Question about Symbol LS2208 Handheld
Barcode cannot read a dash
I have to barcode items that will be read in an inventory management system. When I try to use CarolinaBar-E39...and enter a (-) dash it is read by the reader as a (/) slash. What can I do to make it read what I put in?
SOURCE: Enter function
Hi Lee,
It can be done by programming the scanning the 'Send Enter Key' barcode twice, from the owners manual.
eg
Scan the barcodes -
Send All Data, Send Enter Key, Send Enter Key, Save
Posted on Oct 17, 2007
  • 31 Answers
SOURCE: When i scan a barcode why do i have to push enter?
Go to http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=7188201bpdf&sliceId=&dialogID=111756507&stateId=0%200%2011492385
This is the quick start guide for the LS2208. On the first page you will see a section titled Carriage Return/Line Feed. Scan these three bar codes from top to bottom. That's it.
Posted on Jun 30, 2009
ama1226
  • 3 Answers
SOURCE: My barcode reader won't scan - light works, electricity works
bad laser needs to be sent in for repair
Posted on Dec 01, 2009
SOURCE: Microsoft Metrologic MS9520 Voyager Barcode Scanner problem
If it is using the MX009 USB Cable it wont scan with the standard configuration. You will need extra configs such as enable Rs-232 Mode, Enable Xon/Xoff handshaking etc..
These can be found on the www.Metrologic.com website which will divert you to Honeywell website
Posted on Jul 08, 2010
SOURCE: Scanner does not automatically enter barcode,
I had this problem as well, and I found the fix! Go to this site:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=7188201dpdf&sliceId=&dialogID=191796267&stateId=1%200%20191788707
It is the link to the PDF support for the scanner. It has barcodes you can scan to program the scanner to press enter or tab when it is done!
Posted on Sep 14, 2010
Have an online manual for LS4004 I000. How do I get the scanner to transmit an enter key after scanning a barcode?
try reprogrammimg, it should default after it scans an item to enter whaT WAS SCANNED
Jan 31, 2013 | Computers & Internet
Failed to load the print preview or failed to print.
You need to run the Wasp software under an Administrative account or Right click the program Icon and select run as administrator (only need to do this 1 time, not over and over again). Once the program loads, set the label printer again by clicking file at the top left and selecting Setup Label Printer. Select your label printer. Now try printing the labels again.
Jul 19, 2012 | Wasp Technologies Inventory Control...
Hi, I have restaurant pro express v 12.0. Is
You could program a key at bottom with the ON SCREEN KEYBOARD function using the TOUCH SCREEN SETUP. This will let you manually type in the item number or bar code number. One thing to note, if you do not use bar code numbers as your item numbers, you can still make this work. On your inventory screen, click on the green check box beside ALTERNATE SKU. Then type or scan the bar code and ENTER and SAVE. You now have both an item # and bar code # that will reference your items.
Nov 07, 2010 | Pc America Restaurant Pro Express
The library is using APEXII scanner to scan collection for
It might depend on your application, but I'd try downloading all the information you scanned more often than every 20K items. It's possible that you are filling up the memory in the unit and it won't accept any more.
May 21, 2010 | Compsee Apex II
MS9535 BT Bluetooth Wireless Barcode Scanner Problem
Problem with Scanner settings .you have to load default setting to scanner from Configuration guide which comes with Scanner.
First Scan the Enter /Exit Configuration then select load defaults and at last scan Enter/Exit Configuartion.
Scanner will be o.k
Jul 07, 2009 | Metrologic Instruments MS9535 VoyagerBT...
Transfer info from the digital weight scaleto quickbooks
You would need to add an criteria or the rule, like barcode length or type. Than is the the scanner able to understand which barcode should be handled by the specific rule.
Dec 03, 2008 | Symbol LS2208 Handheld
Beeps instead of reading the barcode
Hi Richiet Seems liek it has not been detected into the system or has gone faulty. I would first wonder is ot a new item ? If so try reinstanning it on the system you are using, If it was an older item do the same but maybe look atthe fact that it could be faulty in both instances. YOu always have a warrenty with manufacture and by law they will have to give you full technical support on the item
Mar 07, 2007 | Datalogic D100 Handheld
Symbol LS2208 Handheld Logo
813 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
