Question about Kitchen Ranges
I have an old(over 20 nyears) free standing magic chef model No. 177-31DB2 range. I put it on the cleaning cycle and everything seemed to be working well. But then it seemed like there was alot of smoke so I interrupted the self cleaning cycle by moving the timer ahead and shutting the thermostat and moving the selector out of the cleaning cycle. The oven totally cooled down but the oven door light does not go off and the door remains locked. Is there anyway that I can manually open the door.
  • tjmax Apr 01, 2008
    The range does not have a lock button. The door locks automatically when the temperature reaches 400 degrees. I did not try to force the door open. The range has totally cooled down but the lock light stays on and the door still will not open. Don't know what to do and the manual provides no solution.
    Novelist:
  • 184 Answers
WHEN THE DOOR IS LOCKED ON A SELF-CLEANING RANGE, AND THE TEMP GETS ABOVE 400 DEGREES, IT LOCKS THE LATCHING ASSEMBLY SO YOU CAN'T OPEN THE DOOR AND GET SCORCHED. IF YOU FORCED THE HANDLE TO TRY TO OPEN IT, YOU BENT THE ARM OF THE LATCHING ASSEMBLY. IN ORDER TO RELEASE THE LATCH,
ONLY IF YOU FORCED IT TO THE OPEN POSITION, YOU MUST FORCE IT BACK TO THE LOCK POSITION TO STRAIGHTEN THE ARM.THEN IT MIGHT RELEASE.
IF YOUR RANGE HAS A LOCK BUTTON THAT NEEDS TO BE
PRESSED TO SLIDE THE LATCH TO THE LOCK POSITION,
YOU WILL HAVE TO SET ALL CONTROLS BACK INTO THE CLEAN POSITION AND PRESS THE LOCK BUTTON TO RELEASE THE LOCK ON THE LATCH ASSEMBLY. YOU SHOULD HEAR A BUZZING OR HUMMING SOUND WHEN THE BUTTON IS PRESSED.
Posted on Mar 31, 2008
SOURCE:
Can I put a new burner receptacle on a very old range?
As long as the new element has the same wattage rating and you performed the receptacle installation correctly, there is no reason why this cannot work. Using the wrong wattage rating element can have impact on the control regulator knob for the element.
Oct 13, 2016 | Magic Chef Kitchen Ranges
Magic Chef microwave model#mco165ub cant seem to turn up the power level. when I hit the power level button it cycles through -20, 0 and +20 but nothing happens when I hit enter.
Try unplugging the unit for a few minutes. The microprocessor on the control panel may have locked up. Leave it unplugged for at least 15 minutes to see if it will reset.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jul 16, 2016 | Magic Chef Microwave Ovens
Magic Chef DISHWASHER - mODEL du4k, STOPPED DURING drain cycle
I am assuming that the pump motor is bad, and since the unit is at least 15 years old (just guessing), we decided to wash the dishes by hand till after the holidays!!
Merry Christmas
Dec 09, 2009 | Magic Chef Dishwashers
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Oven goes on without being turned on
the control switch tripper problem that switch has to be replaced with a tripper.
Dec 15, 2008 | Magic Chef 31000 Gas Kitchen Range
Magic chef range
if you give me a model number i be might be able to help try here get your model number off the serial plate from the range http://www.maytag.com/support/manuals_literature.jsp if that dont work reply to this thread with model number
Jan 15, 2008 | Kitchen Ranges
Kitchen Ranges Logo
263 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
