I am trying to help a friend out by exchanging her old hard drive that is no longer working with an extra hard drive I have lying around. however I have hit a snag,Upon entering Setup which I can do I am unable to change any values in setup with out a password. I am prompted to ''Enter Setup Password''. My friend can not recall her Password.
The easiest way to do this is to locate the coin cell / watch battery located on the motherboard and remove it, let it sit for a bit (some motherboards may need to sit upwards of 24 hours due to energy that stays in the motherboard). this should wipe the configuration.
Keep in mind, it will bring it back to default factory setup, so you might need to configure some devices again for everything to properly work.
but it should also wipe the password so you can make changes to the BIOS.
If you have any questions, please let me know.
Thanks,
Mike
Clear the password using the pwd jumper on the motherboard
NO its a software crash use the installation disk you said you used......go through the blue screen allowing windows to boot up from that disc let it go right to the end and press "R" for the console (the dos line ) when there enter .... chkdsk /p
Let Windows fix any problems. When finished remove the disc and I bet it will open windows for you. Please come back and tell me how did you do because most people that I helped with this problem just run but you know old saying "what goes around comes around"
