Question about GE WCVH6260FWW
GE WCVH6260FW washer
My GE WCVH6260FW washer stopped adding the softener into the wash cycle just stays in the softener holder? What to do?
I should have been more specific above. Remove the detergent drawer by first pulling it out until it stops. Then reach back into the left rear corner and press down on lock tab and pull drawer out. Remove the softener insert. Clean out the hole that the softener insert came out of. Put the insert back in and then put drawer back in. Hope that was your problem.
Posted on Aug 10, 2008
The solution gradually clogs the drain hole. Stick a toothpick or something similar into the hole to unclog. Worked for me.
I have same problem-looking for solution also
Posted on May 18, 2008
Fabric softener compartment does not empty
Try cleaning out the fabric softener holder with some type of citrus cleaner to dissolve the wax build up, or run a hot load without adding any fabric softener to an empty washer. Good luck!
Aug 21, 2010 | Kenmore Washing Machines
GE Washer Model WCVH6260HWW, Fabric Softener Won't Dispense/Drain
I took the tray out and placed it to the side. Then I ran a common pipe cleaner through the nozzle that supplies a water spray to the tray. So far, so good.
Jan 28, 2010 | GE Energy Star WCVH6260F Front Load Washer
My Ge Adora washer fabric softner dispenser
You have low water pressure which wont reach the dispenser drawer during rinse cycle. Clean the feed pipe in case there's dirt in the feed gauze located at the back of the machine. The mould on the rubber is dirt in the machinme. A mixture of 1 cap of bleach and 1 small tub of Swarfega mixed with water and put into the drum on an empty wash will stop it geting worse but it cant be removed.
Dec 09, 2009 | GE WSXH208A Front Load Washer
Adding liquid to rinse cycle
on your h-3 the soap disp tray will allow you the add powder ,liquid, bleach, or fabric softner at the time you put soap in disp then the water valve will dispence at proper times in the wash cyc you don't have to stop the wash cyc
Aug 26, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Bleach and softener is going in with it's cycle
Pour a pot of boiling hot water through the softener side. Try this a couple times. Let me know how it works.
May 29, 2009 | Kenmore 43042 Front Load Washer
The fabric softner is not going into my washing machine
hi there just try washing the complete soap drawer again in boiling water leave in there for 10minutes to let the hot water work into the gaps and make sure u take all the holders out of the drawer u sometimes have to use a tooth brush to get into the small holes at the bottom of the little funnel what your softener holder goes over also get a small flat blade screwdriver and clean inside that funnel if thats not clean it will stop softener from going away if this doesnt work still then when your softener is supposed to be taken thru the programme make sure the washer opens the valve for the water to go into the fabric softener holder if it doesnt then the solenoid will need replacing as this could be faulty. LET ME KNOWHOW U GET ON PLEASE PETER
Nov 15, 2008 | Washing Machines
Clothes softener does not drain out of the holder
Do your clothes smell funny? Does it take forever for a load to wash? That happened to me and there was a wire loose in the machine somewhere and it would quit mid cycle and never finished a rinse or spin cycle. My fabric softener never drained either!
Oct 03, 2008 | GE Energy Star WCVH6260F Front Load Washer
Fabric softener dispenser
remove top of machine, there is a arm running across from programe dail, to drawer despenser,its spring loaded it determines which compartment the water gos into,check it
Nov 13, 2007 | Frigidaire GLTF2940ES Front Load Washer
GE WCVH6260FWW Logo
307 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
