Question about Samsung SGH-G600 Cellular Phone
How do I save a phone number from an incoming message to the phonebook, and how do I only show numbers in my contacts only from PHONE not duplicated from SIM and PHONE.
Go to options and it should have save adress and it should havet he number they gave u and the senders number and click the one you want vto save and rename it and that should do it =]
Posted on May 16, 2010
I want to block unwanted callers from calling me . i am unable to block these callers
to block a particular mobile number, if the contact is saved in your phonebook, do these.
1. press menu,
2. select settings
3. select application settings
4. select call
5. select all calls
6. select auto reject
7. scroll down and select reject list and add number.
8. select search and it will give an option
9. select from two options, call log and phonebook
10 select phonebook (this is because the numbers were saved in your phonebook)
11, once set and configured, check and enable auto activation
12. click save and exit the settings.
if the contacts is not on your phonebook.
follow the steps 1-9 but step 10 will be your call log not the phone book.
10. select call log
11. it will give you the phone numbers of all the person who contacted you, including those who sent you a message,
12. at the right upper corner you will see all, filter it through received message and it will give you those who sent you messages.
13. select from the contacts or numbers from the list.
14, select and enable auto activation
15, select save and exit the menu
Apr 11, 2011 | Samsung Star GT-S5233 Cell Phone
All my incoming calls are displayed as unknown number even for people saved in phonebook!
hi friend, this problem occurred. bcoz, same numbers are saved two time in your phone book. so, delete those numbers. which has saved as unknown name in your phonebook. go and check it.
Regards: Rakesh
Jan 31, 2011 | LG KS360 Cell Phone
THE INCOMING SMS IN MY INBOX DOESNT SHOW MY PHONEBOOK CONTACTS NAMES.INSTEAD THEY SHOW phone NUMBERS. It has stopped recognizing numbers by the names i have saved them in my phonebook.KINDLY HELP
this problem occurs when phone internal memory is low or corrupted, first do a contacts backup and complete back up on storage card, then do a factory reset from phone setting, and restore contacts fro card. if problem still persists do a online software update by downloading nokia software updater from nokia we site
Dec 22, 2010 | Nokia E63 Cell Phone
Dear Sir, I am using Samsung SJ700 mobile phone.And sometimes I get incoming call with no number displayed on the screen. It just shows incoming call. Can you pls help me in sorting out this...
This happens when two or more similar (saving one number with different names) contacts is saved on your phonebook, i.e. if you've saved my number on the sim card with a name and at the same time you have my number (same number) on your phone's memory, the caller id will not be displayed, you'll only see the "Incoming Call" or "Call". So I would suggest you to please check the phonebook and delete (keep only one per number) if there are multiple similar contacts saved on your phonebook.
You can also reset the phone to Factory default, in case there's no problem with your phonebook/contacts.
Good luck.
Thanks for using FixYa.
Aug 14, 2010 | Samsung Cell Phones
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
Message appear the contact number not name
Ive has this problem before, this normally happens if you have your contacts saves twice in your phonebook, for instanse if you have them saved to the SIM and the phone. Try deleting either all SIM contacts or all phone contacts, your messages should then show as the name you have it saved as in your phonebook.
Jun 04, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Blocking unwanted numbers
Normally you can so long as the caller is presenting their number through Calling Line Identification (CLI) - ie you can see the incoming number on the screen.
If you can see the number, save the number into your phonebook. Create a Group in your phonebook and put the number in it. Then normally you can automatically reject calls from a Group - either by the Group options, or by the settings under the phones Profiles.
Mar 27, 2009 | LG RUMOR Cellular Phone
Motorola Problem
Thats not atall software prob buddy. You verify that your messages are saved on phone memory and that you are not using SIM stored numbers. You can surely backup all phone memory numbers to SIM by copying.
May 31, 2008 | Motorola Mobility W375 Cellular Phone
Samsung SGH-G600 Cellular Phone Logo
48 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
