Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer wont restart mde 3000 aya
My maytag neptune dryer will not restart after the first load has dryed and a new load is immediately loaded. I have replaced the hose, cleaned the lint trap with soap and water, and blew out any lint from the screen trap to the rear of the machine. it makes a buzzing sound when you try to restart it and there is a smell of something burning, is it worth fixing or just buy a new dryer. thank you.
  • jank2 Nov 28, 2008
    my md 3000 gas dryer would not start after having just run a load as well. There was a slight electrical 'odor' when pushing the start button and a slight buzz. Is it worth checking lint blockage on exhaust. The last posting indicated they did it but it did not resolve. IS it a possibility.Is there a blockage detector that will defeat the on switch?
  • Anonymous Mar 20, 2014
    Dryer lint hose came off. Cleaned and reattached. Tried to restart dryer but it just beeps. Ran the diagnostic code test and it came up as 39.
    Novelist:
  • 131 Answers
Your dryer needs a new motor. It should cost about $200-250 including labor. Call a local repairman - not a national company. Give him the model number and ask him to bring the motor with him.
Posted on Mar 31, 2008
SOURCE:
Maytag dryer will not restart immediately after drying a load. has to cool down
try cleaning out your dryer vent. Remove your lint trap and use a flexible wire brush to clean deep inside, then remove your dryer vent hose and make sure all lint is clean from the dryer side of the vent and the vent hose all the way to the out side vent.
Sounds like it may be clogged with a build up of lint
May 23, 2012 | Dryers
Dryers I have a Maytag electric Dryer, that...
you may have one of ur overheat sensors going out that wont let the elements heat uplike they should they are behind the back cover they are round and very inexpensive u can take the wires off put new one in or u may have a bad element ake the wires off and check continuity thru the element itsself if all that is good take dryer vent off and run with it off 1 load and seee if this cures the problem if it does u had the hose kinked or u have a restriction of lint in the dryer vent going outside hope this helps
Feb 25, 2010 | Maytag Neptune MDE6700A Electric Dryer
Taking long time to dry the clothes
Due to a dryer either heats or no heat , I would suggest pulling the dryer out and removing the vent hose . Dry a load of clothes to see if they dry normally . If they do , this verifys that the vent hose is either kinked ( restricting air flow ) , or , if the vent runs UP inside the wall , there is a restriction between the inside vent hose to the outside vent . May have to go into the attic to clean .
Jan 28, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Front load MDE2400AZW takes forever to dry stuff. A regular load takes 1 1/2 hrs to dry,but the heat is on, and it seems to work.
Make sure the lint trap in the door is clean. It has a plastic cover that opens. Disconnect the venting at the rear and run a load, if it works you have a restriction in the hose after the dryer or in the wall past the hose.
Dec 01, 2009 | Maytag MDE2400AYW Neptune Electric Dryer
Maytag dryer not drying clothes properly
Have you tried cleaning off the sensor? Many of the newer dryers have a sensor that, when dirty, can no longer determine the moisture level of the clothes. Some manufacturers recommend using a light vinegar solution. Check your owners manual for location and recommended cleanier. Also, make sure your exhaust hose is clear of obstructions and that you vacuum out your lint trap area. HTH.
Aug 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer doesnt dry clothes
I suspect you have a blocked air vent. A blocked vent will definitely extend your drying time. You may even find yourself having to run a load twice to get it fully dried. One way to confirm this is to disconnect the vent hose from the back of your dryer and dry one load with the machine venting directly into your laundry room. If that load dries quickly then you know the problem is a blocked vent. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
Jun 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer taking too long to dry a load of clothes.
First thing I would do is clean from screen filter all the way out. I would clean and vacuum all the dust in the vent.
If problem still persists, I would have the heating element replaced
May 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag gas dryer runs, doesn't dry
Check in the hole where the screen goes for blockage. Many times debries falls in there when removing screen. It cant make it out of the vent so it builds up and clogs the vent.
Dec 01, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
582 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
