Question about Refrigerators
American style samsung f/freezer iceing up on back wall in fridge section,I have replaced the back panel but still icing up
    President:
  • 1,314 Answers
Im alittle confused is the iceing in the fridge or freezer
Posted on Mar 31, 2008
Freezer not making ice
Is it an icemaker? Either the water valve is bad or the freezer isn't cold enough or the ice maker is bad. Is it just a ice cube tray? Then it's not cold enough.
Aug 25, 2016 | Samsung RSH1DTMH American Style Silver 524...
Samsung fridge not working freezer is?
sounds like you removed the defrost tstat.you need to replace it.if your evap coil ices up it will block the cold air flow to the frige section.replace your bad part so your defrost system willwork
Nov 27, 2012 | Samsung Refrigerators
I have an american style fridge freezer from Samsung and it is buzzing when the fridge door is shut. I am guessing there is an ice build up around the fan but cant get the cover off easily. Any ideas...
i had a fan noise and the repair tech replaced the fan...turns out that the new fan was also making noise which lead me to look for other problems which lead to the fan problem
new fan was also buzzing in my freezer after some time...noticed ice build up towards the bottom right corner of the back panel (in freezer)....i diconnected power...took the back panel off .....fan had frost on it....coil was iced up.... then on the back of the refrigerator i accessed the control board....plugged the power back on ...i jumped the line to the heater...heater didnt work....then checked resistance through the heater (checked ok)....
it came down to me replacing the defrost thermostat which is in series with the heater....defrost now works fine ...which is every 60hrs for 45 minutes on mine.
good luck
Oct 02, 2009 | Samsung Refrigerators
I have a Samsung American style side by side fridge freezer - not plumbed in at present. The freezer works ok but the fridge ices up in the bottom half and the overall temperature will not drop on the...
these samsung are liable to ice forming around the fan and jamming it.
take the backplate off inside the fridge and melt the ice off with a hairdryer. make sure the fan rotates freely as well.
if memory serves me right, samsung did a mod to prevent this
Oct 20, 2008 | Samsung Refrigerators
Water Dripping Inside
Sounds like a blocked defrost drain. By "American" I presume you mean side-by-side.
I had a similar problem with a freezer-on-top style Samsung. The solution to that was to defrost the freezer, remove the false backing plate in the freezer (required removal of the ice cube tray. the panel just pops out with a bit of pulling). The drain hole beneath the freezer coils was blocked with ice. This drain passes down into the fridge and then out the back of the fridge into the evaporation pan next to the motor. There is a collector pan under the freezer coils, this and the drain hole were filled with ice. When the freezer goes into its self-defrost cycle the water collects here and then overflows into the fridge.
I removed the ice with hot water/vinegar mixture (so it doesn't re-freeze immediately) and simultaneosuly used a bit of chiselling with a screwdriver to clear the drain plug. I did this from inside the fridge working up the drain hole into the freezer. The whole job took about an hour.
Aug 24, 2008 | Freezers
SAMSUNG RS20CCMS AMERICAN STYLE FRIDGE FREEZER
in the freezer section there is a 6 screws. unscrew them and remove the back panel. there will be 2 wires attached to the panels, remember where they go. you will see a metal evaporator which will be filled with ice. this is the problem. use a hairdryer to melt the ice. this is essential as you mustn't puncture the wall of the fridge with any sharp item. before replacing the panel ensure that everything is dry or ice will reform, and also ensure that the fan blades are turning properly or cold air will not be blown into the fridge.
May 22, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Samsung fridge freezer
hey gordon is this model 4 drawer electronic control with the display in the ice door
Feb 16, 2008 | Refrigerators
Samsung, american style fridge
hi lemmy, i will find out from samsung tech and get back to you, this is an unusual prob,,
Jun 04, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
131 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
