Question about Panasonic Workio DP-2500E Copier
Panasonic 2500 we have a panasonic 2500 multifunction and it has a e-0401 error code do you know how to clear it?
  • ss53 May 12, 2008
    We have the DP-2500 and the error code E0401 comes up. I've been told that is because the toner is running low, however there should still be some ink left yet we are unable to use the copy functions at all on it. Any advice would be great!
  • mchomboto Nov 04, 2008
    THERE IS A SPANNER SIGN ON LEFT CORNER WITH E401-01.IF I TRY TO PRESS FUNCTION ITS NOT RESPONDING
  • 100 Answers
E4 errors means fuser error, probably you encountered lots of fuser jamming.
the best thing to do is to ask your service provider to check your machine but for the mean time, you could erase the error log.
press function + orig. size + 3
press 9
find ram initialize
find LBP FUSER RESET
note: make sure that LBP FUSER RESET is the selected one
press set.
restart your machine
if you still encountered an e4 error, it means that there is a physical/hardware problem on your fuser unit.
i hope this could help u. : )
Posted on Aug 22, 2008
ERROR E000004-0401 ON CANON C4080i WHAT DOES THIS MEAN
Code
E000004
Description
Fixing temperature abnormal rise
The temperature detected by the main thermistor does not rise to the specified value during startup control.
Remedy
1.Go through the following to clear the error: CLEAR > ENGIN > ERRCLR; and then turn OFF and then ON the power. 2.Check connection of the Connectors (Thermistor Connector and AC Connector). 3.Replace the Fixing Main Thermistor (Film Unit). 4.Replace the Fixing Assembly. 5.Replace the DC Controller PCB (PCB4).
Sep 28, 2016 | Canon Office Equipment & Supplies
My canon iR c5185i displays error E000004-0401 please help me he solution
This is a fuser unit error, if powering off & on the machine the error doesn't clear then you will need to have the fuser unit replaced.
Aug 25, 2014 | Canon Ir-c5185i With Feed, Fax, Finisher,...
Need help trouble shooting stuck on black screen dell inspiron 1720 so ran Diagnostics this is what i get backError code 0148 Msg:error code 2000-0148 Msg: unit 0:Ide error: status 1A error registry 0020h...
Error Code 0148
msg: Error Code 2000-0148
msg: Hard Optical Drive 0 - incorrect status 1 A Error
Register: 0020h
sense information: (02-0401)
sense: 70h 00h 02h 00h 00h 00h 00h 0Ah 00h 00h 00h 00h 04h 01h 00h 00h 00h 00h
Sorry but you have a hard drive issue. Replace the drive.
Mar 10, 2014 | Computers & Internet
Error code e000004 0401
1. Make the following selections in sequence to perform the error clear:
[Service mode > COPIER > Function > CLEAR > ERR].
2. Turn the control panel switch OFF > turn the main power switch OFF/ON.
3. If the error code still persists, check to see if the connector [1] of the fixing thermo switch is disconnected or the pin [2] of the receiving side connector is bent. If the connector is disconnected, re-fit it.
Jul 29, 2013 | Canon imageRUNNER iR C4080 Color Copier
ERROR CODE 3151-351F-B780-0401-C000-0022 xbox
how to fix my xbox 360 it shows the same thing it shows a code 3151-351F-B780-0401-c000-0022
Sep 17, 2011 | Microsoft Xbox 360 Console
I am getting an error code 6A00 but can't find anything in the manual pertaining to that error code. Can you help?
Try turning the multifunction printer on and off to reset the error. If this does not clear the error, this code may indicate a paper jam Check the paper path for a piece of paper
Let me know if this clears the problem. Thanks.
Jun 09, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Error message: E000004-0401
Probably the copier is iR C5185i
- E004 = Fixing unit protection circuit trouble
-  0401 = Check the connection of the connectors of the relay PCB, the IH power supply, the fixing thermoswitch, and replace the fixing unit (fixing
thermoswitch OFF), the relay PCB, and the IH power PCB (blowout of the
FU261).
In the service mode, clear the error by selecting COPIER > FUNCTION >
CLEAR > ERR.
You need a canon technician to resolve this problem.
Sep 25, 2009 | Canon Office Equipment & Supplies
OBD code 0401 (1997 Toyota Camry 4 cyl)
There is a VSV (vacuum switching valve) , usually mounted on the back side of engine block, under the intake manifold, as well as the map sensor, that can also cause that code if one or the other is faulty. It takes some pretty detailed troubleshooting to confirm this in some cases, so if that's not in your line of work, you may have to have it properly diagnosed, or take a 50/50 shot at which one first.
Jan 24, 2009 | 1998 Toyota Camry
Panasonic Workio DP-2500E Copier Logo
384 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
