Question about Denon AVR-1601 Receiver
Still won't stay powered up
Replaced the 4 resistors, same problem, any other tips? would you know where I could get schematics for this?
thanks again,
Jesse
  • RichieHndrsn May 12, 2008
    Receiver keeps shutting itself off.. after powering up !
  • StaceyK Jun 02, 2008
    when I go to power on my receiver, it powers up momentarily, but the light behind the power button blinks a few times then everything shuts down.
    Genius:
  • 1,694 Answers
Www.retrevo.com ....................T.
Posted on Apr 01, 2008
SOURCE:
LG crt tv 21fs4rge-TS resistor R407 burnt i don't know the value
A burned out resistor means too much power has flowed and burned it out.
you need a schematic to find the resistor value but also what other parts have blown as I can guarantee just replacing the resistor would just mean another burned out resistor.
Jun 16, 2018 | LG Televison & Video
When system is turned on, the subwoofer light comes on and then goes out.
Hello!!!
Just check out the cables connected to the woofer first... Guess its an electronic issue ..
Jan 08, 2008 | JVC TH-C60 System
I have a dolphin cleaner that is not working. The power supply voltage drops from 37 VDC to about 4 VDC when the cleaner is plugged in. It previously had a severed power cable that was repaired. I saw a...
The new PCB you purchased should take care of it. If you need assistance connecting the new part or the unit continues to give you trouble please contact us directly or add a comment here.
John
Jan 24, 2011 | Smart Pool Inc Dolphin Diagnostic...
RE: arver Sunfire Super Junior subwoofer. In attempting repair, I found Q12 shorted, gate to source(not to drain!), and F1 open. After replacing with exact cmpnts, operation returned to normal, however,...
is that resistor in the line to q12 ? if so it should be in the spec sheet for that device. if you don't have the spec sheet then let me know what q12 part number is.
Nov 12, 2009 | Audio Players & Recorders
Samsung pcl5414r power resistors and pico fuses??
Hi again and welcome back to FixYa,
Appreciate the direct "Ask Me'.
Based on your original post, only the STK ICs were replaced. Presumably 392-040, the surrounding resistors and pico fuses could very well have been affected as well. Depending on the board revision (pls confirm location numbering on the actual board), the resistors could be:
RZ104 -RZ106 - 270 Ohm 1/2watt
RZ133-RZ135 - 27K Ohm 1/16 watt
RZ136 & RZ138 - 3.3K Ohm 1/8 watt
RZ146 and RZ147 - 3.9 Ohm 2 watt
RZ148 and RZ149 - 150 Ohm 2 watt
while the pico fuses would look like the image below.
Good luck and Thank you for using FixYa.
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Info on the rca d52w15
well i can't get the schematic free
sorry i just don't have that one yet
, but there are some tips and a schematic for sale
here is the tip area , you can also ask here , just don't know how long before they get to you
but here is one of the tips for your tv http://www.freelists.org/archives/techassist/12-2005/msg00321.html
here is where you can buy your chassis schematic
http://www.electronicsrepair.net/scemes.html
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence
http://home.comcast.net/~dande76530/ConvergenceOutSchematiics.pdf
http://www.servicemanuals.net/results.aspx?type=SM&brand=15&model=AV-48WP74
Dec 17, 2007 | JVC AV-48WP74 48" Rear Projection...
Burnt resistors
Researching resistors---
What caused the resistors to burn?? Have you already fixed
that? If so, what exactly was it ???   let me know...T.
Oct 18, 2007 | Philips 60PP9352 60" Rear Projection...
Weak reception, broken surface mount component
You can not find any schematics for the Magellans.  The schematics are classified.  Even when repairing GPS's for Magellan we didn't receive full schematics.  If your talking about the RF cable connector on the I/O Board (the board attached to the rear housing), then it's an easy solder fix.  For the capacitor/resistor:  I'm not sure where you found the capacitor origin, but if it's black with four legs coming off and parallel with the IC then tell me and I'll msg you back the rest.
Oct 09, 2007 | Magellan RoadMate 700 GPS Receiver
Denon AVR-1601 Receiver Logo
298 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
