Hitachi 53uwx10b Convergence
Mikenj1964, Hi. You anwered my quesiton a few days ago about tinkering with the Convergence on this TV. I really thank you for that. When the technician popped that grid up on the screen he also manually taped to the screen another grid so he could align the TV's grid with the one he taped up to the TV. Is there somewhere I can purchase that grid he had? If not, would it be next to impossible to adjust the convergence or just a little more complicated yet do-able.
Thank you.
  • 398 Answers
The grid (called an overlay) is put in place to fine-tune one of the colors, usually green. Once one color is adjusted perfectly, the other 2 colors are adjusted to match the first color. For example, if the convergence data is completely erased, the tech will set up the overlay and align the green using to the overlay, and then align the red to the green and then the blue to the green. If the alignment is being done after replacing the convergence IC's because one or 2 colors are slightly off in the corners, the green is usually very close to perfect and the use of the overlay is not absolutely necessary. It is pretty easy to align one color using the outer edges of the screen itself. If you do need the overlay it can be purchased from any Hitachi parts distributor such as Herman Panson, Fox or Union Electronics.
Posted on Apr 01, 2008
Testimonial: "Great Info. Thank you."
SOURCE:
My screen slopes from one side to the other on bottom!
Convergence on ur tv are dead.Must know how to do soldering?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to fix it urself.The shop will cost u $300 for parts and labors.
Mar 25, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 61UWX10BA Convergence Still Off After Chip Replacement
Remove Front bottom Panel thier you will see front of convergence board there is a small blue contact switich with TV on press and hold it for 5 sec then you should see convergence Pattern so you can aline convergence correctly I have the whole Manual to tv just have to find it. anyway for now try this.
Dec 01, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53uwx10b Convergence Grid Tilted A Little...
If the tilt is not that bad, I would leave it be. The reason is yes you can straighten the tilt out, but it requires a mechanical alignment to all 3 CRT's then you will have to align the convergence on all 3 as well. Please take a few moments to rate my answer. Thank you.
Nov 18, 2009 | Hitachi 53UWX10B 53" Rear Projection...
I changed the IC chips on my hitachi 53uwx10b tv like you guys said that helped alot but still have wavey lines on both sides of the screen what do I change on the con. board now? Thanks alot Jim
Resistors " RK42 3.3ohms
RK46 1.8ohms RK50 2.7ohms RK54 1.5ohms RK58 3.9ohms RK62 2.2ohms After you replace all of them then enter convergence by pulling OFF bottom front panel there on front of convergence board is a small blue button press it and a convergence pattern will come up now aline each color red then blue.
Sep 24, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Convergence settings on hitachi 53uwx10b
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 10, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53UWX10B
Good Day, Armenian;
You may have CRT Coolant on one the boards. LOOK very closely for shiny spot on any of the boards. WHY? Because you are saying the TV is having multiple problems. Let me know.
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53UWX10B Convergence cutting in and out
Good Day, Armenian;
You have poor connections on the convergence IC's , re solder and your TV should be back to normal.
Aug 04, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Color convergence problem
I'd suggest either replacing the ICs and resistors on the convergence board (requires soldering skill by yourself, someone else or an electronics repair shop) or purchasing a new convergence board from Partstore for $299 and swapping it out yourself.
While it may sound daunting, it really isn't once you find out more regarding this issue and dig into it a bit.  There's a wealth of info at the Digital Home Forum regarding this particular issue and ways to resolve it.
Good luck...  -TD
Apr 30, 2008 | Hitachi 53UWX10B 53" Rear Projection...
you must be experienced technician to do this if you are not will mes up your tv there is a service mode that you can access by pshing a service buttom located in front of digital convergence bord afther the aligment is done you have to reinitialize sensors and save to eprom for this service manual is needed
Mar 26, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53uwx10b template
Hi, first what exactly are you looking for? the convergence board of the STKs number? If you have convergence problem, you will need to change the STKs for sure and check the resistence to the STKs and generally all of them have same low value. check it out and replace the faulty onces. switch on and adjust convergence and you have a good working picture on the screen. Visit www.fixurtvs.com for more FAQs.
Jan 11, 2008 | Hitachi Televison & Video
Televison & Video Logo
305 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
