Question about HP LaserJet 3050 All-In-One Printer
Fax confirmation set up
I need to know how to set up to recieve a fax confirmation after every fax on a laserjet 3050. can you help??
thanks
  • 2 more comments
  • Anonymous Apr 25, 2008
    Any Solutions for this? I can't find out how to set this up.
  • Anonymous Aug 26, 2008
    i am not a full page fax call report only heding
  • Anonymous Sep 10, 2008
    i need more information on how to set up fax operation
  • Anonymous Mar 14, 2014
    cannot turn off fax rx, won't print any docs or faxes
Document.tlSearch.tx.value=unescape("") fax confirmation set up - s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
Posted on Apr 30, 2008
SOURCE:
My HP Laserjet 3050 used to print automatically after each fax sent a call report showing that the page(s) had sent. For some reason, after a service call, now it doesn't do that any more and I have...
Hi Dear
Jun 01, 2011 | HP LaserJet 3050 All-In-One Printer
Recieve faxes problem in hp laserjet 3050
- cables properly connected
- analog or digital (DSL, VoIP, etc) phone line
- dedicated line?
- under fax setup, all faxes, turn error correction off
- under fax setup, all faxes, turn v.34 off
- test fax
Jul 17, 2010 | HP LaserJet 3050 All-In-One Printer
My brother just gave me a HP LaserJet 3050 and for some reason i can't send or recieve faxes. What would be my problems?
First plug in the phone line into a working phone to see the the line works. If the line works you may need a new modem for the 3050.
Jan 07, 2010 | HP LaserJet 3050 All-In-One Printer
Hp 3050 laser jet printer the fax page is black
The scanner in your FAX is nothing working -- i.e., "100%-black" or "100%-white", and so what is transmitted is what the scanner has scanned, improperly.
Dec 13, 2009 | HP LaserJet 3050 All-In-One Printer
How do I set up my 3050 to get a report each time I send and receive a fax?
Press menu button printer control panel.
Select the option reports.
Selected all faxes reports and that should allow you printer the report everytine you send or recieve fax
Jun 30, 2009 | HP LaserJet 3050 All-In-One Printer
HOW DO I GET A FAX SEND CONFIRMATION HP MODEL 3050
entre nas configuraçoes de fax e selecione a opçao para imprimir relatorio de envio
May 15, 2009 | HP LaserJet 3050 All-In-One Printer
Fax procedure in laserjet 3050 model
Press the Menu button and there is option to set-up select that option and there is another option call fax set-up there will be three option.
Fax recieve set-up , Fax send set-up and all faxes set-up from these three options you can set-up fax on your printer.
Thanks and Regards
Nov 26, 2008 | HP LaserJet 3050 All-In-One Printer
MY HP LASERJET 3050 WON'T SEND FAXES
While its possible, I doubt your doing it wrong...
  • Select [FAX], place the paper as indicated on the tray, type the number, and hit send. That's about it.
However, Fax machines will not send when attached to a digital phone network, used over IP phones, or in conjunction with DSL service without the lines being conditioned. This is a small device which hides the higher frequency noise from the fax machine. Any sort of signal shared on the lines may interfere with sending, recieving, or both. If you use DSL for example, I'd almost guarentee this is part of your problem.
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
Fax Confirmation Sheet
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
Fax receiving problem in 3050
changing these settings:
ECM-error correction 'off'
V.34 'off'
Silence Detection 'on'
Dec 28, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
2,062 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
