Question about Nokia 6126 Cellular Phone
Back light When I open my phone, the screen stays dark and my keys don't light up. Everything in the phone still works because I can barley see the screen and I can acsess the menus. It is all just really dark.
Are you talking about the Nokia 6126? i have the same problem with mine and i don't see any pin or chip near the screen. do i have to take back part of phone apart to access what your talking about?
Posted on May 17, 2008
  • 983 Answers
If you mean that only the backlight is not working then this may have happened when you opened the handset you didnt place all correctly ...
just open it again and near by screen there will be a pin or chip which must touch the board to get backlight ... so i think that might not be touching the board ...
so open it and make it touch the board ...
you will get the backlight...
your problem is minor one you can solve it by your self ...
this has happened due so loose conntact inside ....
Posted on Mar 31, 2008
SOURCE:
My htc has a dark screen and still works and by dark i mean you can barley see any thing but sometimes the screen goes back to normal light
Is your phone a smart phone?? Does it have something called ambient light sensor (light sensor).??? Check your phone manual. If that is the case then you can turn it off. Ambient light sensor is a function that senses the light outside and automatically adjust the brightness of the screen. But sometimes it goofes up. So you can go to settings> display settings> brightness> if it is auto then turn it to manual as per your convenience. Again depending on your phone model the settings may vary. I hope this helps.
Jan 17, 2014 | HTC explorer
Screen comes on then goes dark , turn it back off and same thing comes on and then goes dark you can barley make out imagies on screen
Most monitors failures are caused by failed capacitors in the power supply/Inverter board, you need to open it up and inspect for caps with bulging top/seal, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you find inside so we can guide you further.
Mar 18, 2010 | Computers & Internet
Dark Screen
The back light is bad in your monitor. This is the light source that gives light to the image on your screen so that you can see it. This is a common thing to go wrong with a laptop. You can take it to someone to be repaired or if you are handy you can buy the part and replace it yourself.
Jan 18, 2009 | HP Compaq Presario 2200 Notebook
Unable to see the pictures because screen is dark ( Kodak C713)
Sounds like a back lighting issue if it worth it to you, you can have it serviced. You can also purchase a camera that for less then you paid for that one and it will be better and new with a warranty.
Keep me posted.
Thanks,
Lee
Jun 28, 2008 | Kodak EasyShare C613 Digital Camera
Nokia 6126 Screen problem
i have to say, the same thing happened to both of my nokia 6126's.
Jun 04, 2008 | Nokia 6126 Cellular Phone
Dark screen
go to your dispaly setings and check on the contrast and ilumination, if they are low, increase them and the screen will be bright
May 16, 2008 | Nokia 6133 Cellular Phone
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
Tips:
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Motorola Razr V3 display problem
Solution this same thing happened to me - cause LCD screen going out = it's weak and thats the sign that it is giving up. To Temporiley to keep it on: take the battery out and back cover of battery off place phone in ICE section of Freezer ( NOT IN THE ICE )by the area where it gets cold leave it there for 10-minutes, then take it out after 10-minutes wipe everything up put the battery back on and restart phone & wah'la it's working....
Aug 14, 2007 | Motorola Mobility RAZR V3
Nokia 6126 Cellular Phone Logo
169 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
