Question about Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television
Green and pink wavy through out the screen
Green and pink through out the screen
  • Pioneer Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to figreen and pink wavy through out the screen - 69189a5.pngrgence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jul 03, 2010
I have pink and green wavy lines. Most pronounced at the bottom of the screen.
Ur tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments anywhere in the pictures,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 24, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Green and pink wavy lines throughout. Picture
I am having the same problem and so far unable to fix,
Jan 22, 2010 | Pioneer SD-582HD5 58" Rear Projection...
3 d green and pink
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 02, 2009 | Samsung HCM422W 42" Rear Projection...
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Coulor distortion at the top left of the screen
Hello jordan ashe,
This is an indication that the green CRT is having a convergence problem. This might be caused by the convergence amplifier or by the CRT. Does the rest of the picture look OK? and in addition can you supply a picture of your TV so as I can see what you are seeing and develop a proper diagnosis?
Thank you,
Shuttle83
Sep 28, 2008 | Hitachi 53UDX10B 53" Rear Projection...
MODEL NO SP42W4HB PICTURE DISTORTED TOP AND RIGHT SIDE COLOURED SHADOWS COLOURED WAVY LINES TOP THIRD SCREEN PINK AND GREEN
This is most likely a convergence problem. You should see 2 large black ICs in side attached to a heatsink. They will be marked STK392-010. Try resoldering the pins on these ICs first. If that does not resolve the problem, replace them. These parts will be about $20 each.
Keep us posted.
Dan
May 28, 2008 | Samsung Televison & Video
Emerson TV EWT2721 27"
Did the TV get pink with the wavy lines all at once, or did it start out gradual? If all of a sudden, then a defective part on the CRT control board or the picture tube itself could be going bad along with some components in the video section of the set. Probably not a cheap and easy fix I'm afraid.
Jan 01, 2007 | Emerson EWF2703 27" TV
Samsung HCM4215W pink/green and wavy
Practice visual acuity technique!Check signal PCB for CRT coolant leak.Cleaning circuit board may restore normal operation,but one or more leaks will cause problems to re-occur.Change leaky CRT(s).
Dec 19, 2006 | Samsung HCM4215W 42" Rear Projection...
Pink picture with wavy green and blue lines
start with convergence ic's probably stk 392-130 big black chip's on an alluminum heat sink. mark ALL connections with majic marker. check for bad solder connections. for god's sake be carefull
Oct 19, 2006 | Sony KP-53S65 53" Rear Projection...
Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television Logo
113 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
