Question about Maytag Neptune MDE5500AY Electric Dryer
Belt Re-assembly Help! :) I have fixed the problem, but can't figure out how to get the belt back on my Neptune. Any diagrams out there? My Motor pulley is on the far left and the Idler pulley is closer to the center and below the motor pulley (from looking from the front of the machine). I have taken a picture I am happy to upload or send if that helps. Thanks!
  • HandySandy Apr 01, 2008
    I appreciate your help. I got it all put back together and it looked quite promising. The squeaky noise was gone, it purred like a kitten. However, a burning smell that wasn't there before I worked my magic is now present. :(
    Sadly, my husband thinks it is time for me to give in and call the repairman.
    Shoot-I was so close! :)
    Well the repairman can't come for 2 more days and I am willing to figure this out with your help.
    Tell me more about the motor pulley. I did get the belt around the motor pulley and then pulled in the idler pulley and it has great tension and looks to run just fine, but then the burning starts. If this is an easy fix I would just assume keep my money in my pocket! :)
If the belt is on the motor shaft rather than on the pulley, you will get a burning smell.
Posted on Apr 01, 2008
    Novelist:
  • 131 Answers
If you have a really old dryer (not a neptune), and if the idler pulley is about 4-in diameter you have chosen the hardest dryer to replace a belt on. There is a diagram on the bag your new belt came in. The door in the back of the dryer will be helpful. The tricky part about this one is that the fabric side of the belt goes against the basket drum.
A Neptune belt is easier, but can still be tricky.
First, put the drum in position against the back wall; but without the front supporting ring. The rubber side goes aginst the drum. Line up the new belt on the drum according to the marks left by the old belt.
Reach under the drum and match up the belt to its position on the motor pulley. Lift the idler pulley up until you can slide the belt onto it. Gently release the belt and idler pulley. Check to see if it stayed in position.
Carefully replace the support ring and install the four screws holding it in position. Slowly rotate the drum counter-clockwise about two full turns to better align the belt on the drum before restarting the machine.
Posted on Mar 31, 2008
Belt deck assembly
Are you still looking for that belt diagram..? Is this for the motor to trans (which is pretty simple) or the belt for the deck..? Couldn't find a diagram so hope my drawing comes out right.. This is for the "deck belt" routing..!!!
Back of mower is up here on the top..
Left pulley (O\ /O) Right pulley
.......Tension \ \@/ / Pulley
.............Engine \ @ / Pulley
Front of mower here, where the motor is..
Main thing is, you take the belt from BETWEEN the right & left pulleys, pull it down and around the tension pulley..
Hope this helps.. Think I have the same Sentinel..
Jun 28, 2013 | Garden
Maytag Neptune Drying Center MCE8000AYQ Why does it not tumble?
I would start at a belt. Most cities have a do it your self appliance store, they can order you the part and ship it to your door or you can pick it up. Some Belts are as low as $16. Before condemning it is worth the gamble. Before Disassembing the unit go to U tube search out your dryer there should be an instructional video on how to replace it. Also pay attention to how the current belt is fed. I take a picture with my phone or diagram it. It helps especially if you get called away from the project. Hope this helps
Jun 21, 2013 | Maytag Neptune MCE8000AY Electric Dryer
How to replace the belt on the Maytag Neptune FAV6800AAW?
See if my Clutch Fix post will help. I also have links to Service Manual which will be big help. The drive belt can be walked on the Clutch Pulley but it is a very snug fit even with the drive belt tension bolt loosened. Watch you fingers as you walk the drive belt onto the clutch pulley….Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
ANt diagram of how the belt goes on the Maytag
pull the loop on the bottom of the tumbler once you have it warped around and hanging free
pull that loop twords the motor under the idler pully
both side of the loop
pull the loop twords the motor hub, you may need to left the idler pully to gain a liitle slack
once on the motor let go of the idler and it should tighten the belt
Oct 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I need the diagram for the belt on a Maytag MD-6 Neptune Dryer. I just need to get the belt back on the tensioner.
Go to repairclinic.com and click on the "Repair Help" link. On the following page, look for the "Dryer Belt Diagrams" link under the Special Features section. Scroll down to Maytag (diagram E). I hope this helps you.
Aug 11, 2009 | Maytag Neptune MDE4000 Electric Dryer
Placrment of belt
THIS ONE IS TOUGH PUT THE BELT AROUND THE DRUM FIRST THRU THE REAR OF THE UNIT PUT THE BELT AROUND THE MOTOR PULLEY LOOK CAREFULLY AND THERE SHOULD BE WHAT THEY CALL A TENTIONER PULLEY THIS TENTIONER SHOULD GO ON THE BACK SIDE OF THE BELT THIS IS GOING TO BE TOUGH, THEY DON'T GIVE A WHOLE LOT OF ROOM FOR THIS
Aug 09, 2009 | Dryers
Maytag LDE412 dryer.
Here is a link to the internal diagrams of your model.you can choose among the parts just in case.Good luck.Please do post comments and rate my answer.Thank you for contacting fixya.
LDE412 internal diagrams
Jan 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Belt came loose
BELTS DON'T JUST FALL OFF THERE MUST BE AN UNDER LYING PROBLEM.WHEN YOU FIGURE THAT OUT TO PUT THE BELT ON GET ON YOUR HANDS AND KNEES
REACH IN ONE ARM ON EACH SIDE UNDERNEATH THE DRUM WITH YOUR RIGHT HAND GRAB THE BELT (BE SURE ITS NOT TWISTED) WRAP IT AROUNG THE MOTOR PULLEY.
HOLD IT THERE, NOW WITH THE LEFT HAND PUSH THE TENSIONER PULLEY TOWARDS THE MOTOR
THE BELT SHOULD GO OVER THE MOTOR PULLEY FROM THE RIGHT SIDE. SO IF HOOKED UP CORECTLY THE BELT WILL GO DOWN THE RIGHT SIDE OF THE TUB-AROUND THE LEFT SIDE OF THE TENSIONER PULLEY TO THE RIGHT SIDE OF THE MOTOR PULLEY THEN BACK UP THE LEFT SIDE OF THE DRUM
GOOD LUCK=)
Feb 20, 2008 | Maytag Neptune MDE5500AY Electric Dryer
I CAN'T SEEM TO INSTALL A NEW UB8 BELT
  1. Remove the lower plate
  2. Carefully lift up on the agitator assembly until it clears both sides of the nozzle housing.
  3. Remove the belt from the motor shaft by sliding it off between the end of the shaft and the nozzle housing.
3.4.2 Installation
  1. Place the belt around the motor shaft.
  2. Start the new agitator assembly back into the nozzle housing by placing the side opposite the belt partially into the slot. This will hold the agitator in place and leave both hands free to place enough tension on the belt to allow that side of the agitator to return to the nozzle housing slot.
  3. Place the belt around the agitator pulley on the agitator assembly.
    NOTE: There is a place for the belt to fit on one end of the agitator assembly only. This is the agitator pulley.
  4. Use both hands to pull the belt tight, and slide the agitator assembly firmly into the slots on each end of the nozzle housing.
  5. Rotate the agitator assembly by hand to insure nothing rubs and to check for correct assembly.
  6. Replace the lower plate
Jan 10, 2008 | Panasonic MC-V5745 Bagged Upright Vacuum
Maytag Neptune MDE5500AY Electric Dryer Logo
98 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
