Question about Toshiba TP43H60 43" Television
Additional info on Toshiba TP43H60 convergence
Tv was manufactured May 1999
  • Toshiba Master
  • 8,617 Answers
I am not sure what your needing help with , however its posted under convergence . Your set if having difficulty with aligning the colors will need to have both Convergence ICs replaced. This is an easy repair you need two STK392-110 Convergenve ICs. You can get them at the following link just click on the section titled Convergence IC and you will see your ICs listed there. They also include step by step instructions with pictures on how to remove the old and replace the new ICs as well as set you up with a free online chat session for support while your doing the repair. Heres the link.
http://servicemanuals.vstore.ca/
If you need any additional info please let me know.
Posted on Mar 31, 2008
How much was this tv sold new toshiba tp43h60
Original price of this model was around $1700.
Bill W
integrityhomeworx.com
Mar 09, 2011 | Toshiba TP43H60 43" Television
Toshiba TP43h60 - Wondering what the dials are for
You are describing the MASTER SCREEN/ FOCUS CONTROL BLOCK---black with six controls--three are red, green and blue focus--the other three are screen controls--red, green and blue--- the screens are adjusted so with the color off you have normal brightness and a black and white picture--
They have nothing to do with any Convergence problem and unless they have been tampered with rarely need to be adjusted---
Let me know if this helps you AND IF YOU HAVE ANY QUESTIONS OR NEED ADVICE--LET ME KNOW.
I am here to help people.
SD TECH
Oct 09, 2009 | Toshiba TP43H60 43" Television
Toshiba TP43H60 - Unable to adjust colors left/right
Have you tried to adjust in the customer menu or in the TECH menu? I can tell you how to get into the tech menu--if it will not adjust there you have a convergence circuit problem and I can tell you what is needed to repair the set.
SD TECH
Oct 08, 2009 | Toshiba TP43H60 43" Television
Toshiba TP43H60 Convergence Problem
This may sound odd but try moving the remote further from the set. I have seen similar issue with my 42H81.
Jun 01, 2009 | Toshiba TP43H60 43" Television
Excellent picture for a several hours, then gradually dims.
if this is a old unit the there is serious problem with the display.
check how many times the light blinks and get back to us.
Feb 08, 2009 | Toshiba TP43H60 43" Television
Toshiba big screen tv. tp43h60
Good Day;
I would suspect the convergence IC's, to confirm this unplug the convergence yoke, all three. If TV comes on IC's are bad. Also, check the little green pico fuses. Good Luck, big IRISH.
Nov 10, 2008 | Toshiba TP43H60 43" Television
sounds like maybe a fusible resistor has opend. Did you remove one leg of the resistors out of circuit when you checked them? Also some toshiba models had fuseable links near the ICs some mounted between the fins on the heatsink and others were solderd directly to the circuit traces themselves.
Mar 31, 2008 | Toshiba TP43H60 43" Television
what year was your set manufactured. The other site I work for as atech has a vast collection of toshiba service info
Mar 28, 2008 | Toshiba TP43H60 43" Television
No picture, sound and flashing red power light...
Pull off the back pressboard. At the bottom left hand corner is the power cord that attaches to the power supply board. There is a white plug that attaches directly to the power cord. With the TV power off, pull this white plug up to disconnect. Then push it back in. Then plug your TV back in and press the power button on the front of the TV. I just did this and it is working fine.
Sep 16, 2007 | Toshiba TP43H60 43" Television
Toshiba tp43h60
You have a bad regulator IC or something in the seweep power supply is blow out. if you can read a schematic, i suggest you get one to troubleshoot the solid state circuits in this TV set. if you do not have any solid state repair experience or no electronic background, play it safe and call in a pro to assist you in the repair of this TV set. Good Luck.
Mar 17, 2007 | Toshiba TP43H60 43" Television
Toshiba TP43H60 43" Television Logo
95 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
