Question about 3002 2 Way LED Car Alarm Keyless Entry System
Out of range issue on viper 3002
I have a viper alarm system model 3002 and my problem is when my alarm is triggered i'm not getting notification on my remote? I think I've narrowed the problem to an issue of either my remote, or the antenna. I read the owners manual, and it says that when i arm my system if my remote responds with 3 sets of 2 quick beeps and the Green led flashes 6 times that I'm "out of range"? My system arms ok, and I'm standing next to othe car when setting th alarm so how can i be out of range? Someone told me I may have a bad remote, or my antenna may be bad any other suggestions?
I am having this same exact problem. Have you found a solution to this problem yet?
Posted on Jun 18, 2010
I am getting a second alarm when the first lock alarm is pressed in my wingroad car and when you open the doors the alarm is not coming on
If you open the doors when the alarm is armed and, the alarm does not trigger then, you have the wrong door trigger wire connected. If you were to list the year, make and model of the vehicle I could direct you to the proper wire and location.
Jun 28, 2013 | 5601 1Way SuperCode Security and Remote...
I have DRL on my car and with the factory alarm remote when you press either the lock or unlock the head lights or the parking lights come on. With my Viper 2 way remote no lights come on when pressin
The Viper alarm (and most other alarms) are designed to be connected to the parking lights.The headlights are not meant to be flashed continuously, as when the alarm is triggered. If you want the headlights to activate with the alarm then, the parking light wire from the Viper needs to be connected to the headlight wire instead. NOT RECOMMENDED.
Although the Viper alarm may or may not have a horn output (you didn't mention the model) ,it can be connected and it can be programmed to sound either when the alarm is triggered or all the time(depending on the model).
By the way, the Driving while Running Lights are seperate from the Sentry Illumination Lights. The Sentry Illumination Lights are designed to illuminate the area in front and around of the vehicle before and after entry. They can be programmed for the time that they will illuminated before and after entry.
Aug 25, 2012 | Remote Start System
2005 dodge dakota horn honks while arming vehicle with Viper alarm instralled
You need to look under the dash for the model number then contact viper support
Feb 17, 2012 | Vehicle Parts & Accessories
I have a 2011 doge avenger with stock alarm and 504k shock added. when i remote start the car the horn blows for 2-3 secs. turning off 504k stops this. help
You are having this problem because the OEM alarm will shut off your engine and trigger your alarm when the hood is opened. Your 504k sensor is connected to your hood, so when you start your car remotely, the vibration is triggering your shock sensor and thus triggering your alarm. I had this same problem. You need to reduce the sensors sensitivity dramatically to help resolve this issue.
Jul 23, 2011 | Viper 504d Double Guard Shock Sensor Car...
Had this viper alarm installed on a mustang and the alarm seems to go off every 30 minute
If your alarm is going off every 30 minutes its because a zone is backfeeding after the cars computer shuts down. First you have to find out what is back feeding... I would first disconnect the door trigger wire from the alarm to the car. Test it and if this is the problem then you should go to the latch wires of the car doors and not the interior domelight. If the problem is still there than you should check to see if the trunk trigger is the problem. Most techs pick up the trunk trigger in the trunk at the light. if you find that this is the problem then just remove the trigger from the light and add a pinswitch in the trunk.
Dec 28, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I ordered a viper 3002, does it have a remote start and I'm just not seeing it?
The Viper 3002 is not a remote start system. It is only a security system with keyless entry. In order to remote start your vehicle with the 3002, you will need an add-on unit installed.
Dec 23, 2010 | 3002 2 Way LED Car Alarm Keyless Entry...
Just baught a truck with a viper alarm, worked great then today i unlocked the truck with the viper remote and when i open the door the horn goes crazy for for about 1 min not the accual alarm! but at the...
Can be somewhat complicated to explain, particularly without knowing the make, model & year of the truck and which bypass was used to integrate into the factory systems. But here's one thing it might be. The Viper system is aftermarket obviously, when the alarm is triggered the siren with start to sound, and sometimes the horn will honk as well (depending on the vehicle and the bypass). If the siren isn't blaring that means the Viper system was disarmed when you unlocked the doors but not your factory security....or another way to word it is if only the horn is honking and no siren then you're factory alarm system isn't being controlled by the viper remote the way it should be. The factory disarm wire needs to be connected. It's a light green wire with a black stripe in a red connector in the Viper alarm brain. For anything more specific I'd need some more info on the vehicle. You can email me at jared@underground-audio.net if you'd like.
Nov 17, 2010 | 7752V Replacement Transmitter Supercode...
I have a Viper Alarm 3002 2-way on a 2003 Mustang GT. After removing it, my car no longer starts. Please help
if your car doesnt start, maybe when you pulled out the alarm, you didnt connect the starter wire back together
Aug 19, 2010 | 3002 2 Way LED Car Alarm Keyless Entry...
Alarm System
No it won't reset your alarm system. As part of the bit-writer program, anything you set or change in the alarm menu will remain the same. The only thing that can happen is if you have a DEI 520t back up battery, it may trigger the alarm upon re-connecting. No biggy.
Feb 25, 2009 | Viper Vehicle Parts & Accessories
Viper 5701 2 way alarm and remote start
Most ford need the door triggers double diode isolated. When the GEM module goes to "sleep" it will set of your alarm . Cut the factory wires where you hooked up the door triggers determine which side goes to the door and which side goes to the GEM module. If it is a negative trigger solder in a 3amp diode with stripe towards the door then solder the door trigger from the alarm to the door side of the diode. Repeat for all door triggers.
Dec 18, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
3002 2 Way LED Car Alarm Keyless Entry System Logo
463 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
