Question about Ovens
Hotpoint fan oven motor removal - Fixed!
I just wanted to let you know that I have just replaced the faulty fan motor in my oven. The old one came out as per your advice. I picked up the new motor this morning. No trouble installing the new motor, the whole job done in about 30 mins. I just wanted to give you the feed back and thank you again for the advice. 'Till next appliance failure........... Thanks.
  • raesinclair9 Nov 17, 2008
    hotpoint BS11P oven fan motor removal i am having trouble trying to remove the nut in the centre of fan and removal of fan blade can you help
  • 30 Answers
No problem glad to help you
Posted on Apr 01, 2008
The main oven fan in Hotpoint BD32B is sticking (tries to rotate but goes slow and stops). I need to either re-lubricate the existing fan or replace it. How do I remove the fan?
Remove the cover at the rear of the oven compartment, then holding the fan blade with one hand, undo the nut holding the fan on, it is a left hand thread, so turn the nut clockwise as though you were tightening it.
To remove the motor itself you will have to undo 3 screws securing the fan motor from inside the oven compartment, then remove the outer rear cover of oven to remove the motor.
May 10, 2011 | Ovens
Fan in main oven does not come on when oven is switched on,there is a delay of sometimes up to fifteen minutes oven has often reached desired temp from element at back of oven without fan operating. When ...
The fan motor is obviously faulty, the only real solution is to fit a new fan, if you do not, then the element is in danger of burning out, do not delay replacing the fan motor.
Nov 06, 2010 | Hotpoint Ovens
Hotpoint UD47 electric oven not hot enough
For all Free appliance repair videos visit our VIDEO TUTORIALS
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 13, 2010 | Ovens
Fan assisted oven is not working it is not heating up I dont think the fan is working can this be repaired the oven is over six years old
Generally speaking, they can be repaired.
If both the fan and the heating element are not working, then it could be a faulty control switch.
If it is only the fan that is not working, then it could be a faulty fan.
This and the element are usually located at the rear of the oven compartment, behind a removeable cover.
Hope this helps.
Dec 28, 2009 | Hotpoint Ovens
Hotpoint BD32 element not working, How can I check if it is a faulty element
Assuming you are talking about the fan oven element, you should be able to feel heat from it , if you are not sure it is working, then you need to remove the rear cover of oven to expose the fan and the element, run it for a couple of minutes, then feel if it is hot, if not, it needs to be replaced.
Hope this helps.
Nov 27, 2009 | Hotpoint Ovens
My oven wont heat up light and fan work I have visualy checked the element and it looks ok but not sure how do you know/test,if ok what else could it be hotpoint DY46
Even though the element look's o/k, it is more than likely faulty, more so if the fan is working o/k.
The only 100% test to make sure if it is faulty, is to test it with a meter.
In my experience I would advise you to replace the element.
Please rate my solution.
Nov 03, 2009 | Hotpoint DY46 Style Line Stainless Steel...
The oven switches on, and fan spins but doesn't heat up!
If the oven fan is working o/k, then it is probably the oven element that is faulty, and you will need to replace it.
Jul 16, 2009 | Hotpoint SY36 Style Line Stainless Steel...
Oven not getting hot
The fan oven element needs to be replaced in the Hotpoint 6150 cooker.
Access is by removing the inner rear cover of the oven, there you will see the element.
Replace with a new one.
It is possible the base element is faulty in the top oven of the Hotpoint EW95,
The other possibility is that the high speed grill element is only part working.You need to check both these elements.
If the fan is working o/k in the main oven , but not getting hot, then you need to replace the element.
If it does heat, then it could be a faulty thermostat or possibly selector switch.
Unless you have a good working knowledge of electrics and know how to use a meter, then I would suggest you call some one in.
Plz rate my solution
Dec 26, 2008 | Ovens
Yes, it can be fixed quite simply.
First check that the fan is not catching the cover or grill, if it is not remove panel covering fan and see if the fan blade is loose,on the shaft, they are usually held on by a left handed nut., so to tighten go the oppisite way to what you normally do, if that does not cure it, then your only solution is to replace the fan motor complete.
Plz rate my solution.
Thanks, and a merry xmas.
Dec 21, 2008 | Ovens
Hotpoint BU62 bouble oven
sounds like the bott oven element has gone, or faulty thermostat.
Dec 09, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Ovens Logo
129 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
