Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Water will not flow. It is a kenmore cold spot
Water will not flow. It is a kenmore cold spot with ice and water on the outside
  • Kenmore Master
  • 4,654 Answers
Most likely the dual water control valve is not opening to allow the water to the dispenser if that is your meaning. Now if you mean water for both dispenser and ice maker then that would change everything. See if you can locate the model number that Sears puts on the door frame near floor. The fresh food section door at base and the number will look like this example 312.256489 With that number I can see everything your side by side came with and tell you the parts and locations. You also can have someone test voltage going to the water control valves while someone presses the dispense water switch. And with a voltage meter set to OHM's test the coils on the dual water control valves for resistance and if one has a very different number that can tell you. So we have several things to look for, water supply, dual water control, (if one works and other will not) and model number, Let me know what you find, Sea Breeze
Posted on May 16, 2010
  • John Tripp
    John Tripp May 16, 2010
    If your model number begins with 106. it was made by Whirlpool. And I will not be positive until you confirm yours, but the water control valve is part number Click Here=> 4389177 and found on back of refrigeraor near floor. There are more than100 model numbers very close to that butdon't worry if close theparts will be correct. Click here=> 10650262992 User Manual Look through this manual an see if it looks like yours. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
    Thanks, Sea Breeze
  • John Tripp
    I see you have a water filter also, had one yesterday was getting very little flow, Sea Breeze
Ice maker in kenmore coldspot refrigerator quit making ice, nowater flow
There are several causes of no ice maker operation. First, is the freezer cold enough? It must be below 32F to operate the icemaker. 2nd: Is the bale or metal rod that runs along the side of the ice maker in the down position? 3rd: You may have a failed water solenoid valve, located on the back of the unit. The plastic or copper water line from your house's water supply is attached to this valve.
Apr 11, 2015 | Kenmore Refrigerators
Why does my refrigerator keep acting up the freezer gets frosted up then the frig gets warm I have cleaned it underneath unplugged it for 24 hours then plugged it back in it works great for about a w
This problem can have many causes, but generally it is a defrost issue. If the freezer coils are frozen over, they block cold air flow to the refrigerator; and can be caused by different part failures. See the link below for a good explanation of possible failures and for parts. Also, if you turn the refrigerator temp to 0ff and unplug the refrigerator then plug it back in, it should go into defrost mode. Leave it that way for 15 or 20 minutes, then unplug and plug it back in. It may resolve the defrost mode problem. If not you'll need a part, or repair man. Kenmore Refrigerator Freezer is Cold But Refrigerator is Warm
Oct 18, 2014 | Kenmore Refrigerators
I have a kenmore coldspot fridge model # 106.73182302. It is only 7 years old and it is not keeping a cold enough tempature in either the freezer of fridge. The problem started with water leaking from...
my gsi 23 ice maker continues to flow water into the ice maker after the tray is full. It flows non-stop and floods the kitchen until I raise the arm that turns the unit off. I have no ice?
Sep 09, 2011 | Refrigerators
What would cause the airflow to stop to fridge when freezer door is closed? (kenmore model 106)
Ice in the path of air flow to fridge. The freezer also kkeps the fridge cold via a fan that blows the cold air from feezer to fridge.
Aug 21, 2011 | Kenmore Refrigerators
I have a kenmore 90 series, while filling..it's all hot and very little cold. I've checked the outside lines and their clear. So now I'm going inside, any thoughts?
newer washers have a thermister on water valve meaning water temp usualy between 42 and 92 degrees in the tub is the flow of water normal
Jan 23, 2011 | Kenmore Washing Machines
I have a Kenmore Cold Spot Model 70192000. Having
HI, I can help you with this. It sounds like the defrost drain is plugged. If you will get me the model# from inside the fresh food section of the refrigerator, I can look up this model and instruct you on how to repair this.
Thanks
Vic
Jun 08, 2009 | Kenmore 50522 / 50524 Side by Side...
Ice maker stopped working???
water valve or icemaker or make sure freezer is freezing check see if you have frost build up
Apr 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice Maker problem
check if it has one the filter, hollow ice = lack of water flow into the icemaker
Apr 26, 2008 | Refrigerators
Kenmore coldspot fride problem
The water line could be frozen. Take a hair dryer and heat up the tube where the water enters the ice maker. MAke sure it doesn't get to hot and start melting the plastic,
Feb 01, 2008 | Refrigerators
ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
Dec 08, 2007 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
196 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
