook
BIOS help
Hello
you need to download right bios and burn it to a CD, then you need to boot from that cd.
plz give me the exactly model of your computer? and I will search for the bios update.
you can boot from the recovery cds before you have "installed" the right bios.
let me know the exact model and I will give you more instructions what todo.
if you know how to burn and how to get the right bios go here and input your model.
else let me know.
hp drivers
Oct 09, 2008 | HP Pavilion dv9000z Notebook
Bios upgrade failure
so what did hp advise exactly.you could try removing rtc battery and see if it (bios)resets but I dont know yet exactly what youve done.you may need bios flash files installed on a floppy and reflash bios(depending what youve done this is the only left solution)
Mar 31, 2008 | HP Compaq nc6220 Notebook
HP Compaq nc6220 Notebook Logo
165 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
