Question about Kenmore 66469 / 66462 / 66464 Microwave Oven
Wattages W#hat is the difference from wattages????
  • antymom Mar 31, 2008
    What is the differences with the wattages?
  • 807 Answers
The higher the wattage the faster it cooks.
Posted on Mar 31, 2008
SOURCE:
Ilve combination microwave is not heating
Don't know how handy you are but the biggest reason for microwave failure is a diode (HV) between ground and the lead to the magnatron. usually mounted low down low on the right side of the unit. Also, there are about three microswitches in the door closing latches to make sure the door is properly closed. Sometimes they come loose or fracture the mount. then of course there is the Magnatron its self. I save them from old units. They are different wattages but physically the same and simple to change. Good luck.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Feb 19, 2018 | Microwave Ovens
THE ERROR CODE E350 COMES UP WHEN THE MICROWAVE MODE IS ACTIVATED. NO MANUAL IS AVAILABLE
Don't know how handy you are but the biggest reason for microwave failure is a diode (HV) between ground and the lead to the magnatron. usually mounted low down low on the right side of the unit. Also, there are about three microswitches in the door closing latches to make sure the door is properly closed. Sometimes they come loose or fracture the mount. then of course there is the Magnatron its self. I save them from old units. They are different wattages but physically the same and simple to change. Good luck. Use Google and search on your unit and u will see the manual and error codes
Feb 18, 2018 | Microwave Ovens
I am Hamilton microwave it turns on but not heating, so can you pls tell me what is the problem?
Feb 13, 2018 | Microwave Ovens
Door shows two different wattages which is correct ?
I gues you are misintepreting something. Maybe wattage for 110V or 220W?
Take a photo and post it wth your question
Jul 03, 2015 | Tappan Microwave Ovens
What is the wattage
There are 2 different wattage's on a microwave oven.
1 The wattage a microwave oven uses from your wallsocket that is in a range from 1500 watt to 2500 watt. you can read this on the typeshield on the back of the oven.
2 The wattage the oven put in you food. ( that is also the wattage that a foodpackage or recepy mentions. it is normal in the range from 600 to 1200 watt. you have too lookup this in the manual or manufacturers website.
Mar 03, 2015 | Microwave Ovens
Stopped cooking
This is technical!!! Don't know how handy you are but the biggest reason for microwave failure is a diode (HV) between ground and the lead to the magnatron. usually mounted low down low on the right inside of the unit. Also, there are about three microswitches in the door closing latches to make sure the door is properly closed. Sometimes they come loose or fracture the mount. then of course there is the Magnatron its self. I save them from old units. They are different wattages but physically the same and simple to change. Good luck.
Jan 30, 2018 | Advent Mw912bwdk Black Built-in Microwave...
Microwave wont work
Feb 04, 2018 | Kenmore 66292 Microwave Oven
I have a sharp microwave-convection model #r-7a85. how many watts this oven needs or have thank you
800 or 1000 are standard wattages. It should say on the plate on the inside 'doorway' of your oven - that is where I find that info on my sharp microwave. It could be on the back but, like I say, normally inside the 'doorway' to the oven
Dec 27, 2009 | Sharp R-7A85 Microwave Oven
How many watts on my microwave?
Hi
The wattages of your microwave is 800 watts.
Thanks!
Jun 15, 2009 | Emerson MW8985W Microwave Oven
Microwave wattage at different power levels
Usually the output power is adjustable from 10% to 100% in 10% steps relative to the full output power rating.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Apr 15, 2008 | Panasonic NN-MX25 800 Watts Microwave Oven
Kenmore 66469 / 66462 / 66464 Microwave Oven Logo
98 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
