Question about Thales MobileMapper CE GPS Receiver
Moblie Mapper CE Cannot Link to desktop
My Mobile Mapper CE will no longer connect to the desktop computer. The computer does not recognize the device and reports a malfunction. If it does recognize the USB device, it reports a failure during hardware installation. Not sure if a setting was changed or if something is wrong with the unit. If I try to connect from the MM CE it reports that it's been disconnected from the remote computer
I plugged one of our other units (MM CX) to the I/O unit I was using for the MMCE and it connects without a problem.
On your Thales, go to Start> Settings> Control Panel, then find "PC connection". Open that and make sure "Enable direct connections to the desktop computer" is checked. Click "Change Connection" and make sure it says USB then hit OK. Hit OK again close Control Panel. Disconect the GPS from your computer and reconect. It should allow access now.
Posted on Jun 19, 2009
It stopped recognizing my air printer and I dont know how to get it back online
On your desktop, go to control panel and then to network and internet setting's. Now click on network devices and see if your printer show's up. If not, unplug printer for one minute then plug back in and power on, If it is detected in the network devices, then it should work. Being that it is no longer working for either the desktop or ipad, then it is most likely the printer itself and should now be available to both once it is detected in network devices . Once it is detected, left click on the printer icon and then right click on "connect".
n
Feb 21, 2014 | Computers & Internet
Can't comunicate between desktop and printer
On desktop, go to 'start' then to 'control panel' then to 'internet and network' and then to 'network devices'. Left click on network devices will bring up icon's of all wifi device's recognized by computer, Right click on the printer icon then left click on 'connect'. You should now be connected and communicating.
Feb 10, 2014 | Verizon Wireless Jetpack 4G LTE Mobile...
My computer no longer recognizes my Panasonic mini-DV recorder. I am using USB 2.0, but the device manager does not even recognize the camera. I have even tried multiple USB ports, all to no success. I...
Vista may not support it but you can try some things.
oYou may need to simply and very carefully delete all usb devices from device manager and restart so they are reseen and re-installed.
usb devices in devices mgr link
Google
I would take the time to look at some of these help articles to determine how you wish to proceed:
more at this link
Google
this is a differentr camera but may also give some leads to discovering the issue:
Connecting Sony Handycam to Windows Vista Via USB
Google
Mar 25, 2017 | Panasonic PV-GS35 Mini DV Digital...
I am getting problem connecting samsung B5722 with PC. I am using windows XP (SP3) with 512 RAM. I have installed Kies 1.5 supplied with the set but failed to connect. Again I downloaded Kies 2.0 from...
Hi supriyakhan1 your problem is that you need to down load the windows moblie onto your computer first then you will be able to connect your phone to your computer. Next you need to go to windows market on your phone. The problem sounds like your carrier hasn't set your internet up on your phone. you need to check your account to make sure that your phone is provision for the internet. Ok next you need to setup your phone to see the internet. If you have a windows mobile them you need to going your settings to check for that ok. Hope this helps
Feb 27, 2011 | Samsung B5722 Cell Phone
My computer no longer "sees"
hello
at end of this instruction set, see link to review more questions/answers,as your issue with CD/DVD ROM will vary .
This document applies to HP and Compaq desktop computers with Windows XP, Me, and 98. Use this document to make Windows and the CD writing software recognize the CD or DVD writer drive. Start at Step 1; do not skip to other sections until Step 1 has been completed. Step 1: Does Windows detect the CD or DVD drive? Use Device Manager to determine if Windows is recognizing the drive:
  1. In Windows XP, click Start , and right-click My Computer . In Windows 98 and Me, right-click the My Computer icon on the desktop.
  2. In Windows XP, select Properties , click the Hardware tab, and then click the Device Manager button. In Windows 98 and Me, select Properties , and click the Device Manager tab.
  3. Click the plus sign (+ ) next to DVD/CD-ROM Drives (or similar) category.
  4. Do the following depending on what is listed in the DVD/CD-ROM drives category:
    • If the CD or DVD drive name is missing , the drive is not being detected by Windows. Close Device Manager and skip to the section CD or DVD drive is not recognized by Windows .
    • If a drive name is shown but is disabled (icon is marked with a red X, c00877300.gif ), the drive has been disabled. Right-click the drive name and select Enable . You may have to restart the computer to complete the enabling process. The drive should work correctly once it has been enabled. NOTE: If the drive cannot be enabled, a required service or driver that the drive needs is not functioning or has been disabled. Click the plus sign next to IDE ATA/ATAPI controllers and troubleshoot any problems found according to any error codes in Device Manager. Resetting the BIOS may also resolve this problem.
    • If a drive name is shown but contains an alert icon (an icon marked with an alert symbol, c00877301.gif ), then use the section Using Device Manager error codes to troubleshoot the problem. You may also use the next section Disc burning software does not recognize the original drive to reset the drive configuration.
    • If the CD or DVD drive is listed as normal but your disc burning software does not recognize the drive, Device Manager shows no special icons c00877302.gif . Windows is detecting the drive but the writing software does not. Leave Device Manager open and continue with the next section Disc burning software does not recognize the original drive .
here is a link that will give you several other questions and answers to CD/DVD ROM issues.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=11843&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=443069
please rate me with 4 thumbs UP to keep my services active
Dec 01, 2010 | HP Pavilion a810n (PP164AA) PC Desktop
My DellAxim doesn't recognize my Ambicom WL54-CF
All versions of activesync will handle this device providing it is powered by Microsoft Widows Mobile, Microsoft Windows CE, or a similar Microsoft Windows Powered OS. I am unaware of what your specific device utilizes; however I do know that all versions of ActiveSync will provide support to devices listed above.
The CD is most likely a support plug-in or a remote install for desktop to device software.
Please consult Dell's support and Drivers site for any additional information or pieces of software you may require. You should however, providing your desktop/laptop computer is using > Windows XP, be able to utilize limited access abilitys of your device (such as transfer of files) given Windows Mobile device recognition.
Please let us know if you require further information.
Thank you for choosing FixYa!
Jun 12, 2009 | Dell Axim X3 Pocket PC
My nokia 6500 slide is not detected on my p3 processor computer
hi ,
on your p3 laptop/desktop go to the device manager and update usb drives (DO NOT CONNECT your phone). Before that uninstall pc suite. Then reinstall again.And follow the on screen guide how to connect the phone.
Apr 11, 2009 | Nokia 6500 Slide Cellular Phone
How can i download pictures from my samsung sgh e330 to computer?
You need a USB cable meant for your handset to connect to computer. Once you connect your handset to your computer , you can be able to copy pictures from mobile to computer. Go to samsung site to download the latest drivers and softwares for your handset. You will surely get a PCsuite for your handset.
Nov 13, 2008 | Samsung SGH-E330 Cellular Phone
My Canon Power Shot SD800 IS no longer is recognized by my computer when I link it up to download my photos from my camera to my PC. I have tried reinstalling my software and that did not work. Do...
I would like to help you troubleshoot your connection issue. I need to know:
1. Which Operating System you are running.
2. What other, if any, imaging devices you have connected to your computer such as printers, scanners, webcams.
3. Are you on a laptop or desktop?
If we could chat through this it would be easier and quicker to resolve.
May 30, 2008 | Canon Cameras
Thales MobileMapper CE GPS Receiver Logo
329 people viewed this question
Top Thales GPS Experts
Will Halftowaite
Are you a Thales GPS Expert? Answer questions, earn points and help others
