Question about Xerox WorkCentre XD125F All-In-One Laser Printer
Drum symptoms? Hi Tryit, The drum reset went just as you said - thank you! It worked on the first try. Now, 1 more question. How will I know when the drum really needs replaced. Will it lose copy quality, will it make a weird sound, etc.? thanks!
  • James in DC Nov 02, 2008
    My XD125F just started printing indecipherable streaked lines where the text should go. What is a drum reset and do you think it would solve my problems? On a related note, when does it become cost-ineffective to repair a printer this old?
    President:
  • 2,072 Answers
Most likely you will start to get streaking. The cleaning blade will finally fail.
Posted on Mar 31, 2008
  • Rick Kasper Mar 31, 2008
    That drum is pretty resiliant. I doubt the quality would fade in the next 18,000 pages.
    I think I would replace it after that.
    To save yourself money use this business to buy it from. Great people to deal with.
    https://www.partsdrop.com/store/
My Oki C5650 is showing all 4 3rd party cartridges as incompatible.
For the printer to do this of its own accord makes me think the main board has thrown a wobbly. As you know how to get into the maintenance mode, scroll to menu reset and this will reset the eeprom. I doubt if it will cure it without new drums. You can buy on the internet a stick-on fuse for the drum which will blow and reset the printer into thinking its a new drum. Do this for all the drums and it may just do the trick. If its toner related then only genuine toners will cure. Anyway the fuse trick is the cheapest option. You may think why drums when its toners. That's because you need to fool the printer into thinking parts have been changed and it may have a knock on effect. Its worth a try.
Jun 11, 2017 | OKI Office Equipment & Supplies
Continue to get a message to change drum soon. Changed drum already. Print quality is still not good.
hi
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Oct 07, 2008 | Brother Office Equipment & Supplies
Hi, I have a Workcenter XD102. It gives me a J2 error. I don't know how to fix it. Please help. Thank you very much, Charles
J2 error for Workcenter XD102 indicates a Drum Cartridge Problem sensed by the main PWB indicating that the Drum cartridge had reached its end of life. You may replace the Drum cartridge with a brand new Drum Cartridge. This should fix the problem.
If you believe that its not the Drum cartridge with or without replacing the Drum cartridge, you may try to open the printer, make a good clean and perform the below. 1. Check the PWB and Drum Cartridge Reset Circuit for any loose connection and short circuit. You may re-seat the cables and terminations and test. 2. If that didn't work you might need to get some voltage from the Drum Cartridge Reset Circuit as per below. 2a. If voltage is more than 0.5 VDC measured between PJ CN116-2 and GND then you need to replace the Drum Cartridge Reset Switch PL x.x. 2b. If voltage is less than 0.5 VDC measured between PJ CN116-2 and GND then actuate the Drum cartridge Reset Switch. Then check the voltage if its +5 VDC measured between PJ CN116-2 and GND. i. If not then replace the Drum Cartridge Reset Switch PL 5.. ii. Else it should be fine. iii. If not then replace the Main PWB, PL 7.1.
Jul 12, 2011 | Xerox WorkCentre XD102 Printer
I recently noticed a message that said "drum end soon" on the screen portion of my printer. With that I went and replaced the drum and toner. The problem is this: The "drum end soon" message never quit...
This message would continue to appear if the drum unit counter was not reset when you installed a new drum.
To reset the drum unit counter, follow the instructions below:
  • Press Menu on the Control Panel.
  • Press the Up or Down Arrow key to select Machine Info..
  • Press OK.
  • Press the Up or Down Arrow key to select Reset Menu.
  • Press OK.
  • Press the Up or Down Arrow key to select Drum.
  • Press OK.
  • Press 1 to reset the drum unit counter.
Thank you !!
Jun 09, 2010 | Brother MFC 7840W Printer
Drum reset procedure for all three colors
There are fuses in drums that needs to be replaced in order to keep working with these drums. It's 1/16A fuses and NO MORE!!! Drum disassembly required to find a place where fuse is.
May 21, 2009 | OKI C5200n Laser Printer
New drum wont work
It sounds to me that your maint counter needs to be reset. 24-7 will reset drum. Let me know if you need help getting into the simulation.
Feb 12, 2009 | Sharp AL-1530CS All-In-One Laser Printer
Casio PCR 260B
Hi.
The 42V printer has no head, as it is a drum printer, so the little numbers that print are on a small rotary drum that you can see spinning around while it prints. Whenever I have tried to obtain parts in the past, I have always been told that you just buy the whole printer, and believe me , it's worth it. They are almost impossible to work on, as they have so many tiny fiddly parts. You usually end up breaking the printer while trying to get it apart. The printer is usually not too expensive, and when the drum is worn, the rest of the parts are usually on the way out as well. They are considered to be a consumable part of the machine with a limited lifetime, as these basic registers are not expected to last more than a few years.
Do you know that the fault is definitely in the drum? There are other issues with these that can be fixed without dismantling the printer. If you let me know the symptom, I might be able to help further.
Mark
Jul 22, 2008 | Casio Parts Cash Register PC Desktop
Phaser 8200 error message - lamps out
I was wondering if any of you have the guide with pictures on the instructions. I got to step 5 and I am stuck trying the remove the upper transport.
Thanks
nbt@tslnet.com
Jun 26, 2008 | Xerox Phaser 8200 Laser Printer
Drum light on after installing new drum
As posted by Songdancer - this solution worked for my HL-1440 to reset the drum light
"Brother's webpage says to reset the drum counter. On some models this is done by opening up the front door, pressing the GO button until all 4 lights are lit, then releasing the GO button"
Apr 30, 2008 | Brother HL 1440 Laser Printer
Reset drum continued...
The flag should be up. When it first turns on it will engage and move to the down position. It moves from top to bottom to swipe the reset. switch.
Since Xerox doesn't want anyone to know this. I can't find any pics of how it sets up.
Wish I did. That way when I do it I could remember exactly myself, It's pretty mush a hit and miss thing.
Mar 28, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
129 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
