Question about HP Photosmart C6280 Printer
The copier and scanner are not working
When I try to copy or scan an error message appears indicating that the scan and copy function is not working
  • 1 more comment
  • Anonymous Apr 01, 2008
    can not log on to printer for scanning
  • Lark1973 Aug 29, 2008
    I'm unable to complete a scan. The scan begins, and I can see about one-fourth to one-third of the document in the preview screen, and then it stops.
    I've tried uninstalling and re-installing, making sure I have the latest drivers from the HP Web site, with the same results.
    The unit prints and copies with no problem -- I just can't scan a document or image into any type of file at any resolution setting.
  • Anonymous Nov 17, 2008
    wont save 2 my computer
  • 813 Answers
Hi friend
remove & reinstall u r printer driver
then after try to scan
Posted on Mar 31, 2008
Scanner error 5
The only fix that I know is to get the scanner/copier assembly(that's the assembly at the very top where the copier is) replaced.
I don't imagine that it is cheap. Get an estimate 1st.
Nov 12, 2011 | HP LaserJet 3055 All-In-One Printer
Scanner initialization error -scanner does not stop moving to right. eventually stops but will not function.
Error messages might appear during scanning. Click here to see the document which was developed to help HP customers resolve these error messages.
Regards
Riztech
Aug 23, 2010 | HP PSC 2110 Color Printer
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
HP Photosmart 3110 All-in-one - Scanner function not working
Scanning requires two-way communication between the computer and the scanner. Usually the error that you describe above indicates an issue with the USB connection. First, make sure that you are not using a USB hub. Try a new USB 2.0 (A-B) cable that is under 6' long. Try using a different USB port on the computer.
If the problem persists, check the Device Manager to see if you have a USB driver problem. (For most versions of Windows, press the Windows key + X to quickly access the menu with the Device Manager.) Expand the section labeled Universal Serial Bus controllers and look for an exclamation point or an X. Similarly check for any issues in the Devices and Printers section of the Control Panel. The All-in-One should be listed as a printer and a scanner.
I hope this helps. If you are still having problems, please add a comment with the OS version on your computer. That can help identify additional issues that could be involved.
Apr 04, 2017 | HP Photosmart 3110 All-In-One InkJet...
Hp laserjet m1522nf
Copy function was not working, says "device is busy". Message appeared on the printer screen is:"scanner error 5, turn off then on". This was done several times and message still appeared. I called 866-625-1176 and was connected with HP Technical Support and after 20 - 25 minutes of diagnostics, the technician informed me that they were sending me a new printer at no charge. I assume this meant that HP is aware of the defect and has no solution other than to replace it. The printer was only 6 months old.
Sep 05, 2008 | Office Equipment & Supplies
Hello, I have an HP OfficeJet 7310 all-in-one print/scanner/fax etc. I purchased about two years ago but don't use very often. Yesterday while I was trying to send a fax I received a loud winding-up...
I have same problem! The copy/scan function would feed the orginal from the ADF halfway and instead of making a normal loud feeding noise it made a horriable alarming sound and displayed an error message. To fix it: I waited a day or two and bang the top of the feeder cover with normal force while the original is feeding. It appeared the problem is resolved. I have no idea what the problem is, however I think if this work for few months at a time is fine by me.
Apr 12, 2008 | Office Equipment & Supplies
Hp psc 2175 all in one SCANNER PROBLEM
This is only a software issue. Reinstall the software or try installing on other system
Mar 19, 2008 | HP PSC 2175 All-In-One InkJet Printer
Scanning
I don't think it'll be able to function given it has any error u need to get rid of the error message first sorry.
Nov 28, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Scanner 3770 hardware problem
Hi, it is possible that your scanner has a transport locking lever or knob underneath which might have been keeping the carriage locked in place. Try checking and release if there is one. Hope this works for you. Pls post again how things turn up. Good luck and kind regards.
Jul 30, 2007 | HP Scanjet 3770 Flatbed Scanner
HP Photosmart C6280 Printer Logo
488 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
