Question about GPS
Magellan roadmate 3000 screen fades out
I power it up and the megellan screen comes up. After 10-15 seconds it fades to black and never comes back. Any ideas...
  • mark leo May 24, 2008
    Magellan 3000 screen fades to blue and locks up
The fix was easy,,,,,,some **** broke into my car and stole it. I just went and got another one a tom tom,,no reason,,,price maybe.. Thanks, IM gellan
Posted on Apr 01, 2008
Register Magellan RoadMate
Hello.
If you want to register your Magellan, You need to go to Megellan web site and create password.
Here is the link to copy and paste in your browser. http://www.magellangps.com/s.nl/sc.73/.f?login=T
Sep 29, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
Hello, I updated my Magellan Roadmate 1440 from the Magellan website. Now, when I try to put in a destination, the screen says "route error, your destination may be in a restricted area or unreachable...
I contacted Magellan about this issue for my Roadmate 5045. They told me to reset the unit by sliding the power bar to to the off position for 10 seconds, and then let it sit off for a minute or so. When it powered up, the issue seemed to be resolved. But it comes back. Successive efforts using this method have about a 80% success rate.
Mar 03, 2011 | Magellan RoadMate 1440 Car GPS Receiver
Once region is set how do I change it on the megellan roadmate 1212?
By default, the Magellan RoadMate has the region setting for the lower 48 United States. When the receiver is turned on for the first time it may ask you to assign regions. Select the map region you want to use by tapping on the item from the list.
If you are travelling in other regions you will need to change the map region by using the following steps.
1 From the Main Menu, tap on the right arrow to access the second page of the Main Menu.
2 Tap on User Options.
3 Tap on Region.
4 Tap on the map region desired.
The Region option will display the map regions that are available for the Magellan RoadMate you are using.
Also if you want you can download the user manual from this website
visit website
or
download
Hope this helps
thanks
Oct 01, 2009 | Magellan RoadMateā„¢ 1212 Car GPS Receiver
Megellan RoadMate 300
You can find it here: http://magellan.cachefly.net/manuals/MRM_300na_en.pdf
You may also want to know that there is a MAJOR firmware update avaiable for your device.. It looks like it would make your GPS a lot faster and more accurate. You may want to take care of that update too while you're working on your device. The update can be found here: http://www.magellangps.com/support/notes.asp?supportID=288
Let me know if that helps!
Regards,
Steve
Sep 01, 2008 | Magellan RoadMate 300 GPS Receiver
Megellan 800 stuck on blue screen
you can go directly to the magellan website and download this fix
May 31, 2008 | Magellan RoadMate 800 GPS Receiver
Magellan roadmate 700 "powerup problem"
I had a Roadmate 700 with the same problem as yours, and the solution was simple: the hard drive inside had come loose!
All I did was open up the unit (4 screws on the back and a small snap-together clip on the end), and plugged the hard drive back into the cable. The cable has 2 black posts that fit into the hard drive, so you can't misalign the pins. On mine, the hard drive label was facing UP.
Once the hard drive was plugged in, I powered up, and could hear the hard drive spin up (which I hadn't heard before). The unit booted from the "Magellan" screen right into the menu almost immediately!
Hope this helps someone!!
Apr 01, 2008 | Magellan RoadMate 700 GPS Receiver
Megellan 3000T - went blank
Being solid stae electronics - there is little or nothing for you to do
With this type of thing it works or it does not.
Mar 17, 2008 | Magellan RoadMate 3000T GPS Receiver
Prob with my Magellan Roadmate 3000T gps: EEEEK!
Battery failure is a likely cause- is it replaceable
Feb 07, 2008 | Magellan RoadMate 3000T GPS Receiver
Magellan 2200T won't completely boot up
Reset unit, and then turn off, but hold power button for at least 10 seconds, then power back on, and when ever you turn off unit, hold power button for 10 seconds, had the same problem with mine, this solved it, it seems that just turning off the unit till screen shuts down puts it in a sleep mode. Hope this solves your problem.
Dec 18, 2007 | Magellan RoadMate 2200T GPS Receiver
GPS Logo
153 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
