Question about Philips 19PFL5422D Television
It turns on it has sound but no picture model 42pfl7662/05
How do I fix my model tv No picture but knocking sound?
The knocking sound is the high voltage trying to fire. That would tell me that the high voltage splitter has failed or one of the 3 picture tubes (not lamps) has failed. Most likely too expensive to repair a TV that old.
Sep 12, 2015 | Sony Televison & Video
WHEN MY FRIEND'S TEVION TELEVISION MODEL No. 3241TS IS TURNED ON, A PICTURE FLASHES ON THEN DISAPPEARS. SOUND IS STILL ON BUT NO PICTURE. THE SAME APPLIES IF CONNECTING AND PLAYING A DVD.
That sounds like the inverter board. I would go online and search for the inverter board for that model TV. Replacing it is a very simple task once you take the back of the TV off.
Mar 01, 2015 | Televison & Video
Tv turns on but no picture but has sound and menu
55" rca projection tv turns on has sound but no picture
Feb 11, 2010 | RCA Televison & Video
My Flat screen model no. LCT2721ad will not turn on.
I have a vizio 42 " LCD TV, model #VX42L, I was watching tv last nite all
of a sudden there was not sound or picture, I could not turn the tv off, but I could turn the dvr off. Still no picture or sound.
Sep 22, 2009 | Akai Televison & Video
Picture good but no sound on my Hitachi model 50ex20b
Your audio switch on the back may have gotten moved please check the switch
Mar 10, 2009 | Hitachi 50EX20B 50" Rear Projection...
Sound but no picture
check with a flashlight against the screen for picture, if present backlight inverter has failed.
Dec 07, 2008 | iLO 3200 32 in. LCD Television
RCA Home Theater (Model #P46924) No Picture, just sound
Sounds like a possible solder issue with the vertical output IC. Try resoldering the Vertical output IC connections
May 17, 2008 | RCA P46924 46" Rear Projection Television
Phillips 60pp935217
I have a phillips HDTV monitor model 60pp935217, i don't get an hd picture but i do have sound. Please help.
Apr 08, 2008 | Philips 60PP9352 60" Rear Projection...
No picture just clicking sound
with your model number manny have a defective flyback part number is 1-453-310-11
regards,
daniel.
Mar 31, 2007 | Sony KV-27FV16 TV
Picture and sound go away after 2 minutes
Protection circuit fault kicks in. No vertical Deflection (V STOP),B+ over voltage protection (OVP), This is about a $150 -$200 to fix.
Nov 04, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Philips 19PFL5422D Television Logo
295 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
