Question about Dell 5100cn Laser Printer
Replacing Black toner
Can you send me the page in the manual about replacing the black ink toner? We have replaced the toner and locked it in place. It is still saying"Replace Black Toner". Help!
The locking thing clicks then needs to be pushed back even further which requires a little force otherwise it thinks there is not a new toner in it - i did this the other week with a yellow - thouygh it was a dud toner till i tried a second and had the same result then realised need to really push the lock mech home
regards chris
[email protected]
Posted on Mar 31, 2008
SOURCE:
After replacing cyan, magenta and yellow toners with genuine Canon toners, my Canon MFC 8180c does only use yellow color to print while trying to print or copy color stuff.
You will need to do an ink reset because from what you have explained the machine has only recognised one of the coloured inks and the black.
1. Switch on the machine and set it up for removal of all the ink cartridges . Then fully remove each of them (including the black) and then replace them back in the correct slots. Make sure they are fully home when you fit them. The machine now thinks you have removed used cartridges and replaced them with new ones.
2. Then close the printer and follow the instructions on the display window on the printer to indicate to the machine that you have replaced each ink tank with a new one.. It will ask in order if you have replaced each of the ink tanks from black onwards and the answer has to be yes. Make sure you hit the correct buttons when responding because if you do not the printer will not recognise the presence of that particular ink cartridge (and will not use it) which I believe is part of the problem you have now.. Check your user manual to make sure you are pressing the all the correct keys for your model machine.
Hope this helps some.
Dec 30, 2015 | Canon Office Equipment & Supplies
How to refill ink in it
The printer doesn't use ink, it uses toner, a black powder. The toner is then pushed onto the page using magnetic force and fused to the paper using a laser. Which replaces the traditional "ink injection" method.
The toner cartridge is a black unit that pulls out located behind the top access panel in the front. This unit contains a glass drum and behind it a well of toner powder. Usually you have to replace the entire unit.
There are toner cartridges with plastic caps which can be removed and then refilled with the powder. However, this powder is messy, difficult to manage, and eventually the drum will become scratched and worn since it is not really designed for prolonged use. So I recommend just replacing it.
While the toner cartridge will run more than ink. The frequency with which you have to replace it is significantly less. So while ink can run you as much as $0.25 a page when you factor in the wear and tear on the printer. Laser printers are more along the lines of $0.04 a page.
If you replace the toner, read the directions carefully and be sure to remove the plastic shipping strip from the side of the cartridge. This strip is used to hold the toner in the cartridge while it ships and will keep it from working properly.
May 12, 2010 | Canon LASER SHOT LBP-2900 Printer
Black toner replaced; now all black printing comes out faded grey
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 02, 2010 | Dell 1320c Laser Printer
Replaced fuser and toner units now only prints black pages
Printing on a laser printer has 3 steps:
1. electro-statically charging the "drum", at various tiny "pixels",
to identify where the toner-powder should be placed.
2. feeding toner-powder onto the charged drum.
3. making the fuser produce heat to "bake" the ink onto the printer.
So, a failing unit or failing electronics would "charge" *ALL* of the drum,
thus putting black ink EVERYWHERE onto the page.
Take the printer to a qualified technician.
Nov 13, 2009 | Epson EPL-N3000 Laser Printer
Quality starts out good, and then fades quickly
You probably running out of black ink. Try replacing with new black ink cartridge.
Try to run a test print.
Jul 18, 2009 | Office Equipment & Supplies
HP 2840, black ink drum q3964a
Hello, these printers tend to be finicky.
In other words, just replace the black toner. When the printer says its low, or empty, regardless of wether or not it is, just replace it.
Replacing the drum, when it says black toner needs to be replaced will do nothing to rectify the issue.
Buy only HP Toner and Drum cartridges for this printer. Do not try to refill toner cartridges, and do not reset drum. You will only end up destroying your printer in the process.
Feb 26, 2009 | HP LaserJet 2840 All-In-One Printer
Xerox XC1020 White Bands running across copied page 4" apart
The metering blades in those cartridges go bad and do not allow the ink to get to the page. Look at the front of the toner cartridge, is should be a solid consistent black all the way across, if its streaky, not consistent all the way across replace the toner.
The other problem could be a dirty laser. If replacing the toner doesnt work let me know, I will tell you how to remove and clean the laser.
Jan 16, 2009 | Xerox CopyCentre C20 Black and White...
When we print manually the whole page comes out completly black.
edithvenzor:
Try replacing the toner cartridge first, then proceed with the other items.
Thank you and let me know what happens:
Binary Bob
Problem
Cause
Solution
How common*
Comments
BLACK PAGES
DC Controller PCA is defective. If the DC Controller turns on the laser beam continuously,
the entire surface of the Photosensitive drum is neutralized causing a completely black page
Replace the DC Controller PCA
10
BLACK PAGES
Defective toner cartridge
Replace the toner cartridge
9
BLACK PAGES
High voltage contact springs are dirty or defective. The high voltage contacts are mounted on
the High Voltage Power Supply PCA and protrude into the toner cartridge cavity
Inspect and clean the high voltage contacts. If damaged, replace the High Voltage Power Supply PCA.
BLACK PAGES
High voltage power supply circuit is defective (not supplying the correct negative voltage)
Replace the High Voltage Power Supply PCA
10
some printers have the high voltage power supply on the DC controller.
BLACK PAGES
Laser/Scanner Assembly is faulty (turning laser on continuously)
Replace the Laser/Scanner Assembly
5
BLACK PAGES
Light is leaking into the printer
Make sure that all covers are in place
possible, but not likely
Nov 30, 2008 | Office Equipment & Supplies
Toner Cartridge
Mine is a single cartridge system. The black cartridge that looks like it holds the ink is the toner cartridge. Replace it with cartridge E40.
Jun 12, 2008 | Canon PC-920 Black and White Copier
Page is black
NO Try to remove the toner and insert it again and make sure the door is locked properly
Apr 22, 2008 | HP LaserJet 2840 Printer
Dell 5100cn Laser Printer Logo
50 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
