Question about Garmin StreetPilot C330 GPS Receiver
Garmin c330 I got this unit for christmas and have only used it about 10 times. Now when I plug it into the car outlet(yes I made sure the outlet has power) the Garmin comes up and just says "low battery". What is the problem?
  • 2 more comments
  • Freebird719 Apr 01, 2008
    Great starting point. I will investigate.
  • ferdy95 Apr 03, 2008
    mine did that too at first, now all it does is come on for about 2 sec and then goes off. The other day I kept turning it back on and finally after a boatload of times it did stay on and work al the way untill I got back home(30 mi). Today it will not stay on, what gives?
  • Anonymous Apr 07, 2008
    I'm having the exact same problem. The pins seem fine. What else could it be?
  • RJDancer Apr 10, 2008
    My Garmin charges easily via USB on my computer but will not charge in car. I, too, get low battery message and no charge. The outlet is o.k.
Push the reset button for three seconds...
It is found under the thumbnail door at the top of the unit
where GARMAN name is located.
The battery if good will recharge.
Posted on Apr 11, 2008
  • 3 Answers
Pins on the mount are broken
Posted on Apr 01, 2008
Battery charging with computer. Do I have to leave the unit on when it's plugged into the computer Garmin Street Pilot C330
Yes just leave the unit power ON and when the charging is done the unit will stop charging automatically.
Jun 17, 2010 | Garmin StreetPilot C330 GPS Receiver
Why should my GPS indicate a low battery even though it is plugged into my AC outlet in my car?
It sounds like the unit is not being charged when it is plugged into the car. Does it come on when you plug it in, or do you have to press the power button? If you have to press the button, the charger is not sending power to the unit. Make sure it is connecting properly to the unit and that it is seated in the AC outlet correctly. If it is, check the fuse in the end to see if it has blown. If so, replace it. If that is not the problem, you may have a problem with the AC outlet in the car.
Feb 18, 2010 | Garmin StreetPilot C330 GPS Receiver
Garmin won't turn on or charge.
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 23, 2009 | Garmin StreetPilot C330 GPS Receiver
I hope this helps, I had the same thing happen today. I noticed on the face under the word Garmin you can pop the face off and underneath on the right side is a reset button I held it down for 10 seconds popped the face back on and pressed the power button it came on. I hope this works for you.
Mar 20, 2009 | Garmin StreetPilot C330 GPS Receiver
2 Garmins, BOTH shut off right after they are turned on
>>>>>Posted by judyferris82 on Mar 15, 2009 "My Garmin nuvi 650 stopped keeping a charge for more than 60 seconds. It is still connected to the car charger. Will a battery replacement fix this problem? I have had this unit for 2 years."
<<<<<REPLY: In your case, the battery seems to be getting weak. You must change it.
Mar 15, 2009 | Garmin StreetPilot C330 GPS Receiver
Power dors not transfer thru the connection between the wire and unit on my c330 , it appears that a little gold wire has broken in the rubber mount.
It took a nap...
Feb 18, 2009 | Garmin StreetPilot C330 GPS Receiver
Blank Screen on Garmin C330
It took a nap...
Dec 11, 2008 | Garmin StreetPilot C330 GPS Receiver
I turned it on and it lit up and then completely died
Question: Why won't my StreetPilot c3xx power on?
Found on the Garmin web site --> Answer: If your StreetPilot does not power on, or if it turns on then turns off, you can troubleshoot the problem by resetting or charging the unit. The reset is a "soft" reset that you can perform in the car; it restores power to the unit, but it does not remove data.
To reset the unit:
  1. Place the unit in the cradle and roll it backwards slightly to lock it in place.
  2. With the key in the car ignition, turn on the unit or put it in accessory mode.
  3. On the face plate of the unit, put your thumb nail in the groove under the Garmin logo and gently pull off the face plate.
  4. With the face plate removed, press the reset button on the right side.
  5. Turn the unit back on. If the unit still doesn't power on, you may need to charge it.
To charge the unit:
  1. Using the provided USB cable, connect the device to the computer.
  2. Reset the unit (following instructions above).
  3. Keep the device connected to the computer and allow it to charge overnight (7-8 hours).
  4. After charging, unplug the unit and power it on.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 03/10/2008
Oct 05, 2008 | Garmin StreetPilot C330 GPS Receiver
Can't update software for StreetPilot C330
I have contacted Garmin several times till I got an acceptable answer. Some of the C330 receivers were sold to car rental agencies and contain software version 2.30. These units cannot be uodated. They are not reconized as a HD letter in "my computer" and mine would not accept a map update.
Dec 26, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
53 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
