Question about Admiral AAV7000A
Admiral washing machine help
My washer will fill than shuts off. I have to play with the control knob for 15 min to get it to turn back on
    Novelist:
  • 131 Answers
If it runs after playing with the knob, I'd replace the timer.
Posted on Mar 31, 2008
It won't turn on
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com Troubleshoot your Admiral Top Load Washer that has these following ... The machine will not complete cycle (fills but won'twash or agitate) I recalibrate it and it ... my washer will not startbecause of lid latch it is an admiral.
Sep 29, 2015 | Admiral Washer Control Panel Frame 35-5733...
Knob won't work
Easy check for water filling problem like yours. Unplug the power and see if water still flows into machine. If yes----your inlet valve on the washer is stuck open and needs replaced. It is the part on the washer back where your fill hoses attach to. If the water is flowing into the machine while plugged in and it stops when unplugged, you have something in the control panel sending power to that inlet valve even when the machine is off. You would now need to find out where the power is coming from. If its an electronic control washer, the main board may need replaced.
Apr 11, 2015 | Washing Machines
How do I reset washer it is stuck in fill mode but wont do any thing else it sits and hums
Might be a bad motor on the control unit. Move the knob slightly and see if unit begins to work.
Apr 03, 2015 | Admiral Washing Machines
Washing machine buzzes on spin cycle
you probably have a broken belt you hve to lay the washer on its side
Jun 21, 2012 | Admiral AAV7000A
Washer fills but will not spin and shuts off after a few seconds
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the lid switch assembly, you jump it to test it. If the lid switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Admiral AW22 Top Load Washer
Hi, What controls the water level and turns off the cold water shut-off solenoid on an Admiral washer? It sometimes sticks and floods the floor. Thanks
the water level switch (the knob that say low med. extra lg. ect) controls the water level, it probably isnt the trouble, but i suspect that the water valve (where the hoses attach)is sticking open to determine this,when it does flood unplug the machine if it continues to fill while unplugged the valve indeed is sticking
Jul 20, 2011 | Admiral Washing Machines
I have a Admiral washer that fills with water but won't agitate
turn on your washer start programme while it is filling turn of power point if water still enters mchine you have a faulty water valve.if water stops there is a problem with the water level switch or hose that connects from outer bowl to pressure switch maybe perished or split.hope this helps you.
Mar 25, 2009 | Washing Machines
Admiral top load Admiral washer
Could be the motor or belt, tilt the machine backwards and look underneath to inspect the belt, try turning by hand see if everything is free (will only freely turn in one direction only as brake acts in one direction). Check motor for rotation, remove the front panel for a look, to remove the front panel, at the seam between the front panel and lid push in a flat knife or screwdriver approx 4" in at each side to release the clips (one at each side). this will allow you to lift the top and then remove the two front panel fixing bolts 7-8mm to remove the front panel.
Mar 24, 2008 | Admiral AW22 Top Load Washer
Admiral AAV7000A Logo
69 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
