I had to manually empty out a F&P 051 smartdrive 9, yesterday, when it wouldnt empty,or engage the wash cycle. I eventually stripped and cleaned everything, assembled, then re-washed the washing, this all went well but now the machine wont power up, and the washing smelt burnt - Water Pump cooked?
Ok, have you checked for power at the power point? if you have power to the machine and the display doesn't light up after you have turned the power point on then your control module is faulty. only the phase 5 models don't power up if the pump is faulty, your machine is a phase 2 with a blue control module. by the way, what part of the machine did you pull apart? i think your pump was faulty which made the control module faulty. check the pump for a burning smell. if it is burnt then i"m sure your module is too. please reply if you need more help to fix this problem.please turn off the power b4 you work on it, don"t want any accidents . good luck.
