Question about Home
I have an Eljer Windsor toilet. The assembly in the tank was cracked, so it continued to leak water, causing it to allow water into the overflow tube. I just replaced the entire assembly. I need to get instructions on how to make the proper adjustments to shut off the water intake at the proper tank level. I'm fairly sure it is a balance between the counterweight and the float. Thank you.
  • lwchinn39 May 17, 2010
    Yes, my plumbing "guru" was very helpful, giving me multiple ideas for resolving my problem. The final recommendation of bending the solid brass rod to lower the float worked! Thank you!
    Bending the brass rod did the trick! Thank you very much for your quick responses and solutions!
  • 560 Answers
Hi. I believe that graphical presentation is easier than reading instructions in plain text so I am giving you the link of the instruction with picture.
Adjust the valve and float - go to step no. 4
http://www.wikihow.com/Fix-a-Running-Toilet
Here's another good instructions but no picture illustration.
http://www.ehow.com/how_2070148_adjust-toilet-water-level.html
Please let me know if you need further assistance. Thank you for using FixYa.
Posted on May 16, 2010
  • 3 more comments
  • lwchinn39 May 16, 2010
    Thank you for your help. I tried adjusting the screw, per the instructions, in both directions, to no avail. I also tried adjusting the screw closest to where the float is attached. When I manually lift the float, the water does stop, but I am raising it fairly high - high enough so that it would hit the tank top.
    Here is a diagram of the assembly:http://www.plumbingsupply.com/eljertoile...
    Also, here is picture of the top of the assembly, so you can see how the screws are afixed:http://www.plumbingsupply.com/images/elj...
    Not sure how the counterweight component affects the system.
    Thanks for your further consultation.
    -Louis
  • Liza Halbrook
    Liza Halbrook May 16, 2010
    what is the length of your float rod? the idea is to make the rod shorter or make it lower so the floater can only float at a certain level.
    The new rod is 7-1/2" long. The old one was 8-1/2". Tried bending the new rod down earlier, but it's a strong brass rod.
  • Liza Halbrook
    Liza Halbrook May 17, 2010
    yes, that is a strong rod and if you find a way to bend that so the float can go lower, that will adjust the water level.
  • Liza Halbrook
    also, please make sure that the float can move freely and doesn't touch the sides of the tank.
Eljer Windsor One Piece Toilet help - leaks water into bowl
I would go back with the ballcock kind. However, the flapper will need to be replaced. It is not seating properly. The fluid master is a revised version and a bit more efficient. It should work well also. They both work off buoyancy and shuts off water the same way.
Feb 18, 2013 | Home
My toilet keeps leaking water and then fill ups on its own. Where could the leak be how do I fix it? Also I have to hold down the flush lever awhile for the toilet to completely flush. Can this be fixed ?...
If you are not getting puddles on the floor then it is probably the 'FLAP" that holds the water in the tank. It is the rubber part that is connected to your handle. Any hardware store will carry that part since it is an item that will fail, especially in hard water. It is probably the cause of both problems.
Jul 25, 2011 | Eljer & Titan Elongated Toilet Bowl
I have an Eljer 141 0220 toilet. The the tank leaks into the toilet and every so often the water runs to refill the tank. Initially, I replaced the flapper. That did not work. I then replaced the...
I had one just like that where the overflow tube that the flapper connects to was cracked. It sounds like this is the only part you have not replaced. The flapper may not be seating onto the inlet either. If you replaced the flapper with a cheaper version of flapper, some new ones will even leak.
May 16, 2011 | Eljer 141-0220-00 Toilet Tank White
A small intermittent water leak in the flapper flush valve unit which also causes "water hammer" in the copper piping in the basement. New flapper valves did not solve the problem Sanding...
Older Eljer toilets are good for this and yes you need to replace the complete flush valve assembly. I would recommend putting in a fluid master system as they in my opinion are the best. Their kits come complete with everything you need to do the job and provide excellent instructions and if that is not good they have videos on their web site. The site is slow to load but worth waiting for.
http://www.fluidmaster.com/
Mar 08, 2011 | Eljer Home
Eljer 0220 toilet leaks from tank to bowl, then fill valve spurts out water from top and around the edges, and also through the tube that goes to the overflow. Replaced the flapper, but still leaks. Also...
When the tank is full and leaking into the bowl reach in and put slight pressure on the flapper and if the leak stops then you may have the wrong flapper or the flapper is not installed properly. If that is not the case then make sure the flush valve seat is not cracked or that the surface is not warped.
Mar 05, 2011 | Eljer 091-0220-00 White Savoy Two-Piece...
My eljer toilet leaks between base and back. it has a built in overflow. there is no overflow tube. i change gasget but still leaks.
Look for cracked ceramic at gaskit joint might need to replace tank..I did after weeks of trail and error.
Nov 28, 2010 | Eljer & Savoy& Toilet Tank With Lid
Leaks from tank into bowl and when flush as it
Change the flapper with a generic one that will fit that toilet... the OEM flapper is **** and it does not allow for a good flush either...
heatman101
Aug 03, 2010 | Eljer Toilet Onepiece Canterbury ...
Tank is not filling to water line
Turn clcokwise to rasie water level, don't mess with the weights unless adjusting the screw to get water to proper height does not do the trick.
Jul 04, 2010 | Eljer Toilet Onepiece Canterbury ...
My Eljer toilet does not always flush completely. It is approximately 20 years old. I don't believe that it is a venting problem. I have dismounted, inspected and remounted the toilet and found nothing...
Not being a plumber by trade I don't want to bad mouth what your plumber had to say but there may be other things to consider.
If the toilet does not flush directly into the main drain there is the possibilty that the coupling between the main drain and the toilet drain is under-sized which could cause reduced water flow and your toilet not flushing completely.
Feb 26, 2010 | Eljer & Elongated Toilet Bowl
Toilet tank looses water over time
As long as there is no water leaking from the tank to bowl connection, you are OK. You would know if it was leaking here, because you would have water dripping out onto the floor.
Verify that the water level in your tank is below the top of your new flush valve's overflow tube. If the water level comes to the top, it will overflow into the toilet bowl. This can be easily fixed with an adjustment to the fill valve.
If the water is not overflowing into this tube, then the only way you can lose water is through the flapper. You said you changed the flush valve, which would have come with a new flapper attached to it, but maybe buy a new flapper and see what happens???
Jan 19, 2010 | Eljer Aqua-Saver 12" Two-Piece...
Home Logo
196 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
