Projectors I have an optoma hd70 bought new. It only has 170 hours of lamp life used. When i turn it on thin black verticle lines appear running from top to bottom of the screen equally distanced appart covering three quaters of the way accross the screen from left to right.
  • 2 more comments
  • RQApageants May 19, 2008
    When I hook the toshiba tdp-b1 to a dvd player and play th4e dvd I have a black line that runs through the middle of the picture, what can I do to fix it?
  • Anonymous Oct 22, 2008
    verticle lines on the screen
  • lucasfem Dec 09, 2008
    I have thin black horizontal lines halfway up from bottom of the projected picture, evenly spaced. approx, 6 lines in my Runco vx-1c. was given as a gift and do not have funds to repair. any self fix tips?
  • acroj Jan 31, 2009
    I have lines in the picture of my Sony VPL-HS10. This appeart to be due to the LCD Panel that sits next tot the projection cube / block. These panels have the ribbons that come directly off of them. There are three different panel for the three different colors. My panel part CN820 Part # 1-794-823-11 is for the GL Ribbon. Sony claims that I have to purchase the entire block assebly for $1635.00 dollars. I'm trying to find someone who is parting theres out.
  • 563 Answers
Hi there
This would mean that your Projector is still under warranty.
The problem you are describing is a faulty Mainboard - which fortunatelly for you is covered under warranty.
Posted on Apr 01, 2008
I have a Optoma projector HD70 How do you reset the lamp operating time?
hi,
Do the following for reset the lamp hour.
1. Press the menu button
2. Select Options.
3. Select lamp settings
4. Select lamp reset.
5 Select Yes
ok
Jul 08, 2011 | Optoma HD70 DLP Projector
How do Ichange the lamp on my hd70.
Look in page 40 of your projector's User's Manual.
If you don't have the manual, you can download it from OPTOMA support pages: OPTOMA HD70 USER'S MANUAL
Oct 11, 2010 | Optoma HD70 DLP Projector
Used my OPTOMA HD70 ABOUT 2years now -and had to replace the lamp i unplugged it and when turning it back on to work - it does not start , it`s dead the green led lamp does not flicker , does not work...
There is a switch on the side where you insert the lamp, it's black with a metal contact. If, when the lamp cover is replaced, it does not "activate" this switch for some reason (i.e. it is loose or perhaps bent) then the projector will not power at all.
Just remove the lamp and take a look at the switch for possible damage incurred from when you replaced the lamp.
Sep 29, 2010 | Optoma HD70 DLP Projector
HD70 DLP Projector: after replacing bulb warning message of "replaceme...
You need to reset the light counter. Access through right most menu item. Then arrow down to lamp settings.
May 17, 2010 | Optoma HD70 DLP Projector
OPTOMA HD70 projector turns off in a few seconds
my 3m projector turns off as soon as it is turned on
Mar 05, 2010 | Optoma HD70 DLP Projector
How do you install a new bulb in the Optoma HD70 projector. Got a new bulb but no instructions
unscrew the screw on the lamp door, unscrew the lamp screws, pull the lamp out, replace with new lamp (making sure it's securely plugged in), screw it in, replace the door, plug the projector in, turn it on, enjoy!
Nov 07, 2009 | Optoma HD70 DLP Projector
Screen is not a true square: One verticle side shorter than other
Simply just manualy adjust the bottom of the screen by adjusting the distance by an inch or so.
Depending on what screen you have adjust it from behind or vith a thin thread
May 19, 2009 | Optoma HD70 DLP Projector
Optoma HD70 "Fan Failure" message, PLEASE HELP!
Simply just navigate the meny system until you find the high altitude option, the switch it on
The projector should work fine now.
If you experience problems with your Optoma projector after onle 3 mnths, assuming it was new when you bought it you still have 9 months of warranty you know, you shouldnt hesitate to bother the seller
Apr 02, 2009 | Optoma HD70 DLP Projector
394 people viewed this question
jasbo
jasbo
