Eject button on Vaio won't work
When i press the eject button on my laptop (Vaio AR690U), there's a message that pops up saying eject, but the tray doesnt open. I can open the tray by going to my computer, right click the icon and select eject, but the button to do it won't work.
  • 1 more comment
  • Cinazool Apr 01, 2008
    Those instructions were to downgrade from vista to xp and breaking things i think, i'm still on vista
  • el08yc Oct 23, 2008
    I also can not use the eject bottom of my ar71j
  • Anonymous Mar 23, 2014
    DVD unit will not eject (open). Get an error message.
    Scholar:
  • 117 Answers
T seems like people are having problems with getting the Fn Brightness and CD Eject Keys working when installing XP.
The following files and install method works here:
01. Install SFEP [AR51] (Right Click - Install SonyNC.inf)
02. Install Sony Shared Library [AR51] and Restart when prompted
03. Install Sony Utilities DLL & Settings Utility Series [BX4]
04. Install VAIO Event Service. Select Custom and Check VESUnique and Sound [BX4]
05. Copy AR51 Vista VESConfig.ini (from attached zip file) to folder C:\Program Files\Sony\VAIO Event Service
06. Start - Run services.msc
07. Find Vaio Event Service in the Services list and Restart the Service.
Your Fn and EJECT Buttons should now work.
Posted on Mar 31, 2008
Hi to All !!
i've found that solution.... for me work fine on vaio vgnz windows 7
change the letter D: to one other .
on Mount'nDrieve gestion , right clic on periferic 0 and change d: with i:
Posted on Jan 05, 2010
  • tonykart38 Jan 05, 2010
    this work form me!!!
Hi, if you have Daemon Tools installed and physical DVD drive don't open pushing eject soft button  you don't need to uninstall Daemon Tools, just change drive letters choosing for the real drive a letter alphabetically minor than letter of the logic drive installed by Daemon Tools...
It worked form me.
Bye
Gianni
Posted on Apr 14, 2010
Sol~2 worked for me on a VGN-TX3XP running Vista.
Posted on Jan 29, 2010
please check if you have installed virtualCD or daemon tools on your computer, since these programs are able to block the eject functionality.
I also had this problem and after I've uninstalled the daemon tools the eject button works again.
bye
Posted on Apr 18, 2008
If I try to right click the SonyNC thing it says "The INF file you selected does not support this method of Insulation."
Posted on Dec 01, 2009
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
How do I open the dvd tray
is there not a small button on the laptop.
Feb 12, 2015 | Acer Computers & Internet
How to eject dvd disk samsung laptop no eject button?
There are two ways toopen the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD driveis faulty and needs replacing.
Apr 01, 2012 | Samsung NC10-14G Notebook
My Technika DVDr 2005 drawer will not open and has a DVD in place - how can I retrieve the DVD?
turn it off then unplug the dvdr then after a while plug it again and turn on, now press the play button after a while press the stop button then next is the eject button. if still the tray won't eject unplug the dvdr use a philip screw driver unscrew to open the cover. look for the plastic motor gear then manually turn it with your finger to eject the tray now you can get your dvd. place back the cover and plug the unit and then turn on to check if its working again and eject the tray. thanks i hope it will help you good luck.
Jun 13, 2011 | Televison & Video
A disk appears to be stuck in the disc drive. It will not eject.
You should see a small hole next to the eject button on your drive. Take a paperclip and push it into that hole. It will force the drive to eject.
Mar 01, 2011 | Acer Computers & Internet
HOW DO i GET CD TO EJECT? WHAT DO I HIT?
There is an eject button on the drive tray, when the notebook is powered up then press this button to open the tray.
If it still does not open then straighten a paper clip and insert it into the pin hole in the tray and push it in gently until the tray pop out, you can then pull the tray fully out to get at the CD.
Dec 10, 2010 | Dell Studio 15 Laptop
Loaded a cd to upgrade firmware, firmware would not load. eject button would not eject. read manual, says to push eject at the same time you plug in the electric cord,still would not eject. Any...
Please try in this way.
Disconnect power.
Connect power back, and keep REPEATEDLY pressing the eject button while you connect. If still no ject press power on button while you keep hitting the ehect button. You need to press eject on the unit, do not use the remote.
If that does not work, then the unit must be taken apart.
Dec 09, 2010 | Cameras
Will not eject DVD is working is stuck I think I might need to open laptop
Power down the laptop and restart it. As soon as it restarts press the open button on the dvd drive and it will open. You may have to try a few times but it will work.
Sep 29, 2009 | Dell Studio 1737 Laptop
Sony Vaio VGN-AW21M OPTICAL DRIVE PROBLEM
replace drive 35-50 bucks i reccomend a lite on
Aug 22, 2009 | Sony VAIO VGC-RA840G PC Desktop
Cd stuck inside laptop
There is a small hole, usually near the eject button. Unbend a paper clip and carefully push the paper clip into the hole, try to keep it straight. drive should pop right out.
Feb 20, 2009 | Gateway MT3705 Notebook
Computers & Internet Logo
13,703 people viewed this question
David Payne
David Payne
