Clear Parental Lock on Aiwa A2010
Dear all,
is anyone able to help me to clear the Parental Lock on TV Aiwa A2010 since my maid accidentally locked it? I tried 0000, 1111, 2222, 3333, 4444, 5555, 6666, 7777, 8888, and 9999 but it is no luck.
Thank you in advance.
Cheers.
hi there!
i think we accidentally "child lock" our tv too... the model is TV-CN203NH... please help....
    Problem Solver:
  • 5 Answers
try 0711
good luck,
joe
Posted on Mar 31, 2008
SOURCE:
Child lock on in LC-T32HV
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Feb 26, 2013 | Televison & Video
I have accidentally locked my microwave oven (profile performance convection oven). I was cleaning the front. Can you tell me what to do?
Got you covered. Here you go:
Microwave - Explanation of the Child Lock Out Feature
Many microwave control panels can be locked to prevent accidental use or access by children.
There are two different ways to lock the control panel:
1. Press and hold the CLEAR/OFF pad for 3 seconds. The display will show "LOCK" and then revert to the time of day.
A small "L" will appear in the corner of the display as a reminder that the control panel is locked. If anyone tries to use the microwave, the display will show "LOCK".
2. On some models, press and hold the 5 and 7 pads simultaneously for 3 seconds.
To unlock the control: Repeat the procedure which was used to lock the control. (Press and hold the CLEAR/OFF pad for about 3 seconds or hold the 5 and 7 pad simultaneously for 3 seconds.)
That info is from GE
Hope that does the trick.
Regards, Farmerbear at FixYa.com
Sep 13, 2010 | General Electric Microwave Oven
Parental code lock sony kp51w5500 reset /or clear it?
If you lost password of parental code then put 4357 and press Ok
This will clear old pass word and type new password.
Jan 30, 2009 | Sony KV-32FS13 TV
Wont turn on
You will need to do a hard reset on the TV. Unplug the TV for 5 hours. This should clear any sofe codes set on the TV. Then plug it back in and turn it on. This should work.
Apr 06, 2008 | RCA 20F512T 20" TV
Parental control lock
Here is the user manual, check page # 40 on how to clear the secret code.
Mar 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
32 inch R.C.A T.V
FPA lock stands for Front Panel Access lock similar to Parental Control/Child lock - it indicates that the buttons on the front of the TV are locked so that it cannot be operated accidentally by young children.
You would need to use the remote to deactivate this security feature. Normally, you would go into the Parental Controls menu and turn off the FPA lock.
If for some reason a password was used, then you would have to enter that password since without it you can't get into the Parental Controls menu.
On some versions, you can press "Menu" on the front panel and "Vol -" on the remote simultaneously for 3 seconds to clear the password. in others, it would require that you press and hold at the same time the Vol < button on the front panel and CLEAR button of the remote control for about 5sec. You would need to enter a new password the next time you access the Parental Control Menu.
Usually, steps involve are explained better in the user's manual which is available at the RCA (Support) website. You would need to enter the exact model number of your RCA TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 25, 2008 | Televison & Video
If you have your customer users manual, you should find the " back door code " to reprogram the parental code. If you don't have your manual you may want to downl;aod one. Service Manuals, Parts Catalogue, Schematics, Circuits diagrams.
Check this web sight and you can download a manual. It does cost on this sight. You may also want to search the internet for other sights that possibly don't charge. I hope this has helped.
Have a great day
Ed
NC Electronics
Mills, Wyoming
Feb 18, 2008 | Televison & Video
Unlocking the parental control
my jensen ts2750j screen turned blue and a red lock is in the corner... how do i get it off
Nov 06, 2007 | Jensen TS2750J TV
Piece of [email protected]#t!
Sounds like you  accidentally "set" the parental lock while you were sleeping.
Try this trick: (may or may not work)
aim the remote at the TV "IR sensor", hold down "display button" on the remote for 10 seconds to erase or clear the password.
"IF" this works go into the menu and "TURN OFF" parental control.
Oct 20, 2007 | Akai CTD-1390 TV
Parental Control Locked
for an unknown passwrod try, go to parental control in menu then push mute,pisplay,clear,reset buttons in sequence. you may need to borrow a friends remote to do this. once in you can change your setting. good luck
Nov 12, 2006 | GE 19GT317 19" TV
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
