Question about Olympus DS-40 Digital Voice Recorder
Help! My Voice recorder is stuck in Slow playback/record
Everything I record is slowed down when I press playback and I can't get it back to normal speed. I can see an "S" at the bottom of the screen, I assume this means "Slow".
How do I get back to normal?
  • 2 more comments
  • Nessah Dec 20, 2008
    how do i get speed back to normal
  • mycroft26 Jan 05, 2009
    the ds 40 puts itself in slow mode (i have never changed anything in the menu) and it is impossible to return to normal speed, as the menu only offers "slow" or "fast"
  • Anonymous Jan 20, 2009
    i touched something and now the lectures are speedy how do i get it off of the "f" which i assume means fast, i would like to slow it down
  • c gregg
    c gregg Dec 23, 2013
    this works! thanks so much!
    New Friend:
To switch back to normal press the PLAY button during
playback.
"Every time the PLAY button is pressed, the playback speed will switch."
Posted on Aug 05, 2010
  • c gregg
    this worked!! thanks so much. kept trying to change the speed with the play settings in menu but it didn't help. this did it!
  • isabellawalt
    isabellawalt May 13, 2014
    It still seems to be stuck!!! Help!!!
SOURCE:
Canon ixus 75
Unfortunately, no. By recording in fast mode, the camera captured fewer frames than usual. When played back at the normal speed, the action appears faster than normal. Because the camera recorded fewer frames, there is no way to make up for the images that were not captured. You could slow down the playback, but the result would be a jerky, jumpy video.
Now, if you had accidentally captured the video in slow motion, you could then throw away some of the intervening frames and recreate a normal-speed video.
Feb 15, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
SD Card Write Speed Too Slow
Hey Jack! Certainly you've found a solution by now but maybe some poor soul is seeking the solution like I was.I had my Pockettrax CX saying "Memory Full" although I'd deleted everything. What helped finally: I formatted the SD. Now I've got all the memory back. Don't know if that would help the recording speed. but maybe. IMPORTANT: SAVE ANY FILES on your LAPTOP before formatting the SD.Here's how to format the SD:Go to Menu.Click on "Common Menu"Scroll down until you get to "Format"Press "Yes""Formatting SD" comes up and, Voila,You've got more space.
Jan 26, 2012 | Yamaha POCKETRAK CX Voice Recorder
HOW DO I GET IT TO PLAYBACK AT NORMAL SPEED
go into the menu and set the playback speed to normal,not fast or slow,if its a tape machine,set the speed using the small switch on the side that says 2.4/1.2
Mar 23, 2010 | Olympus Audio Players & Recorders
Slow Playback
Sounds to me that the computer is way out of date. Chances are the computer doesn't have enough processing power to support what you're trying to throw at it.
It might help stop/uninstall all other programs running at the same time to give Cakewalk the best chance of working.
Nov 15, 2017 | Cakewalk Guitar Tracks Pro 2 Classic
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
Sony Handycam CCD-FX310
Record in slow mo mode, then playback in fast forward mode ;) Problem solved. You'll see the video in normal speed.
Oct 20, 2007 | Sony Handycam CCD-TRV37 Camcorder
Voice playback is extremely slow.
try with some contact spray ,put it on the speed of tape button and that will solve the problem for some time.
Oct 30, 2006 | Olympus Pearlcorder T1000 Desktop Cassette...
Olympus DS-40 Digital Voice Recorder Logo
1,367 people viewed this question
Top Olympus Audio Players & Recorders Experts
Ekse
leoz
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
