Question about Sony XM-2200GTX Car Audio Amplifier
Amp kills battery
Installed new Sony Amp to Chevy S-10. It killed the battery and alternator. Went to dealer to re-install, same problem. The audio dealer says it may be an internal problem with the amp.
Any thoughts??
  • 88 Answers
In first are you sure that the connectics are correct?? to plug your amplifier to your electric system on your car you have to plug the positive (Big Red) to the positive battery via a fuse breaker, the ground(Black) must be connect to the car frame and it has to be shortly, and the last connection blue must be connect to your switched ouptput on your radio.
If this are correct you have to use an amperemeter to follow your leak, for this you have to go to a electrical car specialist. ;)
Posted on Mar 31, 2008
08 lancer battery keeps going dead tried 3 new batteries installed,had new belts installed as per recall,alternator checks out
Based upon what you have said, it would seem that you have something that is causing a continuous battery drain. Have you added any new electronics to the vehicle that may have accidentally been wired up to a constant hot source instead of one that is controlled by the ignition switch? Many enthusiasts accidentally install stereo amps directly to hot and find they never shut off, killing the battery. If you are skilled at electronic troubleshooting, you may be able to track down a wiring problem yourself. I will warn you that many repair shops will attempt to diagnose your problem, but few are trained to do it efficiently. If you decide to pay a pro to fix it, go to an Auto Electric specialist. They charge more per hour, but will take far fewer hours to locate and repair the problem than the corner mechanic.
Mar 28, 2015 | Mitsubishi Lancer 08 2008
2000 Ford Ranger is killing alternators immediately after install
the best way to test an alternator is with a load test-partstores dont do that--battery may still have a bad cell even tho it tested good--an alternator can burn up charging a completely dead batt--make sure batt reads at 12.6volts and no less-----if it reads say at 12.3 its only 50% charged!
Sep 18, 2014 | Ford Ranger Cars & Trucks
Why does my 92 plymouth colt vista keeps killing alternators?
1 may be alternator amp is low and load is high
2 alternator main +B to battery wire resistance to high
May 23, 2014 | 1993 Plymouth Colt Vista
2002 chevy malibu abs light & battery light on
-Sounds like the alternator no produce enough power.
-Start the car and let it runs for 10 minutes to temperature then check voltage at battery. You should get 14.5 volt or +/-. It less then
13 volts. the problem is the alternator. Replace it or rebuild.
Good Luck.
Mai
Apr 15, 2014 | 2002 Chevrolet Malibu
Chevy tracker alternator
Sounds like a bad connection or a bad battery cable. Are the battery cables clean and tight on both ends ?
Yes the engine should crank if the battery is charged no matter what condition the alternator is in.
Feb 11, 2014 | Cars & Trucks
Some one put the jumper cables on wrong and they were smoking now the van wont stay running
If you mis installed the jumpers you probably killed the alternator and burn up the diodes. When the alternator dies the car will only run for a short while off the battery and then quit running altogether. Check to make sure you have a working alternator and a good battery.
Nov 04, 2013 | AMP Fuse Wiring Panel
3.1 L rebuilt motor with 5000 on it. Charging system just dropping below 12 volts. Installed new battery yesterday, and installed a new alternator today. Still have same problem. Going to check wiring...
If charging below 12v most likely culprit is the alternator.You can check the wiring to that and if you have power at the main wire and at the pigtail most likely the alt went bad.
Aug 15, 2010 | 1996 Oldsmobile Cutlass Ciera
Will it kill my battery? I want to install this amp and a 12 inch subwoofer but im scared it might kill my battery.
nope you good for up to 1000 watts RMS anything above that you will need battery and alternator up grad
Apr 01, 2010 | Kenwood KAC-7202 Car Audio Amplifier
Installed a new gas pump. can't find the kill
dealer only immobilisor cut in ,encrypted software
Dec 24, 2009 | 2005 Suzuki Grand Vitara
Something killing new battery & alternator in 1987 Ford Ranger
Well , The vehicle could have several problems. The vehicle needs to be scanned for codes. The electrical system has an open circuit. The open circuit can be a window switch , door switch , head light switch , a radio amp. or relay. There are so many possibilities that a very experienced mechanic is going to have to trace the wiring harness and check for power and resistance . Hopefully a code can be pulled to lead him in the right directions.
You have to make sure all the tail light bulbs are correctly installed and all the fuse installed are the correct type. The vehicle could have an open in the ignition switch and staying on all the time even with the key out and the engine off. I hope this information helps but to be honest there is no easy fix to the electrical system in this situation.
Good Luck
Mar 15, 2009 | 1987 Ford Ranger
Sony XM-2200GTX Car Audio Amplifier Logo
65 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
