Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchen Aid Superba Dishwasher
The washer doesnt seem to be cleaning properly. It runs, the water fills and drain. I am guessing the rotors are not spinning to give an effective cleaing.
  • Anonymous Feb 25, 2009
    dish washer starts but wont go into cleaning it just fills up with water and steams the dishes
  • Anonymous Mar 31, 2009
    I have a kitchenaid superba dishwasher, KUDS24SE BL5 and it has
    stopped in mid cycle with water in the bottom. It will not finish
    the cycle nor when I press the cancel button will it drain.
    In a past problem, a couple months ago it stopped in mid cycle and
    permitted me to drain the tub by pressing the cancel button.
    A week later it started to work properly.
    Can you give me any help.
    Russ
Mix "CLR" (at stores) with water, pour it in, turn on diswasher (nothing in the machine) then stop it in the middle of first cycle before it drains. The "CLR" will get rid of calcium deposits that are clogging machine. I stopped my dishwasher for a few hours to let "CLR" work. This worked for me.
Posted on Jul 26, 2008
    President:
  • 1,314 Answers
Check the holes in the spray arms to see if they are plugged also brand and model number will help
Posted on Mar 31, 2008
6ya staff
SOURCE:
Dishwasher stops working a few minutes after being started
Make sure the water is turned on to the unit first--next, is there water entering the tub? Check the float switch--the round, plastic, "flying saucer" shaped object at the bottom of the tub. Gently lift up on it and carefully listen for a very soft "click" sound. That is the tiny switch underneath working. If something gets trapped under the float switch, the washer won't fill with water. Next, if water is indeed in the tub, did you hear the motor pump running? If it runs and then stops, there might be a problem with the control board--check to see if the drain pump works properly--cancel the cycle and listen for the drain pump turning on and draining out all the water. On almost all dishwashers, at the start of a cycle, the drain pump will turn on briefly to pump out any standing water left in the motor base(you can't see the water but it's there) so it doesn't get sprayed onto your dishes. Then, fresh, hot water enters the tub, when the water level reaches the proper level, the float switch rises, tells the computer enough water is present, then starts the main pump. If the water is not being drained out, try to listen for the drain motor humming. If it is running but not draining, it is probably jammed with food or other debris and must be cleared. If the water is turned on but no water is entering the tub, check the inlet water valve underneath the washer--the water line is connected directly to it. It is electrical and operates on 120v. You will need to carefully disconnect the connector from the valve, activate a cycle, and using a voltage meter, check to see if 120 volts is present. If it is there and no water is entering, most likely the valve is bad. If there is no voltage at the valve, either a wire is broken or the main board is defective.
Jul 30, 2015 | KitchenAid Kitchen Aid Superba Series...
Not draining properly
Hello, I would look for a kink or a blockage of the drain hose. Also check the drain pump belt for looseness or breakage.
Jul 30, 2014 | KitchenAid Kitchen Aid Superba Series...
My Bosch dishwasher SHU43C won't fill. husband used plunger in kitchen sink many times throughout the day. we didnt realize the water was being forced back down the dishwasher drain valve and filling the...
You need to clean that contaminated out of the dishwasher and clean the water level float and the screen at the bottom of the washer tub.
Jul 13, 2017 | Dishwashers
Kitchen aid dishwasher
The washer is filled up with water because it is at float level. So basically same water to clean again and again. You will have to remove kick panel at the bottom front for access to the pump and drain hose.
Apr 24, 2013 | Dishwashers
My dishwasher is a kitchen aid and is leaving all the dishes and glass ware with grime and dirty what to do?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Jan 14, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
The dishwasher is not cleaning properly, glasses look like they have a film on them, plates also do not look clean & the dishwasher has a foul smell.. like rotting food in it.. we use the top quality...
Check the main drain system connected to the dish washer hose pipe. Clean the junction if clogged. This smell might orginate from the pipe.
Check incoming water quality. If hard water is noticed, use softener attachments to the inlet.
Fill dish washer salt in the dispenser. Refer user guide. The salt will help softening the water to certain extent. Finally check whether rinse aid dispenser filled with the rinse aid liquid.
Jun 01, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
I have a kitchen aid dishwasher that is not dispursing the water enough to clean. I have cleaned the entire unit with commercial cleaners and have added vinegar to the washer without dishes. And still it...
You need to remove the wash arms by turning the nut in the centre of the arm and remove,then unblock the holes that are in the arms and replace them,test if the arms now turn and you can see a differance then also check there is salt in the salt dispensor located at the bottom of the machine.
Dec 30, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchen Aid dishwasher model KDC-18 is not filling with water
Under the machine is the water inlet valve. if you take off the front end of that you find a filter which fills up with rust, and you can clean it out. If that doesnt work, repairclinic.com will sell you a new valve for 32
Jun 13, 2009 | KitchenAid Dishwashers
Dishwasher filling with water and flooding when not in use
check to see if your dishwasher is level. If it is unlevel the water could run to the front. Hope this helps.
Jun 04, 2008 | Dishwashers
Kitchen Aid KUDI230BAL0 - no fill on rinse
i would check for apossible drain issue, perhaps siphoning water out after 2nd fill. make sure you have prper high loop insatlled in drain hose, could also be a bad water fill valve, solenoid overheating and not opening properly after 3 fills
Feb 21, 2008 | Dishwashers
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
866 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
