Loking for part # 265871 digital module (DM2) for Infocus screenplay61md10 hi def tv
  • 8,617 Answers
We can rebuild your module for you.go to this link submit a email request and supply the make and model number as well as the part number for the module you need rebuilt and we will give you a quote for your board to be rebuilt all our rebuilt boards are fully guaranteed.
http://servicemanuals.vstore.ca/
Posted on Mar 31, 2008
6ya staff
SOURCE:
Is the harmon kardon avr 225 receiver hi def? we had a "non" hi def tv hooked to our receiver and we are replacing the tv with a hi def LED. do we need a new receiver?
It does not have any of the usual HDMI or component video jacks on the back. The highest 'def' video it supports is S-Video (standard def).
http://en.wikipedia.org/wiki/S-Video
It is NOT necessary to route video through an audio device. Your TV is the ultimate and most logical first recipient of any high def video content.
Whatever video you elect to pass through this thing is not modified in a good way if at all. You COULD just run the HiDef video straight to the TV and not have to worry about what could be happening in the excessive and unnecessary cabling that takes it for a trip through the receiver.
The receiver can still be managed by running its composite (standard def) video from the Monitor Out to a composite input of your new TV.
Likewise, no digital audio would improve from passing it through any device that just acts as a stepping stone to the receiver and ultimately your ears. That iswhy all decent A/V gear has provisions to run the signals separately to their optimum electronic end-user.
Sep 08, 2011 | Harman Kardon AVR 225 Receiver
I need to know which outlets to plug into with the cables, so I can hook it up to a Centrex CTT5103 colour TV.
you have a Dish/Sat or Cable........the cable from any one of these go to the TV (in) or if you have HI DEF.. connect it by color to component 1 (in) note the must be set on channel 3 or set to component 1if HI DEF .........you have DVD player,,,, these wires (yellow white & red) are connected to the TV AUX /Digital (in)
Apr 10, 2011 | Televison & Video
We are in Ghana we need frequency and we update to get more channel
Your flat panel TV is probably factory set to receive ATSC signals (Hi-def DIGITAL TV), whereas
Ghana may not have converted from analog TV (NTSC) yet.
Digital TV's cannot receive analog signals. I'm just guessing about whether or not Ghana supports
Hi-Def broadcasts - you'll have to check with (any) TV channel in Ghana. The Analog-to-digital
conversion is an expensive one at the broadcast end, and may not have happened yet in Ghana.
The US conversion took place by FCC mandate June 12, 2009.
There are available $65 (USD) digital-to-analog converters, but what you may need is an
analog-to-digital converter, which doesn't exist. Your Flat-panel TV amy have to wait until Ghana
begins broadcasting a Hi-Def TV channel.
For a HD antenna, a regular old rabbit ear-type antenna will do.
Oct 15, 2010 | Televison & Video
Activating HD mode
You do not activate or set the TV resolution at the TV, the signal feeding the TV has to be hi-def for the TV to show HI-DEF. TV will show what is being fed with, lo-def in = lo-def display.
Dec 09, 2009 | Sansui HDLCD1908 19 in. LCD TV
Digital ready?
Deacon J,
You will need a digital converter box OR high definition tuner for the transition. What's the difference? A converter box will only output a standard definition signal, either on channel 3 or by composite or S video cables. A high definition tuner will allow you to watch the new digital broadcasts in hi-def, assuming they are transmitted in hi definition. The converter boxes are the cheaper option and you can get a coupon from the government for a $40 rebate on the box, but I would opt for the hi-def tuner fo the better picture quality.CNET has a good write up on the transition here:
http://www.cnet.com/1990-7874_1-5108580-3.html
I did some looking and about the cheapest hi-def tuner I could find was $150, which is 3 times what a converter box would cost. I would expect the cost to fall on the tuners over time. Perhaps a converter box may be a good solution until the prices fall, if they do. The problem is that not many companies are making the tuners, as most TV's already have a hi-def tuner built in, so there isn't a big market for the add-on tuners. I hope this answers your questions.
Dec 31, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Regarding Infocus projector connection to Sony TV
the projector does not have an rf connector, so you have to have a modulator that has rf in and composite video and audio out.
Jun 17, 2008 | Office Equipment & Supplies
Hi def
No I said you dont get Hidef without a HDMI connection
Apr 02, 2008 | Toshiba TDP-S8 Multimedia Projector
Sony KP-53V80 53 in. Rear...
It's not a digital hi-def tv, so you either need a cable/sat box..or a converter once hi-def goes in and analog stops.
Mar 31, 2008 | Sony KP-53V80 53" Rear Projection...
Hi Def from dvd player
Tony, Let me ask you a silly ? as Im sure you can answer your own ?. Is your TV Hi def?? NO?? Ok Is your DVD player HI def campadable? Yes. Does your DVD player have RCA outputs for video or s video Output?? Yes. Ok Tony if your TVs not HI def how do you expect to get HI def out of it??? Use rca outputs as it is compadable. if the DVD player has no s video or RCA jacks and I've not seen one yet that didnt then your going to have to get one that does. Good Luck
Jul 30, 2006 | Hitachi 43UWX10B 43" Rear Projection...
IQB64W10W high-def problem
Your problem sounds like the digital board and probably was what the repair people said. I would suggest telling them about Tri-State Module, Inc in Evansville, IN. 800.203.7484. They have a good selection of modules for about any set and most are under $150.00 with the average being $100. They rebuild boards and all boards carry a 12 month warranty. You can also access them at www.tristatemodule.com. If they can't help try PTS in Bloomington Indiana. I use them for alot of replacement modules. Same deal as tristate. www.ptscorp.com
Oct 12, 2005 | Zenith IQB64W10W 64" Rear Projection...
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
