Question about Nintendo Wii Console
Wii problem: controller or sensor bar
While playing my kids' Wii yesterday (tennis) I swung too close to the tv and came down on the sensor bar, hard, with the controller. Now everything works (as far as we can tell) EXCEPT that any fast swing-type motions - like you'd use in most sports (bowling, baseball, tennis, golf) - aren't detected at all. Otherwise, the cursor does move correctly as you point the controller at the screen.
Is this the sort of thing that tapping the controller on its side on a hard surface 3 times (as I've seen on this board) may cure? Or is it likely to be the sensor bar? There's no visible damage to either the sensor bar or the controller, except for a scratch on the sensor bar.
Thanks in advance for any and all insight!
Tom
  • TomHart Apr 03, 2008
    Last night I finally tried the method I'd read here to fix a similar, but not identical problem. I tapped the controller firmly 3 times on a hard surface. That did the trick! now the swinging motions are registering. Apparently, as mentioned in the posts that prescribed this solution, the tapping "reset" the motion sensing apparatus in the controller.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 84 Answers
You sensor bar is likely not working write because the wii contrl was going to fast and to close to it at the same time + the impackt must have hurt the main cesor inside of it
hope i helped
chris
Posted on Mar 31, 2008
2 Suggested Answers
chris252
  • 84 Answers
SOURCE: turns off when swung, full battery power
you have a problem with your batteries or battery pack it is probably because when you swing hard the battery's come loose from the metal
Posted on May 05, 2009
No hand is showing upon the screen
Check to make sure the sensor bar is securely plugged in. My sensor bar quit working because the wire got damaged and I just went and bought a wireless one and rechargeable batteries. Mostly the sensor bar is only used for the menu and any games that have target shooting like billiards. You can bowl, play baseball, tennis, and golf without it on Wii Sports. I hardly ever use my sensor bar since discovering that it isn't used as much as I thought. We just turn it on load the game and shut it off and everything works perfectly on most games.
Sep 17, 2012 | Nintendo Wii Console
Sensor Bar
The senser bar can ONLY be used if it is ON TOP of the TV OR BELOW it.
Dec 31, 2009 | Nintendo Wii Console
My Wii onscreen cursor appears to be shaking up and down violently for no reason. Please tell me how to fix this nonsense.
Make sure there are no glaring lights either in front of you or behind you. A 100 Watt bulb affected my Wii. The bright light interferes with the infrared on both the controller and the sensor bar on the TV. I turn on only 25-30 watt bulbs in my living roon when playing the Wii. Changing batteries did not help. Worked for Mii!
Sep 09, 2009 | Nintendo Wii Console
Turns off when swung, full battery power
May 05, 2009 | Nintendo Wii Console
Wii controllers
on the wii menu, press the wii button on the bottom-left part of the screen.
press + and press sensor bar.
press sensor bar position
press where it is (above tv), (below tv).
it should be fixed now.
if it doesn't work, leave a comment.
Feb 18, 2009 | Nintendo Wii Console
Nintendo wii problems
Hold the Wii Remote with the button side down. Without using much force, firmly tap the button side of the remote against the palm of your other hand a few times. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard. Check for proper response.
  • Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen.
  • Make sure you are using fresh batteries in the Wii Remote.
  • The Wii Remote Controller should be used between 3 to 10 feet from the TV.
  • Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote.
  • Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves.
  • Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
I hope this fixes it for you!
Jul 08, 2008 | Nintendo Wii Console
My wii remote
@ Slivic22
Some games does not use Sensor Bar pointing because they play with motion/accelerometer only. After you select the number of sets on Wii Sports Tennis, there is no Sensor Bar pointing except for Pause menu. That's because you Swing the remote like a racket.
May 24, 2008 | Nintendo Wii Console
My wii is not working for certain sports games. Bowling is fine but tennis, boxing & golf aren't. Its like the sensor isn't picking up properly and doesn't recognise when i swing...
Have you tried the game settings?There is an option in the wii menu to adjust the wii mote to the sensor bar.Also make sure both are clean.Be sure the sensor bar is centered with the tv,and make sure you have fresh batteries.Hope this helps!
Feb 17, 2008 | Nintendo Wii Console
Wii remote
you need to smack the wii controller on your hand like you were hitting a fly. trust me, this happened to me before, when my wii just came out of the box.
Nov 01, 2007 | Nintendo Wii Console
Wii Remote Problem
try syncing the remote (under the cover on the back of the wii remote where the battery's are there is a circular red button press it then on the front of the wii where you can put your SD card there is a rectangular button press it if that does not work then try doing it the other way around if that does not work keep trying if that does not work i dont know what will
Oct 15, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
90 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
