Question about Equator EZ 3600 CEE Front Load Washer / Dryer
Equator EZ 3600 CEE Front Load won't spin to drain water
  • tyreeh May 21, 2008
    i have the same problem, any advice besides the door
    Novelist:
  • 131 Answers
Most likely, the door latch isn't functioning properly.
Posted on Mar 31, 2008
Water not draining even after reset attempts
Did you check the most obvious item - the motor and belt that spin the drum and powers the pump assembly
Sep 12, 2017 | Equator EZ 3600 CEE Front Load Washer /...
Doesnt spin y
Hi ajin 24,
The reason might be that the Drain pump can no longer pump out the water, and as such the Spin cycle can not begin.
Please look at my tip below for th fix:
ACCESS, DRAIN & CLEAN THE DRAIN FILTER...
If the Tip does not work for you, you might need to replace the Drain pump (Faulty)
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Jul 26, 2011 | Equator EZ 3600 CEE Front Load Washer /...
Water will not drain after rinse
The filter or the drain volve may be blocked with the dust particles else the motor is not functioning properly
Dec 22, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Where can I buy a new belt to my equator EZ 3600 C / B ?
You can purchase a new belt for your EZ3600C from appliance desk through their website www.appliancedesk.com and then click on shop parts.
Sep 26, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Equator Wash dial just spins
just bought this ez 3600cee it says its ventless ,but yet came with
a venting duct work why?
Nov 29, 2008 | Equator EZ 3600 CEE Front Load Washer /...
A lot of water remains in machine at end of wash cycle
The drain pump might have gone bad, check if the drain pump is making some kind of noise and also check if the drain pump is not obstructed.
You can open the coin trap on he right hand side bottom of the unit and clean the same for any blockage.
Nov 27, 2008 | Equator EZ 3600 CEE Front Load Washer /...
Washer is leaking
Hi just went through the same thing... so you can tell if it is the pump take off back support... run it through a cycle and when it drains you will notice the pump turn on and if the water is leaking from the middle of pump the housing is worn out. You can get the part from appliance desk. Equator sold all of the repair stuff to them . parts@appliancedesk.com ask for Garry don't be suprised if the part is backordered from Italy. It took me 6 weeks to get my part. Good luck happy new year
Nov 17, 2008 | Equator EZ 3600 CEE Front Load Washer /...
Leaks near filter
It may be the drain pump that is leaking, you can open the back panel of the unit and figure out if it is so by checking the drain pump for leakage just when the pump starts to work.
Oct 17, 2008 | Equator EZ 3600 CEE Front Load Washer /...
Equator EZ 3600 CEE Front Load Washer / Dryer Logo
244 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
