Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Hitatchi - Ultravision Digital 52" - Pink screen
Wondering if you can help?
Screen color went pink on my Hitatchi Ultravision Digital 52 inch wide screen. Adjusted color to black and white, as this was the only option or way to finnish watching a movie.
Im asuming this is due to a bulb or a lamp that has burned out???
Any idea of the costs of the bulbs or lamps? If one burned out, do you expect the others will shortly?
Any idea where to buy a new one? Cost? and do I have the baility to change it myself?
Or am Im better off looking for a new TV.
  • cawingnut19 Jun 19, 2008
    I have the same problem, just started yesterday. Anyone know what to do? My TV is about 5 years old.
  • 1153 Answers
SOURCE: 52 hitachi ultravision
Yes, you can search these threads for the answer or ctechnicians.com
Posted on Jan 02, 2008
  • 96 Answers
SOURCE: Pink Dot in center of screen.
Well, You have a bad engine, so what other's called lcd projector motor.
This will cost you, the engine states at about $500. I've seen this problem and right after I've change the engine for some
F#$% reson the bulb when, twice on me, that's another $400.
Good Luck
What About Bob
Timmins, Ontario
Home of Shania Twain
Posted on Mar 15, 2008
  • 927 Answers
SOURCE: Hitatchi - Ultravision Digital 52" - Pink screen
Good Day,
TRY THIS:
Before you attempt any repairs, it is necessary to make a test. The results of this test will determine which part may need replacing. Please follow the directions.
In short, you will be doing the following:
  1. Perform Memory Initialization. NOTE: You must write down some data values before performing initialize. (See Below for Procedure).
  2. Check this status of the picture. (See Status after Initialization)
  3. The status will determine what part need replacement.
FOLLOW THE ORDER BELOW:
(01)
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS: (See Below)
Select a non-used or blank Video input or tuner to get into I2C menu, also make sure the Power LED on the Front of the set is not blinking at all.
  1. Enter the I2C Service Menu, be sure the power is OFF.
  2. On the front control panel, press and hold the INPUT button.
  3. Then press the POWER button for two seconds.
    • You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
    • If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
(02)
COPY DOWN THESE SETTINGS:
IMPORTANT: The following are Service Adjustments. These Data Values are lost when Memory Initialization is preformed. It's important to write the values down before proceeding.
H Position: ________
V Position: ________
LCD ADJUST (NOT LCD DRIVE) (Arrow right)
GHOST (Arrow right)> LCD ADJUST =SHP: _______
(Press Select) LCD ADJUST GHOST=R: _______
(Press Select) LCD ADJUST GHOST=G: _______
(Press Select) LCD ADJUST GHOST=B: _______
(Press Select, then Exit)
V COM (Arrow right)> V COM-R: Set For Minimum Flicker
(Press Select) V COM-G: Set For Minimum Flicker
(Press Select) V COM-B: Set For Minimum Flicker
NRSH (Arrow right)> VS-DAT 1 through 9: _______, _______, _______, _______, _______, _______, _______, _______, _______ (Press exit twice) .
I hope this was helpful, big IRISH.
Posted on Aug 12, 2008
  • 1039 Answers
SOURCE: Poss. convergence problem with Hitachi 53UDX10B Ultravision
You have convergence problem. Either bad connections on ics, ics are bad or voltages to convergence circuit are missing. There are no bulbs in this set. 3 picture tubes,red,green and blue produce a picture than when alighned(converged) correctly on top of each other gives you a color picture.When not you get the effect you are describing. Frst you can try the magic focus in the menu.
Posted on May 02, 2009
  • 2334 Answers
SOURCE: HITACHI ULTRAVISION DIGITAL TV.MODEL NO: SP60WS lamp light is red
The lamp should be replace to fix the no picture since the lamp light is red.
Download the user's guide and see pages # 69-72 for lamp replacement.
Posted on Jul 10, 2010
Hi can anybody help me with my jvc 52 inch tv the screen is pink , the picture is real bad
is this unit a dlp digital light projection unit
and a model number would be helpful so we can determine what you have
Oct 01, 2012 | JVC Televison & Video
Have sharp quos 52" screen went pink. Can still
Hi, My guess is your daughter messed it up. Go to menu and color and reset to default should fix it.
You may have to adjust color for your best viewing. Good luck.
Sep 27, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hitatchi Ultrascan HD 43" TV suddenly had what resembles double exposure, and the color went to bright pink and bright green. A friend gave us the TV, which we had had a few months.
Ur tv Tuner board,that the board recieving the incoming tv brostcast signal to the tv.That the Tuner board,it defective.Replaced the Tuner board will solved this problems.Tries Webdites like Shopjimy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
May 14, 2010 | LG 52LG70 52 in. LCD HDTV
A pink-blue stain has appeared on the screen of my laptop
the screen may be physically damaged, or the cable that connect the screen to the rest of the stuff
Sep 23, 2009 | Dell Computers & Internet
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
The screen is pink
You CCD-chip is giving up it's ghost.
DIY-repair possible, but Fuji refuses to sell chips.
Jan 23, 2009 | Fuji FinePix S5000 Digital Camera
Good Day,
TRY THIS:
(01)
(02)
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Jan 02, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Pink picture
the electronic viewfinder on almost all digital cameras if even they got one is a tiny resolution screen or a mirror reflecting the bigger or smaller lcd screen. switch to your Lcd screen and see if colors are ok or still pink, also look at pictures you have taken. if ok the problem soly lies on the viewfinder which I have many cameras like it and come to think of it they looked aliittle pink too. the view finder helps you only in sunny conditions that you cant see your regular Lcd screen. and should be able to give you a good idea of what you are shooting. pink in real digital colors means you lost some green . look through your menu and see if there is an adjustment for it if not and you cant live with it return for exchange. I looked up the specs and would love this camera. good luck
Aug 31, 2007 | Fuji FinePix S7000 Digital Camera
LCD screen has fine pink lines and is changing colors
The LCD might have developed a fault. First try and ensure that the flexible film kind of connector is firmly in place and not damaged. As a final resort the LCD is to be replaced. For spares requirement you can write to me. If it is under warranty pl.try the nearest Sony service center. Sivaram videolabs@gmail.com
Mar 16, 2007 | Sony Cyber-Shot DSC-P92 Digital Camera
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
64 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
