Question about SkyScan 34202 Clock Radio
Digital atomic clock radio
I have a skyscan digital atomic clock radio model 34202. I cannot get the time to the correct time zone. It is pst. I live in Columbus, Ohio. The time is 3hrs behind.
Thank You
Patti
Hi. There should be a switch on top of the radio that allows you to select the time zone. It is just behind the snooze bar and labeled PST-MST-CST-EST. Try that.
Posted on Oct 11, 2008
I got the clock from my daughter and have no manual. I keep setting the time, and it keeps changing to 2 hours earlier. I think I've pretty much figured out everything else, though this is NOT intuitive.
Hi, your clock radio is an atomic clock radio... no wait you don't need your lead underwear! it receives a signal from the atomic clock and sets the time to match it, after you set the time zone and put it on auto dst you will never have to set the time again!
ENVIRONMENTAL RECEPTION EFFECTS:
The Atomic Clock obtains the accurate time with wireless technology. Same as all wireless devices, the receiving ability may be affected by, but not limited to, the following circumstances:
  • Long transmitting distance.
  • Nearby mountains and valleys.
  • Among tall buildings.
  • Near railway, high voltage cable, etc.
  • Near freeway, airport, etc.
  • Near construction site.
  • Inside concrete buildings.
  • Near electrical appliances.
  • Near computers and televisions.
  • Bad weather locally or electrical storms between you and Colorado.
  • Inside moving vehicles.
  • Nearby metallic structures.
LOCATION PRECAUTIONS:
This clock receives a radio wave much like a TV or radio. Be sure to locate it near a window or some other location where reception is good. Avoid the following locations, which can interfere with proper reception.
Synchronization signal reception can be received in Continental USA only. In other areas, you can still use this clock by making time settings manually.
QUICKSTART
  1. Place your clock in a location with optimal signal marks on the LCD.
  2. It is recommended to put the clock near a window. Please move the clock to another location if difficulty in signal reception or unstable signal marks is encountered.
Installation
Simply plug the SkyScan clock radio into any household outlet.
Battery Back-up Operation
This clock radio is equipped with alarm time memory that can be powered with a 9-volt battery (not included).When normal household power is interrupted, or the AC cord is unplugged, the battery will power the clock to keep track of the time and set alarm. When the backup battery activates, the LCD backlight is off, however, the functions of alarm and radio still operate.
To Install the Battery
  1. Remove the battery cover at the bottom of the case.
  2. Connect a 9-volt battery to the connector plug.
  3. Insert the battery in the compartment and replace the cover.
Note: An Alkaline battery is recommended. Carbon Zinc and rechargeable (nickel cadmium) batteries not recommended.
Set the Time Zone Press the SET button in sequence until you see PST(Pacific Standard Time)blinking below the time digits on the LCD. Press UP or DOWN button to select your time zone.
Daylight Savings Time
Always slide the DST switch to ON position unless the clock is used in an area without Daylight Savings Time.
**Special attention to usage in Arizona and Indiana. **Arizona and parts of Indiana do not recognize Daylight Savings Time (DST). Turn the DST off if the clock is used in these areas.
Cheers!
Feb 16, 2010 | SkyScan 34202 Clock Radio
Cant fix the time zone
Successful reception of the time-synchronization radio signal is indicated by a radio waves icon to the right of seconds in the upper section of the display. After synchronization occurs, you can select your continental U.S. time zone (EST, CST, MST, or PST) by means of a switch on the back of the clock.
Feb 15, 2010 | SkyScan 86742 Digital Atomic Wall Clock
I am getting EST time. I live in MST. How do I reset the time ?
Successful reception of the time-synchronization radio2_bing.gif signal is indicated by a radio waves icon to the right of seconds in the upper section of the display. After synchronization occurs, you can select your continental U.S. time zone (EST, CST, MST, or PST) by means of a switch on the back of the clock.
Feb 02, 2010 | SkyScan 86709 Atomic Wall Clock
Skyscan atomic wall clock 87315. Changed battery
Press and hold the set key until time zone appears, then + or - to your zone.
Jan 31, 2010 | SkyScan Audio Players & Recorders
Set the time on my skyscan atomic clock mo 8672
The clock will set itself at specific time set times, this is likely to be at 0200 0400 and 0600.
You will however be required to set the time zone, the switch is likely to be on the back.
INFO:
Atomic Time Synchronisation:
How does it work.
SHORT VERSION:
Radio set clocks and watches receive a 60-kilohertz, radio signal from the NIST the official timekeeper for the US and is located in Boulder, Colorado. Ft. Collins. they use atomic clocks and transmits this official time via high frequency short-wave and low frequency AM radio signals, satellite transmission, Internet, and via telephone.
REFERANCE LINKS:
OFFICAL TIME:
http://www.time.gov/timezone.cgi?Eastern/d/-5/java
PHOTO OF ANTANA TRANSMITTERS:
http://tf.nist.gov/stations/wwvb.htm
Jan 13, 2010 | SkyScan 86742 Digital Atomic Wall Clock
How do I reset my skyscan 86715 atomic clock?
SkyScan 86715:
>Press "SET" once,
>>press "+" until you see your time zone;
-4 ATL-Atlantic
-5 EST-Eastern
-6 CST-Central
-7 MST-Mountain
-8 PST-Pacific
-9 ALA-Alaska
-10
-11
-12
-6MT-?
>Press "SET" once,
DST ON/Off
>Press "SET" once,
US - duh, huh
F - MER-Mercredi, French
E - MIE-Miércoles, Spanish
>Press "SET" once,
>>press "+", for correct hour
>Press "SET" once,
>>press "+", for correct minute
>Press "SET" once,
Range 00-20; 09 = 2009
>Press "SET" once,
Month
>Press "SET" once,
Day
>Press "SET" once,
Day of the Week
>Press "SET" once,
12 or 24 hour
>Press "SET" once,
Fahrenheit or Celsius
>Press "SET" once again - DONE!!!
The clock should now display "month/day/day of the week/moon phase/Temperature"
NOTE: Moon phase and Seconds will correct on first reception from Coordinated Universal Time (UTC)
Lastly,
Press "+" once,
Temperature changes to seconds
>>Press "+" once,
Temperature returns on right-most panel and
seconds replaces day of the week.
>>Press "+" one last time and you are back to done!!!
Thanks,
peppermyers@yahoo.com
Apr 02, 2009 | La Crosse Radio Controlled Atomic Clock
Skyscan atomic clock receives time signal but is displaying GMT rather than EST.. how do I get it to display EST?
You didn't tell us the model number but whatever it is, you should find instructions here:
Skyscan website
Our various 'atomic' clocks have either a menu that lets one select or a simple slide switch with US time zones from which to choose.
Mar 08, 2009 | SkyScan 86742 Digital Atomic Wall Clock
Cannot reset my SkyScan Atomic clock after changing batteries
Online manual is at link http://skyscan.info/content/manuals/25-model-87315.html
Dec 29, 2008 | SkyScan 86709 Atomic Wall Clock
SkyScan 34202 Clock Radio Logo
231 people viewed this question
Top SkyScan Audio Players & Recorders Experts
Rick Goldsmith
Rick Goldsmith
Level 1 Expert
Tom Chichester
Are you a SkyScan Audio Player and Recorder Expert? Answer questions, earn points and help others
