Question about Acer AL1716Bbd 17" LCD Monitor
Al1715 the monitor display the image 20 % en the top, the rest is white
  • shaumy Apr 13, 2008
    Hi
    I got an LCD monitor Acer 1716 which is not powering on , the matter of fact the lights on power button flashes intermittently but not powering , I opened the case thinking it was something lose inside but nothing what can i start testing inside? any ides
    thanks in advance for your help
    Francisco
  • shaumy May 11, 2010
    Hi Mark
    thanks for your answer, I resetted the cable still no go , as you said the panel could be almost dead if so what exactly to look for ? I mean I like electronics like a hobby , but what to look for exactly in the board like a faulty piece? oh well what is comom thing to fail.. I know it might not be worht to repair but i will give it a go as you see
    thanks in advance for your answer
    francisco
  • 472 Answers
There are 2 possibilities, the second is 99% more likely though.
#1 The cable between the onboard video card and the LCD panel has come loose at one end. Push it back into place and try again. (this is inside the monitor)
#2 The panel is almost dead. They have a tendency to do this when they are failing.
Hope it helps =)
Posted on Apr 09, 2008
6ya staff
SOURCE:
The monitor powers up then shuts off then a second later it starts up again and keeps repeating
More likely to have dying power supply due to bad caps just like the rest of failed ACER monitors as shown in my albums here:
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
Please read my guide and read about bad caps.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Nov 05, 2010 | Acer AL1715 17" LCD Monitor
Where can I buy an Acer AL1715 monitor from, I have checked ebay and many price comparison sites but no luck =(
Hello frebib, I found one on on EBay from a top rated seller. Here is the link: Hope this helps! Edward
Aug 24, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
Every 5 to 10 minutes my monitor gets a white screen. If I turn off and back on the monitor, it goes away
You may loose connection between the logic board and the LCD panel connector, or the 5vdc feeding the panel is going out. Look to see if you notice anu caps with leaking.bulging tops.
Jul 13, 2010 | Acer AL1715 17" LCD Monitor
AL1715 (Black, Silver) 17" LCD Monitor: my problem is not computer i am computer problem i...
The problem with PC or the monitor?
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 17, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
My acer al1715 has a pink tint. It started
This is a low-end monitor and the image processor is failing. You will require a replacement but since the monitor is low-cost, it is cheaper to simply by a new one.
Jan 20, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
Acer al1715 main board is a problem
shop jimmy on E bay send him an email question
Jan 31, 2009 | Acer AL1715 17" LCD Monitor
AL1715 Acer flashes twice when starting up but does not go on
blown capacitors most likely cause, replacement of the blow caps on the main power board is advised
Jan 08, 2009 | Acer AL1715 17" LCD Monitor
Black Mark
only sounds as if he has damaged the pixels so much they don't display the colour properly any more, if it is still under warranty get it replaced by Acer, if not take it to an electronics store like pc world and they might be able to fix it for a price.
Martin,
Dec 01, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1715s
Hi, Maybe it is a stuck pixel try this link perhaps this will give ya some insight ... But it sounds as if ya monitor is going flakey :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Apr 20, 2007 | Acer AL1715s (Silver) 17" LCD Monitor
Open Questions:
TECHNICAL 1=855=536=5666 Crypto Tech support number Crypto is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the Crypto email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Crypto support number When you are using the Crypto for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the Crypto support number and ask for the help. Once you dial the Crypto customer support number, you come in contact with a team of experts at the Crypto customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Crypto support phone number will help you with that simply and quickly. This is Crypto's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Crypto agent. Features of Crypto support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the Crypto customer support phone number. Here are some of the features of customer service: The Crypto customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the Crypto customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this Crypto provides you the facility of Crypto support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the Crypto. Here are some of the issues that you are going to face when you are using the application: The user might be having trouble with the connectivity of the internet services. There might be questions regarding the plan the user is using, or how can he or she change it? Might be some channels are missing. The list can go on, but there is no need for the user to worry about. As the user can always get the solution to the problem by contacting the Crypto Customer support number team.
Oct 22, 2019 | HIS Computers & Internet
FLORIDA 1855=536=5666 Crypto support phone number Crypto is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the Crypto email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Crypto support number When you are using the Crypto for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the Crypto support number and ask for the help. Once you dial the Crypto customer support number, you come in contact with a team of experts at the Crypto customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Crypto support phone number will help you with that simply and quickly. This is Crypto's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Crypto agent. Features of Crypto support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the Crypto customer support phone number. Here are some of the features of customer service: The Crypto customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the Crypto customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this Crypto provides you the facility of Crypto support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the Crypto. Here are some of the issues that you are going to face when you are using the application: The user might be having trouble with the connectivity of the internet services. There might be questions regarding the plan the user is using, or how can he or she change it? Might be some channels are missing. The list can go on, but there is no need for the user to worry about. As the user can always get the solution to the problem by contacting the Crypto Customer support number team.
See all Acer AL1716Bbd 17" LCD Monitor Questions
Acer AL1716Bbd 17" LCD Monitor Logo
44 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
