Projection Televisions
Problem for Projection Televisions
Generic problem for all Projection Televisions
Cleaning mirrors and lenses on Sony big...
By 7351 on Mar 31, 2008
How can I clean (without calling a TV repairman) the mirrors and lenses on a Sony big-screen projection television? I had the mirror and projection lenses cleaned several years ago and it really improved the projected image quality. But, I'd like to do it myself -- that is it if the job isn't too big or risky.
Same Problem
Apr 08, 2009
-   TACHE BLEUE -   Guest
Aug 28, 2008
-   No action on my problem yet. My HD isn't as HD as it use to be. Thought it need a goo interior cleaning , but not sure how to proceed at this point. Mine's a Sony wide screen HD. Any ideas would be helpful. THX-   Guest
Jun 26, 2008
-   picture quality is bad.how do i get into the tv to clean the lens and mirrors? -   rkr724
Best Solution
posted on Sep 16, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
it's fairly easy to remove the screws on the back bottom portion of any rear-projector television. when the bottom part is removed, you will see both the mirror and the 3 lens. isopropyl alcohol or windex should do an efficient job. a soft lens rag can be found at any camera store. i'd spray the lens rag instead of the actual lens or mirror when doing this job.
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
i need the specifications for the projectors inside the 46f500 tv. i see two pictures slightly off... (More)
Answer
how do I check the IC's, cap's and fuses with a multimeter?
Answer
my TV picture is pulsing in and out during comercials and channel listings
Answer
Mitsubisu projectin tv model # 4561 I have a huge black box covering screen . I puched test button... (More)
Answer
lamp went out and after replacing it the picture quality had not been the same. All channels have a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
