Computer will not see wireless keybroad and mouse in usb port on turn on pc
  • 813 Answers
Hi friend
u have to reset ur mouse & keybord then its dectec
Posted on Mar 31, 2008
The mouse cursor on my laptop wandering without control?
This is what they call device interference, You might have to many wireless devices connected to a single USB port on your PC. Sometimes its a struggle between keyboard and mouse both wireless. Solution would be to limit the wireless devices to certain USB ports. For ex: plug the wireless keyboard to opposite USB port from the wireless mouse, vise versa. If you are using a multi-port USB connector, unplug the mouse from the multi-port and plug it to a single USB port on the PC.
Oct 20, 2014 | Sony VAIO Computers & Internet
How do I connect a microsoft wireless moblie mouse 3000 to my laptop?
Press the button on the back of the mouse to free the battery cover on top.
Remove the battery cover and put the supplied AA battery into the mouse.
Replace the battery cover.
Insert the wireless USB dongle into a USB port on the laptop or desktop computer.
Move the mouse and watch your computer screen.
Confirm that the mouse is connected by making the cursor move.
Hope this helps
Sep 26, 2012 | Microsoft Wireless Mobile Mouse 3000
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
How do i connect my hp wireless mouse to the computer
The first step is to install its driver, after taht you can connect the wireless dongle into a free USB port of your computer, then put the batteries inside the mouse and turn it on, in the most of cases, the wireless dongle and mouse sinchronize automatically, if they don't, there's a small botton in both devices press it in each one to synchronize them manually.
Feb 25, 2011 | HP Wireless Optical Mouse
Plz help me i want connect wire less keybroad and mouse thnksvjtawale2gmail.com
There are 4 possible ways in my awareness...
Method 1: Resynchronize your device with the receiver To resynchronize the mouse or the keyboard with the receiver, follow these steps. Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put any other wireless keyboards and mouse at least 6 feet away.
  1. Press the button on the receiver, and then verify that the light on the receiver starts to blink.
    Note Some newer Microsoft devices are permanently bound to their receiver and cannot be reset. If your device does not have a button, skip to Method 2.
  2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen. Otherwise, go to the next step.
  3. Press and release the Connect Channel button on the bottom of the mouse or the keyboard.
  4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
  5. For the Wireless Notebook mouse: This issue can occur if the micro-switch on the bottom of the mouse is not released. Use a pin or a pen to try to release the button if it is depressed.
The following example shows the buttons to push to synchronize a wireless hardware device:
Receiver Bottom of the mouse: The connect channel button Different kind of receiver Collapse this imageExpand this image 838398_receiver.jpg Collapse this imageExpand this image 838398_mouse_bottom.jpg Collapse this imageExpand this image 838398_portable_receiver.jpg Method 2: Try different portsTo determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse. USB keyboard and USB mouseIf the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer. PS/2 devices Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device into the PS/2 port while the computer is running.If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations:
  • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that was included with the computer.
  • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that was included with the computer.
If you have to change your configuration, shut down the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection. PS/2 keyboard and USB mouseIf you are using a wireless mouse with a USB connector and a PS/2 keyboard, verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer. Method 3: Reinsert the batteries or install fresh batteriesBoth the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. Remove the batteries, and then insert them again. If the problem persists, install a fresh set of batteries in the device that you are having problems with. Method 4: Check for interferenceItems such as wireless routers, radios, cell phones, desktop fans, fluorescent lights, and large metal objects like computer cases and metal furniture may interfere with the signal of the keyboard. Try to keep such items away from the keyboard, and check the behavior of the keyboard.
Do not put the mouse or the receiver near any electrical devices, especially transmitters such as cordless or cellular telephones or other wireless mouse devices or receivers. A distance of at least 8 to 12 inches is recommended. Do not put the mouse or the receiver on metallic surfaces or objects, especially long metallic rails or cables. We recommend that you keep the mouse and the keyboard a minimum of 3 feet from metallic objects.
Nov 21, 2010 | Computers & Internet
My acer mouse model number mg-0919 stops working after about 2 minutes. I have to turn the mouse off then back on. This happens constantly. What is going on? Is it defective? My mouse is under...
I had the same problem. This mouse came with my Acer Revo which was still under warranty. Tech support basically says to check the obvious (batteries, USB connection, RF interference). Their obviously canned answer goes on to detail a manual reconnect procedure that does not apply to this model. And when all else fails, get a new mouse.
This is what Acer tech support emailed me:
If you are experiencing issues with your wireless mouse not working properly, perform the following steps to troubleshoot the wireless mouse.
1) Ensure that the receiver is 8-inches from other electrical devices. Avoid placing the cordless devices on metallic surfaces.
2) Verify that the USB connector from the receiver is properly plugged into a USB port on the computer. Try plugging the receiver into a different USB port to ensure that the USB port is working properly.
3) Remove the batteries and then reinsert the batteries into the mouse, making sure that the battery polarities are correct.
4) Test the batteries to ensure that they still have a charge.
5) Try the manual connect procedure.
Manual connect procedure:
1) Press and release the Connect button on the receiver.
2) Within 30 seconds, press and release the Connect button on the mouse.
If the issue persists, we can replace your computer's wireless mouse.
We will ship the new wireless mouse within 3-5 business days.
Before placing an order for wireless mouse we would like to confirm the following.
1) Complete shipping address:
2) email address:
3) phone number:
In order to place an order for wireless mouse, the computer must be registered.
Oct 06, 2010 | Acer Aspire One PC Notebook
Took aprt to clean because its been overheating, figured out the keyboard but now my mouse isnt working, suggestions??
I'm assuming you're using an external USB mouse, either wired or wireless (correct me if I'm wrong). Does the mouse work if you plug it into another USB port on the computer (or on another computer)? If so, it's probably that particular port that's bad, otherwise it's either the mouse or, if it's a wireless mouse, the USB receiver.
Jun 18, 2010 | Toshiba Satellite L555D-S7910 Notebook
My case logic optical mouse will not link up
Is this a wired or wireless mouse?
If this is a wired mouse, try connecting it into different USB port or different computer so that you would know if there's a problem with the USB ports or with the computer or with the mouse.
If this is wireless, try the following:
1. Replace the batteries of the mouse.
2. Make sure that the mouse is turned ON.
3. Try connecting the USB wireless adapter of the mouse into different USB ports.
4. Connect also the adapter into different computer.
5. Make sure that there's no interference between the adapter and the mouse such as wireless phones, cell phones and other wireless devices.
Wireless mouse, cordless phones and cellphones are all running at 2.4Ghz frequency, so if there's a wireless device that's running on the same wireless freq, then it would interfere with the mouse that would cause the mouse not to work.
If same problem occurs after checking everything, then contact the manufacturer of the mouse for RMA (repair).
Have a great day!
Sep 21, 2009 | Case Logic Computers & Internet
The mouse keeps becoming unresponsive and turning off at random
What type of mouse is it? Wireless or wired USB mouse?
If it's wireless, replace the battery with new one or you may try connecting the USB wireless adapter (that came with the mouse) into another USB ports of the computer.
If it's a wired mouse, try connecting it into another USB ports of the computer. Or you may use it with another computer just to isolate the problem. If you would get the same problem even after connecting it into another computer, then I could say that the mouse needs repair.
Hope this helps!
Aug 21, 2009 | Logitech Computers & Internet
What is the difference between mouse connected to mouse port and mouse connected to usb port ?
Nothing other than the port that they plug into. New mice will typically use USB ports and older mice typically use a PS/2 port. Careful buying a new PC or Mouse, make sure that your computer has the port that is needed for the Mouse to plug into.
Please rate, thanks.
Mar 09, 2009 | Logitech Wireless Optical Mouse...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
