Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Sony KP-53HS30 53
I am having the same problem with my Sony. I have no picture and sound and see the 6 flashing error code. Where can I find the manual and is this something that is an easy fix. travisllee@yahoo.com
Thanks
Trav
  • Sony Master
  • 8,617 Answers
I just sent you the requested info to your email
Posted on Mar 31, 2008
  • Sonny Berry
    Sonny Berry Apr 01, 2008
    If you didnt get the link send a email to me at slinteriors@yahoo.com
No picture or sound. standby light on front panel
The light is blinking a repeating error code. Try to determine the number of blinks before a slight pause as that will be an error code. Then respond to this same post and I will assist you with diagnosing what may be causing the set not to power up.
Dec 11, 2009 | Sony KP-46WT500 46" Rear Projection...
KP-57WS520 Sony Projector - No picture
5 times blinks shows incorrect white balance (AKB) error. TV needs Screen Volts (G2) adjustment.
Take off lower front panel, find Focus Block that has 6 control knobs, adjust Screen volts of each CRT (red-green-blue) and problem will be solved.
Be Careful while working in TV.
Let me know if you have further question.
Thanks.
Dec 09, 2009 | Sony KP-57WS520 57" Rear Projection...
6 red blinking codes
Below is picture of error code table of Sony TV KP-57WS500You can check what is error 5 and 6
Oct 31, 2008 | Sony KP-57WS500 57" Rear Projection...
Six (6) blinks on the Timer/Standby led
6 blinks means lamp thermal fuse blowing, replace thermal fuse.
See here
Aug 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Error Code 5 flashes when unit shuts down
Good Day;
It sounds like the TV may have a shorted CRT, picture tube, but let's trouble shoot:
1. Unplug TV from wall.
2. Remove speaker grill, two on bottom, the screws are covered with plastic caps, right and left side on bottom next to floor.
3. Remove inner panel.
4. The blue tube is the one the right side, remove socket, with phillips driver, make sure it's not touching anything.
5. Plug and turn TV back on, if picture appears with no blue it's the tube.
6. If still shuts down, bad blue CRT driver IC.
CAUTION: Call a factory authorized service dealer to give you an estimate, if this sounds too hard.
Good Luck, Day, Big Irish.
Jun 18, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-53HS10
The problem seems to be in Secondary supply of Switching Power supply.
Mar 31, 2008 | Sony KP-53HS10 TV
Sony KP-51WS520 Stand by flashes 5 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
This means that there is something wrong with the video.
When you get this error, several IC and components concerning the video signal must be tested and eventually replaced.
Mar 13, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony KP-57HW40 Error Codes 6 & 8
ITS PROBABLY THE RED PICTURE TUB (CRT). IT LOOKS EASY TO INSTALL, BUT YOU NEED TO MAKE ADJUSTMENTS TO THE SCREEN ONCE IT IS INSTALLED. THE PART IS $3OO. TRY TO FIND SOMEONE TO INSTALL IT FOR $150 OR LESS. HERE IS A WEBSITE TO HELP YOU MAKE ADJUSTMENT IN THE FUTURE ON YOU OWN.
PRIDAH
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 10, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection Television
plug it out to reset itself and if that does not work,you will have to call a tech as the tv has a problem in its power supply an its related circuit good luck.
Apr 06, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony TV Repair
It is really hard to say what could be your problem, so let me know exactly what it is -Does your set play-and has no sound and can you go into menu to audio?let me know i will try to help you.Thank You for using FixYa and Have a Nice Day
Feb 27, 2007 | Sony KP-51WS510 51" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
87 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
