Question about ASUS P4S800 Motherboard
Usb not working
The usb ports in the front of my system stop working now when ever i put my device in (phone,ext. hard drive ,mp3 player) i get a message saying windows can not recognize this usb can you please help me with this
  • 99 Answers
Try to change the Bios setup,in the chips configuration nyou have to enable the usb controller,then save the changes and restart the unit,if still does't work ,try to reinstall your os.
Posted on Apr 02, 2008
Panasonic sa pt860
Check your USB memory to make sure that it comply with the points below:
1) USB standard USB 2.0 full speed
2) Media file format support MP3 (.mp3) WMA (.wma) JPEG (.jpg) (.jpeg) MPEG4 (.asf)
3) USB device file system FAT12, FAT16, FAT32
4) USB Port power Max. 500 mA
As you can see
1) You should format your USB in windows format (FAT system)
2) The files on your USB should be those mentioned above on point 2.
3) 2.5" hard drives most likely do not work without an external power supply.
you can download the manual from HERE !
Please don't forget to rate me!
Best Regards
XyFinx
Dec 14, 2013 | Televison & Video
My maxtor 500gb usb hard drive is not responding when I plug to my pc, so I can't access to any of my file
hello,
-make sure that the cables from the ext hard drive is properly connected like power if there is and USB -try other USB port -try other USB devices -try other USB cable for that Maxtor -try other computer
the reason why you are doing that is to know if the USB port is broken of if the ext hard drive is not responding.
cheers.
Feb 24, 2011 | Maxtor BASICS Personal Storage 3200...
We're trying to hook our Western Digital My Passport External Hard drive to our dvd player. The dvd player has a port for it, but is unable to read the external hard drive. Do we need to unlock the hard...
the USB port in the dvd player is to update it by the manufacturer. Unless the USB port is in the front then try going into the dvd players menu and have it search for devices, also make the content easy to find for dvd player, like have a VIDEO folder and put the media in there.
Jun 20, 2010 | Western Digital WD Passport 250GB Portable...
I can't put photos in my YPT10 using Samsung Media Studio.
If that is not working try doing it the drag and drop way:
1. Connect one end of your USB cable into the USB port on your MP3 player and plug the other end into an empty USB port on your computer.
2. Double click "My Computer" on your desktop. You MP3 player should be listed as a hard drive. Right Click it and select explore.
3. Double click the "Media or pictures" folder, then drag your pictures into this folder to download them to your player.
4. Double click the "Safely Remove Hardware" button on the bottom right on your screen, then locate your player on the hardware window. Click "Stop." After the popup windows says its OK to remove your device, safely unplug your player.
5. Turn on your player and select "Pictures" on the main menu to view your downloaded photos.
Oct 03, 2009 | Samsung YP-T10 Digital Media Player
I have a square lookin delstar mp3 and i don't know how to put songs in it.......culd u tell me how....pleze???? i want to get the music from youtube..oh yeah..it has 4GB!!! I LOST THE CD DRIVER SO I CAN...
if you have a windows machine, first plug the mp3 player in to one of the empty usb ports on your computer and let windows install it, now use windows media player to songs to it using sync or copy music to device
Jun 23, 2009 | Delstar DS 31024 MP3 Player
External Hardisk Maxtor 4 One Touch not detected
Have you tried different USB cables with the drive? If the drive is self powered (no ext power supply) which I think that one is, then it needs a really good cable to draw the 5 volts from the USB port. If you have tried a known working cable, then it could be the USB controller or the disk itself. You can buy the USB box on eBay really cheap and move the drive over.
Apr 13, 2009 | Computers & Internet
Getting my mp3 player to work on panasonic cq-rx300n
Unless your USB port can read your phone, this will not work. The USB port is typically for USB memory sticks only. My Juke had the same issues, and I realized that the radio would need to be able to Run Windows Media Player 10 or better to work. Most radios don't have any Hard Drive memory, so unless yours does, you may need to find a different route.
Jan 14, 2009 | Car Audio & Video
Playing movies through usb port?
The options when you play a DVD it will appear when you are connecting ext HD it will not work.
Better you need the play in a DVD Disc to get the good sound.
Jan 06, 2009 | Philips HTS3440/37 System
Help
These units take more power than a thumb drive and sometimes the front USB ports on a computer just don't push enough current to recognize these players (I have the same issue).
Try plugging it into the back USB ports.
Also, make sure your USB ports are working correctly in your device manager.
Apr 27, 2008 | Insignia NS-DV2G MP3 Player
Sansa mp3 player not detected by system
1. I assume you are using a USB Port to connect the device?
--Yes - Continue - If No, please specify connection method
2. Does using another USB Port on the PC make any difference?
--No - Continue - If Yes, that port on the PC is not functioning.
3. Are other USB devices that you plug into the PC detected?
--Yes - Continue - If No - the USB system on the PC is not functioning - upgrading or reinstalling the driver might work if it is not a hardware malfunction.
4. Did you install any type of driver for the Sandisk mp3 player?
--No- Continue - If Yes - uninstall and reinstall the driver.
5. Do you have another USB cable to try with the device?
-- If No, try another PC.
CL23
Feb 15, 2008 | Computers & Internet
ASUS P4S800 Motherboard Logo
91 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
