Question about Janome Mini Compact
Bobbin thread Gets stuck! What is retiming and how do I do it?
  • 106 Answers
Impossible to explain how to time a sewing machine you need to be shown. Basically it entails setting the needle depth then making sure the hook passes just above the eye of the needle at a set height as the needle is rising, this ensures the hook catches the upper thread. Also the hook needs to be set a specific distance from the needle. Sounds easy but sometimes it can be very difficult and fiddly job.
Posted on Mar 31, 2008
SOURCE:
Can I retime my Elna T34d myself
All the info on the machine can be gleaned from http://www.sewingnz.com/elna-lock-t34-t34d-overlocker-instruction-manual/ I am not too sure what you mean by retime. You are not suggesting that you want to reset the feed/ insert/ etc timings are you?
Oct 07, 2016 | Elna Sewing Machines
Model 4075 white sewing machine problem with thread from bobbin
1. Replace thread with good thread. (Check by holding to light to see if there is fuzz).
2. Adjust the bobbin tension. The tension on top is set to three and the bobbin tension should be equal to this amount.
3. Replace needle.
4. Check the top tension with tension foot down to see if the thread can move or does it get stuck? If it gets stuck the tension control may need adjusted or cleaned.
5. Pull the bobbin thread above the throat plate and pull on the thread. It must have some tension but not get stuck.
TENSION TENSION TENSION IS THE PROBLEM!
Sep 30, 2016 | White Sewing Sewing Machines
Top thread not picking up bobbin thread
try changing your needle and make sure the flat side is toward the back of the machine. If that does not work then it will have to be retimed
Feb 21, 2014 | Brother Sewing Machines
Necchi serger pl1036 hand wheel screw keeps falling out
Try some removable thread locker on the screw. Then retime.
Sep 13, 2012 | Necchi Sewing Machines
Elna 9000 bobbin problem
try changing the needle,,make sure the needle & thread & fabric are correct for each other
make sure the bobbin is turned the right way
it's also possible that when the needle gets jammed or broken that the machine can become out of time
and would have to be retimed at a sewing machine shop
Apr 01, 2012 | Elna Sewing Machines
Needle stuck
the machine is out of time & will have to be retimed at a sewing machine shop
Mar 20, 2012 | Singer Sewing Machines
I have a 513 machine the bobbin thread wont let the needle pick up the thread.
it is very possible that the machine could be out of time & it would have to be retimed at a sewing machine shop
Feb 26, 2012 | Sewing Machines
Janome Mini Compact Logo
175 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
