Question about Universal Remote Control DIRECTV Universal Remote Control
Strand Master Remote 3 in one codes
I need the codes a bush tv
  • mjccass Apr 04, 2008
    I have managed through trial and error to get the remote working with the BUSH television. I will outline briefly what I did. However I am still not sure if this is the correct procedure but it does seem to work.
    1. Switch on the Television.
    2. Hold down the "SHIFT" button on the remote for about 6 seconds until the LED glows continuously.
    3. Press the "Chapter/CH+ button on the remote. The LED will begin to blink steadily at approx 1 blink per second.
    4. Press and release slowly the "Power" button until the Television switches off. This may take some time. (I had to press and release the Power button about 120 times!!)
    5. Press the OK (middle top) button on the remote IMMEDIATELY.
    The remote should now work. Some of the functions have dual keys. For example the "Menu" function is accessed by first pressing the Shift button and then Menu. The OK function is also accessed by first pressing Shift. Pressing OK without Shift would give the mute function.
    Thanks tohttp://www.fixya.com/users/benimur for resonding to my initial request and providing very helpful information.
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Master Remote Control codes
Hi XX,
My sincerest apologies, I am not familiar with either the Strand Master 3 in 1 remote control or the Bush Television RF2185NTSIL/A.
However, a quick Google disclosed that a great many TV sets use the code 0065, 065 or 584.
Additionally, you can try 0742, 0157, 246, 263, 377, 037, 064, 065, 310, 300, 383, 399, 391, 402, 547, 292, 239, 312, 609, 322, 339, 515, 236, 389, 035, 191, 232, 245, 064, 0377, 0037, 0064, 0310, 0300, 0383, 0391, 0402, 0547, 0292, 0239, 0375, 0312, 0609, 0389 and finally 0339.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 01, 2008
robotek
  • 1512 Answers
SOURCE: Strand Master 3 in 1 Remote Control
I have looked about the place for anything to o with strand master, and found nothing. Can you check the model of the remote for me.
thanks
regards
Graeme
Posted on Apr 14, 2008
IrishDruid
  • 2712 Answers
SOURCE: Strand 3 in 1 Master Remote Control
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
prakas_3p
  • 107 Answers
SOURCE: no instruction manual or codes for strand master
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Posted on May 08, 2010
Need code for my remote control for my Bush Tv
Codes are in the remote. Finding the code depends upon knowing the "brand" of remote and whether it is universal (URC-???).
Feb 01, 2016 | Bush 42" LCD TV 1920x1080, 50 Hz, Freeview...
New bush tv cannot find code for my sky remote
Hello
Sky remote codes for Bush TV are:
246 263 377 037 064 065 310 300 383 399 391 402 547 292 239 312 609 322 339 515 236 389 035 191 232 245 288 714
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible
OK.
Jun 26, 2011 | Televison & Video
How do i tune my remote into my bush tv
Firstly you need the correct code for your television brand:
1037 or 0714 or 0037
Secondly, you need to programme the code into the remote control:
1. Press the relevant device key (e.g. TV)
2. Press and hold down the MAGIC (SETUP, or SET ) key until the light blinks twice (the light will blink once then twice)
3. Enter the code using the number keys (the light will blink twice)
Try one code at a time and test each one with various functions of the TV - Volume, Power, Channel, etc. If a code doesn't work or only partially works, try the next one.
This should be all you need to use your One-for-All remote with your bush TV.
Please rate this solution if you find it helpful. Thanks.
Oct 16, 2010 | One For All URC 7740 Remote Control
No instruction manual or codes for strand master remote 3 in 1
hi
Oct 01, 2009 | Universal Remote Control Remote Control
I need the code for a strand easy remote 8 in 1 on a toshiba tv please help
0159 0178 0109 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
Dec 16, 2008 | Radio Shack 3-in-1 Easy-to-Use Universal...
Hope that helps!
IrishDruid
Apr 01, 2008 | Televison & Video
thanks
regards
Graeme
I have a strand 3 in 1 you just need to press and hold shift/setup until the light stays on. Then press channel up. DO NOT press the on/off button but just let it cycle until the tv turns off. THEN press the ok button immediately.
Sky remote code
codes for bush are
107
031
codes for bush uk are
005
038
140
018
052
143
020
058
152
022
085
169
031
107
172
036
121
175
015
043
141
019
053
144
021
078
156
026
099
171
033
109
173
226
196
hope this helps
Dec 08, 2007 | Directed 434MHZ Remote Control
Bush tv remote code
i have a bush lcd tv 27 inch an its stuck on stand by i have an urc7740 one forall remote how can i take my tv of stand by with this remote.
Aug 26, 2007 | Televison & Video
Televison & Video Logo
1,383 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
